what to use when undercoating bed and cab
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Feb 23, 2013.
  1. tjet
    tjet
    1. Early Hemi Tech
    The ruberized stuff can trap water & it's generally a no-no for real protection. I only use WaxOyl, but I drive NY roads...I buy the real UK stuff below
    http://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=31508
    You may be better off using a spray on sound deadener or something...No need for HD Waxoyl stuff in CA, unless you live at the beach
    I used POR 15 on my old car when I was in CA. Worked good, but the black stuff turned brown when exposed to UV light
  2. landseaandair
    landseaandair
    from phoenix
    I'd think bed liner would be a nightmare if you ever need to do sheet metal repairs later.
  3. Frankenstein57
    Frankenstein57
    I used rust seal from KBS coatings, on the frame and under body. They recommend a cleaner, and primer etch, 3-step process. They come in different colors, frame coater kit was about 75-80 bucks. Good stuff, I'm building a 57 which I had planned to powdercoat the frame, think I'll stay with this stuff, Mark
  4. pressuredrop
    pressuredrop
    from mesa AZ
    Rustoleum makes a good rust converting primer, its about 6 bucks a can at home depot. Wire wheel all the rust scale and loose paint, then blow off all the dust and debris. Apply at least 2 good heavy coats of the rusto stuff. Then get a spray in bed liner kit make sure you get the gun with it ( u-pol and raptor are both good). That will be more than suffcient for both corrosion protection and sound deadening, and should only run you about 150.00
  5. bathcollector
    bathcollector
    I sanded the entire underfloor and under the fenders on my 56 F100 with a 3m clean n strip disc and emmery tape where the disc couldn't reach, rust neutraliser on any surface rust then etch primed it a couple coats and sprayed 3m paintable body schutz over the primer. Another coat of etch primer over the body schutz and painted a couple topcoats in industrial enamel with hardener added. looks real good.
  6. Bert Kollar
    Bert Kollar
    NAPA rubberized undercoating seems to be the same as 3M and cheaper. Works great
