Technical What type of open conversion is this?
Discussion in 'Traditional Hot Rods' started by JTW, Feb 24, 2014.
  1. JTW
    JTW
    No splines, key way tapered. Complete. I've only seen splined before? Is this an early conversion?
    Thank you guys.
  2. Looks like a stock Ford pick-up open drive banjo.
  3. fordcragar
    fordcragar
    from Yakima WA.
    That's what it is.
  4. Sphynx
    Sphynx
    from Central Fl
    Are they any good? I have a complete 46 truck banjo.
  5. summersshow
    summersshow
    from NC
    I gave 2 away last year...
  6. primerhotrod
    primerhotrod
    from ILLINOIS
  7. yep stock pickup stuff, been looking for a yoke for a while now
  8. F-6Garagerat
    F-6Garagerat
    Dick Spadaro sold me an NOS yoke last year. Give him a call.
    I see people spending big $$ for aftermarket open drive conversions. The stock pieces are as good as any. I scored a complete center section for my A pickup and it had a 3:54 ring and pinion.
  9. turdytoo
    turdytoo
    The real kicker here is the pinion being threaded to hold the yoke on vs the splined pinion with a hole for the pin that holds the driveshaft on.
  10. DICK SPADARO
    DICK SPADARO
    42-47 Ford PU. good item, complete axles are a little wide for early fender cars but center section can be exchanged with earlier 35-40 axles and tubes for narrower open drive rear.
  11. butch27
    butch27
    I've built two of them. Running one in my T-Bucket.No trouble if you don't get crazy.
  12. fordcragar
    fordcragar
    from Yakima WA.
    What is the gear ratio, of the ring and pinion set?
  13. JTW
    JTW
    I will have to look tomorrow. hmm, I didn't know that they came like this.
  14. JTW
    JTW
    exactly.. thought that might be rare.
  15. They come in several different ratios. Lowest was the '42 4 cylinder pickup (basically a 9N tractor engine) that was offered as an option in '41 and '42. 6 cylinder trucks were geared lower than V8. Best I remember, the V8 pickups came with 3.78 or optional 4.11. I think the 4.11 was used on 6 cylinder.
  16. JTW
    JTW
    3:54 gearing. Are these going to be ok behind my mild 40 Flathead t-5 conversion. .AV8 car...? Or should I get rid and go with the 6 spline 3:77 gears?
  17. well, I have a 3.78 in my tudor with 750-16 rear tires behind a Y block and it seems to be a great ratio so far.
  18. JTW
    JTW
    I actually meant will this slip type yoke be ok? or is a splined a must?
  19. JTW
    JTW
