Hot Rods What size front tires are you running?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, May 13, 2019.
  1. Roothawg
    Roothawg
    i think I may need to step up a size on my next build.
    On the Produce truck I ran a small VW tire, just because that’s what I always do. I think I probably sacrifice some ride for the big n littles feel. I have played with tire pressures etc, but it is what it is.
    So, I’ll open this up to every make, but the 35-40 Ford’s are the main focus I am interested in.
  2. I use to run 135 x 15's on the front of my '40 Fords, they rode fine. HRP
  3. Roothawg
    Roothawg
    I have 165 -15’s now.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
  5. DDDenny
    prpmmp and Roothawg like this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    165/80/15 as they are called these days.
  8. 1:45 SR 15's. Rides as good as a buggy spring Model A is going to ride.
    Gotgas likes this.
  9. 1:45 15's on this one too. No problem at nearly 145 at Riverside.
    prpmmp, Gotgas and Roothawg like this.
  10. BamaMav
    BamaMav
    from Berry, AL
    215/60/15, fat fender, fat tire. Just what I had mounted at the time. Probably go to a 70 series when I buy tires again.
    Roothawg likes this.
  11. deathrowdave
    deathrowdave
    from NKy
    165/75-15 on the 32
  12. gene-koning
    gene-koning
    225R 75 15 all around on the coupe.
    225R 60 15 all around on the pickup.
  13. Roothawg
    Roothawg
    and probably speed rated for 85 mph.... :)
    Just Gary likes this.
  14. mcmopar
    mcmopar
    from Strum, wi
    All the tires I find for a 4.5 inch wheel are speed rated for 93mph, unless I look at drag race tires. Are you looking for a skinny tire?
    Tony
  15. Roothawg
    Roothawg
    I actually am running a 5" wheel. It sits pretty low now. I am running the 165/80/15's. It's pretty much my go to tire, but I was wondering if I could get a little more ground clearance and soften the ride. I am scraping up all the Possums in Canadian County.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
  17. Roothawg
    Roothawg
    That's sort of what my grille does... ha ha
  18. Fred A
    Fred A
    from Encino, CA
    1. Upholstery
    Reads like a race to the bottom. How low can you go? The title of this thread begs for such boasts. I'm rolling on 550-18. Good luck in the corners! Fred A
  19. 5.60-15's have to catch the driveway at angle tho.
    Roothawg and Moriarity like this.
  20. Dooley
    Dooley
    from Buffalo NY
    205/70/15 20180521_191327 (3).jpg
  21. prpmmp
    prpmmp
    0426191301.jpg 0426191301b.jpg 0426191301a.jpg 6.70 front and 8.20 back. Pete
    akoutlaw, F&J, Roothawg and 1 other person like this.
  22. 19Fordy
    19Fordy
    5:60 x 15 front. 7:60 x 15 rear.
    akoutlaw and Roothawg like this.
  23. PHIL COOPY
    PHIL COOPY
    550-16 on the left......
  24. Chris, the coupe has the 165/80r15's, and I just put some 205/75r15's on the truck.
  25. Yes. But every major gasser team in the 60's used exactly the same tire. Speed rating, what's that?? ;)
  26. 47ragtop
    47ragtop
    I have 205/70 by 15 on my coupe now. 225/75 by 15 on the rear. I like larger tires on the front, I think they steer ( handle ) better with larger rear tires. 195/65 by 15 are also a good choice and 1" smaller diameter. Later Bill
    akoutlaw and olscrounger like this.
  27. olscrounger
    olscrounger
    195/65/15 on last 5 40's-235/75 /15 on rear.. Just did 39 woody with the same setup
    47ragtop likes this.
  28. 125 x 15 Michelin
    Dean Lowe likes this.
  29. Fronts are 5.90x15 on the A cabriolet, and 6.70x15 all around on the 51
  30. nunattax
    nunattax
    from IRELAND
    215/60? x15 7 inch rim .
