Technical What should I cast?
Discussion in 'The Hokey Ass Message Board' started by flathead 37, Jan 2, 2019.
  1. Finned Y block valve covers. Ill bite the bullet and test fit em for you...
    CudaChick1968 and flathead 37 like this.
  2. belair
    belair
    I don't know, but good luck to you. Maybe a single 4bbl. 303 and 324 Olds intake.
    triumph 1 likes this.
  3. 34Phil
    34Phil
    A rounded back frenching bucket with a separate swivel foot for a couple different vintage taillights so it could be screwed to back of PU cab or car package shelf as a third brake light.
  4. 51 mercules
    51 mercules
    4 71 blower intake manifold for a 331 Cad.
    kidcampbell71, rod1 and flathead 37 like this.
  5. A Boner
    A Boner
    Culver City license plate frame.
    Nailhead Jason and kidcampbell71 like this.
  6. oldolds
    oldolds
    I think your first casting should be something like a tag topper or club plaque. You can cast it and be done. Minimal machining to have a finished product. Just a little filing and sanding. Valve covers or intake manifold will take a lot of thought, and effort. You need to account for shrinkage and porosity, ect. Then it needs to be machined to reasonably exact specs.
    fourspd2quad and quick85 like this.
  7. Bandit Billy
    Bandit Billy
    pearls before swine...although I read somewhere you shouldn't
  8. bchctybob
    bchctybob
    I would make water cross-overs for Olds Rockets and Nailheads.
    Olds needs them when using a 6 x 2 log manifold or when the water part was trimmed off an old intake. A nice clean cross-over that uses a Chevy thermostat and housing.
    Nailheads need 'em cause they are sometimes lost or missing when buying a core engine, plus they are cast iron, a nice aluminum one that uses the Chevy thermostat housing in a plain version and a finned version to match the spark plug covers would be something that should sell.
    A_Burly_Wind and belair like this.
  9. junkman73
    junkman73
    What ever makes you happy is what you should cast.
    Hnstray and CudaChick1968 like this.
  10. harpo1313
    harpo1313
    from wareham,ma
    Windshield stanchions , different angles of coarse/
    flathead 37 likes this.
  11. Kan Kustom
    Kan Kustom
    Don't know but show us what you do when you do it .
    CudaChick1968 and quick85 like this.
  12. Three Widow's Garage
    I just got done with these, trying for a traditional look for a Cadillac 472 / 500 IMG_0030[1].JPG IMG_0029[1].JPG
  13. Rickybop
    Rickybop
    from Michigan
    You made those Cad valve-covers, TWG?
    Those are beautiful. Not enough nice finned valve covers for the various engines. I'd like to see 6x2 intakes that aren't presently available.
    Sorry we couldn't come up with very many ideas for you, flathead 37. :D Get busy...
    CudaChick1968 likes this.
  14. Ebbsspeed
    Ebbsspeed
    Cast whatever you want, as long as they aren't aspersions.
    Both the spark plug covers and the carb tops are pretty nice!
    williebill likes this.
  15. Three Widow's Garage
    Currently working on a 6 x 2 cross ram intake for the same motor plan is to cast it in individual parts - runners, flanges, logs ect. then tig it together. Its a ways out just 3d printing patterns at this time.
  16. bchctybob
    bchctybob
    Best looking valve covers I've ever seen for those big Caddys, nice work TWG!
  17. Rickybop
    Rickybop
    from Michigan
    Please make some finned valve covers for the B/RB engines. I don't see any around.
    And I luuuuuv 6x2 setups.
    Please have them ready by spring. Thank you.
    FunnyCar65 and CudaChick1968 like this.
  18. brigrat
    brigrat
    from Wa.St.
    Looking for someone to cast up a few Magneto covers with fins. The one I have is an early wannabe prototype that needs refining ...........................................
    IronTrap, Tuck, CudaChick1968 and 4 others like this.
  19. patsurf
    patsurf
  20. License plate "bottoms", hard to find.
    Holley / Stromberg custom frog mouth scoops.
    custom hood ornaments
    two piece intake manifolds to change # carbs.....
  21. VANDENPLAS
    VANDENPLAS
    I do a lot of work at a scrap aluminum foundry, really neat stuff.
    Try and make friends with machine shops in your area and get ahold of some of there turnings.and clippings .
    Usually good quality aluminum for making stuff.
    Cans and bbq lids stuff like that is of a lesser quality.
    Be carfull with lawn mowers and equipment ( chain saws trimmers etc)as a lot of them are made of magnesium! Stuff likes to burn!
    The foundry goes through all there scrap and piles the mag they get mixed in there loads in a pile to resell. A few years ago one of the operators took a skid steer bucket of mag and dropped it in the furnace! They had no choice and just let it burn itself out. Furnace was pretty much done after that full rebrick and rebuild !!
    kidcampbell71 likes this.
  22. flathead 37
    flathead 37
    Search "devil forge". They have a wide array of different foundries and forges. Mine can melt up to 20 pounds of aluminum which i think is a good start.
  23. flathead 37
    flathead 37
    Have my first complete model all drawn up. I plan on using a match plate setup because it is easier to make a larger quantity of parts, and should be easy to 3d print. I have some of my renderings all drawn up below. Capture.JPG Capture.JPG 2.JPG Capture.JPG 3.JPG
    williebill, wicarnut, fauj and 3 others like this.
  24. How about something simple like a traditional "el toro" shifter knob? :rolleyes:
    Like this:
    weps, CudaChick1968 and kidcampbell71 like this.
  25. big john d
    big john d
    from ma
    tech section had a post on how to make one we did it and it worked fine we used an old beckett oil furness burner and it worked very well
  26. jim snow
    jim snow
    This sounds like a great idea. Start small. Snowman
    CudaChick1968 and Just Gary like this.
  27. goldmountain
    goldmountain
    Another idea. How about an intake manifold that utilizes EFI components but looks like a 1960 Rochester unit to sneak by the HAMB?
    Sent from my SM-T350 using The H.A.M.B. mobile app
    steel3window likes this.
  28. slim38
    slim38
    from Sudan TX
    1. H.A.M.B. Chapel
    Holy moly! Those are nice valve covers.
  29. I was shocked when the Boss at worked asked me "can we make a clean room and put that filler in it to fill "lube".
    VANDENPLAS likes this.
  30. Thor7352
    Thor7352
    I used a beer keg foundry I constructed (idea found on youtube) to cast an intake manifold(s) that connects a Latham Supercharger to a Weber DCOE.
    Drivers Side fitting prior to final machining and media blasting:
    PLA 3D print ready for investment slurry prior to casting:
    I started a little over a year ago making the foundry and began casting last month. Let me know if you have any questions.
    -Thor7352
