Technical What the heck is this?
Discussion in 'The Hokey Ass Message Board' started by OahuEli, Nov 25, 2017.
  1. OahuEli
    OahuEli
    from Hawaii
    This jar is on the driver side fenderwell of my Dads '54 Chevy bottle on drivers fenderwell with arrow.jpg mystery jar.JPG mystery jar top.JPG . He and my brother have asked me what it is but I have no idea. Factory? Dealer add on?
    Stogy and chryslerfan55 like this.
  2. lostone
    lostone
    from kansas
    I would say from the way it's hooked up they are using it as a water injection unit.
    Looks like a old windshield washer bottle.
    Clay Belt and chryslerfan55 like this.
  3. 30dodge
    30dodge
    from Pahrump nv
    Looks like a top end lubricator. Used something like Marvel Mystery Oil.
    s.e.charles, mgtstumpy, egads and 5 others like this.
  4. squirrel
    could be for either water or oil, which ever kind of "magic" some guy believed in way back when.
    Interesting conversation piece, but I'd probably remove it or at least plug the vacuum hose
  5. Clay Belt
    Clay Belt
    Looks like some sort of vacuum canister, given how it connects. Other guess would be some sort of fluid resevoir. If you take the line off and sniff it, it might tell you what was in there.
    Fitnessguy likes this.
  6. henry29
    henry29
    Could be an aftermarket vacuum operated ashtray.
    OahuEli and Hotrodmyk like this.
  7. RichFox
    RichFox
  8. Stogy
    Stogy
    Early Nitrous...:D
  9. BJR
    BJR
    Older Ampco top oiler.
    s.e.charles, mgtstumpy, egads and 3 others like this.
  10. Deuces
    Deuces
    from Michigan
    Accelerator pump for that early morning startup.....:rolleyes:
  11. Stogy
    Stogy
    http://www.ampcolubes.com
    You guys are good...
    And they still make them...
    Quoted directly from the site above...:rolleyes:
    "The Original Ampco Lubricator - what is it?
    The Ampco top cylinder lubricator is an oil vapor delivery device, designed to supply a mist of oil vapor to your engine’s combustion chamber – the heat/friction/wear zone. Manifold vacuum draws metered oil through a nozzle into the air/fuel mixture, which lubricates valve stems, guides, seats, rings, and cylinder bores – everywhere your crankcase oil cannot reach. As soon as your engine pulls a vacuum upon startup, it is getting the benefit of undiluted, atomized oil to the hottest parts of the engine.
    The recommended lubricant for all Ampco oilers is Marvel Mystery Oil®, found at most auto parts stores."
  12. 56sedandelivery
    56sedandelivery
    Judging by the year of the car, it's a top oiler for sure. Water injection arrived on the scene much later I "think". What happens when the car reaches 88 MPH, anything? I am Butch/56sedandelivery.
    egads likes this.
  13. If it’s not a top Oiler
    My guess is a remote booze holder, check if there’s a petcock under the dash!
    OahuEli and egads like this.
  14. johnold1938
    johnold1938
    from indiana
    moonshine injection for fast getaways and spark plug cleaner!
    OahuEli likes this.
  15. Flathead Dave
    Flathead Dave
    from So. Cal.
    If I remember correctly, it is for lubrication for valves or cylinders. We had these on our cars when I was a kid.
    Sent from my SM-G930T using The H.A.M.B. mobile app
  16. deucemac
    deucemac
    Low tech snake oil injector system
  17. 1964countrysedan
    1964countrysedan
    from Texas
    If it feeds into the intake, could it have been a fuel priming contraption?
  18. Top end lubricator. If you have unleaded gas, and want to minimise valve seat wear, fill the jar with diesel, set it up for about 3 drops/min. at idle. I have been using a similar system on my daily drivers for years.
    mgtstumpy and Stogy like this.
  19. 4wd1936
    4wd1936
    from NY
    As stated by a few already, definitely intended for top cylinder lubrication and still a great idea for todays unleaded fuel. Might save you a stuck valve guide or a sunken valve/seat. Read about the history of Marvel Mystery Oil, there are a few different opinions with the most interesting I think involves Smokey Yunick, 50 caliber guns, tank engines and more.
    Stogy likes this.
  20. 34Larry
    34Larry
    I would have said water alcohol injection, but these other hambers know for sure. Had a buddy with a 56 Chev. in Air Force, Wichita convert his windshield washer to this on the sly at the on base drags. Push the button and with that car at least, stock eliminator was his for sure. Never did get caught.
  21. 1934coupe
    1934coupe
    Ding! Ding! give that man a cigar. Old timer I know had one on his 50 Olds 98 sedan. He was 2nd owner and put it on in the early 50's he sold the car around 15 yrs. ago and died shortly after.
    Pat
    Stogy likes this.
  22. OahuEli and Stogy like this.
  23. LOL ....No...Not this time:D
  24. Jack E/NJ
    Jack E/NJ
    from NJ
    This isn't magic. It's the real McCoy. The stovebolt will be in good hands but only if you leave it in there. 8^) Jack E/NJ
    Stogy and OahuEli like this.
  25. OahuEli
    OahuEli
    from Hawaii
    LOL, when my brother sent me the pictures I told him it was the reservoir for the flux capacitor. I don't think he bought my description.:D
    Stogy likes this.
  26. OahuEli
    OahuEli
    from Hawaii
    Thanks for all the info guys, you've been a big help.
    Stogy likes this.
  27. It's a vacuum leak with oil in it.
    Truck64, 49ratfink and OahuEli like this.
  28. I think these answers are the closest to the real truth!
    OahuEli and 49ratfink like this.
  29. dan c
    dan c
    back in the day, it was an nhra no-no to add alcohol to fuel. i heard of at least one guy who got away with it by using one of these to do that. the flagman smelled the alcohol, but they took awhile to figure out how it was done!
    OahuEli likes this.
