Technical What to use to clean yellowed gauge numbers?
Discussion in 'The Hokey Ass Message Board' started by Paul, Jun 5, 2020.
  1. Paul
    Paul
    Editor
    I am putting together a set on Stewart Warner gauges, black face, white needles and numbers.
    A few of the gauges whites are nice and bright,
    some are yellowed.
    I looked around the interweb and see various bits of advice, Windex, 409, etc
    Any first hand experience with successful results here?
    What worked for you?
  2. olscrounger
    olscrounger
    be very careful. I have cleaned the numbers with windex and a soft cloth lightly-came out fine
    loudbang and Paul like this.
  3. alchemy
    alchemy
    Light water or maybe Windex on a Q tip to clean the dust. But you'll never change the yellow to white again.
    Test a corner, maybe the little part number on the bottom edge of the face, first. If it wipes the paint off down there you can prevent ruining the whole face.
    loudbang, Paul and olscrounger like this.
  4. Can you get new face decals for them?
  5. Paul
    Paul
    Editor
    I could have them rescreaned but this is a budget build.
    Primary gauge in question
  6. Paul
    Paul
    Editor
    Matching tach is bright and clean,
    Oil pressure gauge is about as yellow as speedometer, rest are various shades between them.
  7. 41rodderz
    41rodderz
    from Oregon
    Hey , it’s traditional.:D
    kidcampbell71, loudbang and Paul like this.
  8. big duece
    big duece
    from kansas
    I would leave it... find some other gauges to match:D
  9. loudbang
    Have you tried some full strength bleach on a Q tip? Try it first on a less visible area.
  10. rockable
    rockable
    My gauge restorer said they soak them in a mild acid bath. I have no clue exactly what that is but Google could probably help you find out more.
  11. indyjps
    indyjps
    How about yellowing/browning out the other gauge faces.
    You could use thinned out water colors. Rinse them off if you dont like the look.
    loudbang and big duece like this.
  12. ClarkH
    ClarkH
    If you want to test some of these methods on something less precious, I have a few crappy yellowed gauges in my swap meet pile that you can use. PM sent.
    I wonder if a "mild acid bath" is vinegar?
    kidcampbell71, Paul and loudbang like this.
  13. fleetside66
    fleetside66
    I've experimented with this over the years & it's pretty well a lost cause. Anything harsher than Windex will tend to do irreparable damage. Besides, there's a big learning curve to the proper removal & replacement of the bezel & glass. I personally don't mind the yellowing, but I do hear you when you have a number of bright white ones & one yellow one. If it's not a valuable S/W gauge, just buy another one.
    That being said, I did have success with an old Moon gauge...one of the early ones that was made by U.S. Gauge. U.S. Gauge was first rate across the board & whatever process & materials they used to create the gauge faces for Dean Moon were very strong. Check out his vacuum gauge that I cleaned with Windex & a Q-tip. You can see in the first picture where I started to clean it. I did it very slowly, like you see the art conservators when they clean an oil painting.
    Lepus, big duece, loudbang and 6 others like this.
  14. john worden
    john worden
    from iowa
    Try careful rubbing with a clean pencil eraser.
  15. Paul
    Paul
    Editor
    I used the Windex on a Q tip method.
    It did lighten a shade or two,
    Sprayed the Q tip, gently wiped, changed Q tips often and stopped when they stopped picking up color.
    I don't want to get any more aggressive than that.
    Put back together.
    I may try adding just a touch of color to the tach.
    Pictures are before, during and after.
    Some change but not much.
    IMG_20200606_110219.jpg IMG_20200606_110506.jpg IMG_20200606_112639.jpg IMG_20200606_113042.jpg
    ClarkH, loudbang and indyjps like this.
  16. Jmountainjr
    Jmountainjr
    I would try a spray window cleaner that has vinegar in it. Use it on a Q-tip. Should you have a stubborn spot you could try white vinegar on the Q-tip.
  17. indyjps
    indyjps
    Looking good, Looking good.
    If those gauges are backlit, bulb selection could blend the colors as well.
  18. Paul
    Paul
    Editor
    Excellent point, hadn't thought of that
  19. ClarkH
    ClarkH
    That's what the previous owner of my car tried... :confused:
  20. Paul
    Paul
    Editor
    Now that's some funny shit right there :)
    loudbang and ClarkH like this.
  21. Paul
    Paul
    Editor
    I tried adjusting the color on the tach with what I had around the shop,
    Nothing I tried was working
    so I closed it back up.
    This is not a high priority issue now if ever.
  22. Kind of like a heavy smoker and non smoker...ha
    I looked at my 160 speedo but it's different from what you got, not sure on the others.
