Technical What the H**l is up with old bumper sticker glue?!?!?
Discussion in 'The Hokey Ass Message Board' started by Old TFFdriver, Feb 6, 2016.
  1. Old TFFdriver
    Old TFFdriver
    I have tried WD-40 , brakeclean, lacquer thinner, gasoline, etc..!!!
    This stuff is like crazy...especially around the old edge of the stickers where dirt got underneath and has formed a hard ridge...
    Can not use anything abrasive...
    Any ideas?
    Thanks all and have a great day !
  2. Budget36
    Budget36
    Heat gun and plastic scraper, maybe?
  3. Try Turtle Wax bug tar remover , hope it helps. Or a larger sticker lol
    Old TFFdriver likes this.
  4. MikeRose
    MikeRose
    from Yuma, AZ
    Goo gone
    pat59, 1oldtimer and dan31 like this.
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Goo Gone and fine Bronze wool. You can get bronze wool at some hardware stores and most boat supply stores. The bronze wool should not scratch, but as always try it on a spot like the bottom of the bumper first.
    If it is on a painted surface a white scotchbrite pad and Krud Cutter cleaner available at most paint stores.
    KK
    T.L. likes this.
  6. Old TFFdriver
    Old TFFdriver
    WOW ! Thanks for all of the ideas ... I am simply amazed of the knowledge on this site !
    Any more?
    Might try a couple just to see what works the best.
  7. Old TFFdriver
    Old TFFdriver
    That made me Lol !
  8. Plain white vinegar, and a plastic scraper. Works like a charm.
  9. Slopok
    Slopok
    Lighter fluid, Isopropyl alcohol or nail polish remover.
  10. DDDenny
    This^^^^^
  11. nh-lead-man
    nh-lead-man
  12. T.L.
    T.L.
    from Colorado
    If you've already gotten the sticker off, try Goo Gone to remove the residue.
    A heat gun works like a charm for removing the sticker.
    "Goof Off" removes paint. Goo Gone does not, but it removes adhesive.
  13. AmishMike
    AmishMike
    a wacky idea from all the above - cooking oil. plain cooking oil like sunflower or Mazola will soften glue. if upright on bumper; wet a wiping cloth and soak it. Then a good rubbing with the wet cloth. Will soften many types of glue.
  14. The37Kid
    The37Kid
    Is it seven years old?
    pipebomb and belair like this.
  15. mike bowling
    mike bowling
    And the punch line is ?????
  16. 19Eddy30
    19Eddy30
    from VA
    New bumper!!!
    Vinegar ,
  17. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I get it! I just won't go there, but that was good!
    KK
    The37Kid likes this.
  18. Paint Guru
    Paint Guru
    from Bowdon, GA
    Use a eraser wheel, cost around$15, put in your drill at low speed, it will remove all the glue in less than 5 minutes.
  19. If it is, just put a Hillary sticker over it.
    gearheadruss likes this.
  20. If it was a little older, it might have read
    "Potatoe lovers for Quayle"
  21. Old TFFdriver
    Old TFFdriver
    The one that just won't seem to come off says.....
    This is your brain " GM FORD DODGE "
    This is your brain on drugs " toyota nissan, honda"
    Gonna have to leave it on I guess..;)
  22. stimpy
    stimpy
    3m woodgrain and adhesive remover works like a charm , haven't been able not to remove any yet with this stuff , most bodyshops have a can of the stuff , a couple of bucks for some on a rag will take care of it instead of buying a whole can at $20 , I just removed some decal gum with goo gone , and a hair dryer , heat it up first till its warm to the touch then wipe the goo gone on it and it softens hardened adhesive up in a couple of seconds .
  23. davidvillajr
    davidvillajr
    Wasn't there a thread a while back about the magic of dryer sheets?
    Hahahaha!!!
    But seriously, those Mr. Clean magic erasers can do some amazing things, plus, most folks have at least one of them in the kitchen.
  24. khead47
    khead47
    Peanut Butter!
  25. paleot
    paleot
    from louisiana
    3M used to sell two compounds, one to take off the sticker and one to remove the glue. Don't know if they still do haven't used any in several years.
  26. mmMMMMmmmm. Peanut butter... :)
    Use chunky style if you need something a little more abrasive. :rolleyes:
  27. Hot Rods Ta Hell
    Hot Rods Ta Hell
    I know Peanut Butter works great for removing chewing gum from hair w/o any cutting.
  28. Finnrodder
    Finnrodder
    from Finland
    Try decal remover discs.We call them the taffy discs in here,because they smell like candy.
  29. deathrowdave
    deathrowdave
    from NKy
    Hillary ha ha , somehow I'm not seeing the whole story here , you most have a different definition of a bumper than me , I guess because I use Mules to work
