I am using ABS Plastic for Door Panels ? What should I use ? ; 3m 77 3m 90 Loctite Heavy Duty Spray Adhesive Is there another 3m number to use Which holds up to heat better?
This was recomended by a few interior guys on another board. Because it is for tops it handles the heat better than the other 3M stuff. I used it to stick two thin Sintra panels together with the clips between them. Smokey
I wouldn't use a spray adhesive. I would use contruction adhesive or a mastic type used for composite floor tiles.
