Planning on hanging my tube axle in my 1962 Falcon and the one I have is about 49 in inches center to center on king pins. I am thinking I want about 44 or 45. What are you running? I am running Shelby 15x4.5 Wheels. Also can any one tel me if this looks like Econoline spindles and drums?
Econoline axles are 52" kingpin to kingpin. If you have one that's 49" I think it will be perfect myself. Some people run narrower, but they look weird when you get the front up and go narrower. I'm running a stock width Econoline axle in my '63 Falcon with 15x4.5" ET Classic spokes, and 185-15 tires. It's right at the edge of the wheelwell, and the sidewall of the tires actually hangs out past the fender. Probably should have cut the axle 2"-3" prior to putting it in. This was a mockup picture, with front fender just hanging there to judge the width then: Those don't look like Econoline backing plates to me. Bolt pattern on the wheel cylinders looks too narrow. Raised area on the backing plate looks different also.
