Technical What rear end is this?
Discussion in 'The Hokey Ass Message Board' started by lebl468, Apr 14, 2014.
  1. lebl468
    lebl468
    Came across rear end, no tags, only numbers are the ones shown. Any ideas?
  2. sawbuck
    sawbuck
    from 06492 ct
  3. I am guessing Hudson?? Notice how the Pinion is in the center of the pumpkin.
  4. Perrorojo
    Perrorojo
    Plymouth? I think i have a light blue lawn mower in the shed with that rear end.
  5. squirrel
    looks like a late 50s to early 60s Mopar rear
  6. lebl468
    lebl468
    I was hoping it would have had a tag or something on it. I ran those numbers but no dice.
  7. squirrel
    Mopar part numbers are sequential, that casting number was first used in the late 50s, so that tells you what it is. and it looks just like a Mopar 8-3/4" rearend. And if you google the casting number, you will find out what it is.
    If you take more better pictures, showing the top, and ends, then others will tell you that's what it is.
  8. lebl468
    lebl468
    Thanks for the nudge in the right direction. I think it is a 8 3/4 Dodge rear end. I am going out today to measure the bolt pattern and turn it up on a tire so I can really scour it for additional casting numbers. Regardless it is free, so I think it will drag it home, never hurts to horde!
  9. Follow the link....it's a '57-'64 8 3/4
    http://www.mymopar.com/Mopar8_75RearEndGuide.htm
    As far as 8 3/4's it's the least desirable due to the bolt on hubs. You can change to normal axles I believe using factory parts, but you'll have to look that up.
  10. lebl468
    lebl468
    1-3/8" small stem pinion (aka. '741')
    Carrier casting numbers: 1820657 (1957-1964),
    There we go. 8 3/4 Dodge 57-64.
