What needs 11/16" wrench?
Discussion in 'The Hokey Ass Message Board' started by XXL__, Feb 17, 2013.
  1. J'st Wandering
    J'st Wandering
    11/32 wrench used on Fords somewhere. I think the Model A's. Can not remember where. Or is it on flatheads?
    At least where to use the 11/32 has to make you think. The use of 7/16 inch bolts, therefore the 11/16 wrench for the nuts, is pretty common.
    Neal
  2. Stock SBC motor mounts like from a late '60s car are actually 7/16 and the bolt head is alway they are 11/16 on the nut side as I recall and 5/8 on the bolt head.
    I used 1/16 taking my '53 Stud suspension apart. Some transmission mount bolts are 11/16 as well.
  3. 296 V8
    296 V8
    from Nor~Cal
    These must be the same people that market some of the wrench sets I see for sale that have no 11/16 …………… like the 7/16 fastener doesn’t exist.
  4. Taff
    Taff
    Y block down pipe nuts are 11/16th, I seem to recall
  5. Larry T
    Larry T
  6. hotrawd
    hotrawd
    from lima,ohio
    The real question is "why do they make metric wrenches?". They don't fit anything on my cars.
  7.
  8. chubbie
    chubbie
    I even have a cut off and bent mono use 11/16 wrench i made to put the throttle cable on my 970 case. i've even borrowed it out!! wow that was 30 years ago
    this realy isn't that strange of a tread:rolleyes: most guys don't own a 9/16 wrench and have NEVER needed one:eek:
  9. manyolcars
    manyolcars
    ALMOST EVERY BOLT ON A 8n, 2n AND 9n FORD TRACTOR IS 11/16
  10. billcove
    billcove
    from mass
    x3!
  11. fenderlessA
    fenderlessA
    from canada
    used one to replace the blade on my chop saw yesterday
  12. TagMan
    TagMan
    Best thing about 11/16" wrenches is that when I misplace them I don't miss them as much...
  13. Those guy must just own a tool box to be cool, but hardly use it. How the hell could you be a mechanic for 30 yr and never use one? I used one to remove the wheels on my dirt bike yesturday....
  14. Lots of things require or have 11/16" fasteners. Goofy damn question.
  15. scrappybunch
    scrappybunch
    from nj
    Just checked, mine is as worn as much as the 3/4
    Alot of front suspension uses 11/16..
  16. The old Lowey axles on my bicycles were 11/16"
  17. aaggie
    aaggie
    Maybe stealing the thread but I bought a set of Craftsman wrenches back in the early '60s and it included a 19/32" wrench. It still looks new and I have never used it for anything.
  18. jazz1
    jazz1
    the bolts on my bumper are 11/16 head and nut!
  19. Paul B
    Paul B
    Used one yesterday lower ball joint nova clip in my sedan delivery
  20. XXL__
    XXL__
    Thanks, HAMBers, for the references. I think this Internet argument has run its course... until someone googles the mis-information on that other board and represents it as fact-- you know, that 11/16" wrenches were created by a secret government agency to lull us into thinking there were uses for it.
    One guy really nailed the basis of his argument as follows--
    To which, I replied...
    BTW, not only does Craftsman make this wrench for some strange reason, but Stanley is in on the conspiracy as they indicate 11/16" is the standard NUT size for 7/16" SAE here-- http://www.stanleyproto.com/default.asp?TYPE=STATICLEFT&PAGE=charts/chart_23.htm&LEFT=left_cc_01.htm
    Oh well.
  21. 302aod
    302aod
    from Pelham,Tn.
    It takes an 11/16 wrench to remove the plug to put power steering fluid in my Massey Fergusen.
  22.
  23. Bert Kollar
    Bert Kollar
    Here's four hangin on my board
  24. Mr48chev
    There aren't any 11/16 nuts that I know of. There are plenty of 7/16 nuts that take a 11/16 wrench and that is what he was stating. nuts and bolts are always measured by the size of the shank/thread and not the hex of the bolt or nut. The gent who called you on it is correct.
    Walk into any hardware store of fastener supply and ask for a 11/16 nut or bolt and see the look you get.
  25. junk yard kid
    junk yard kid
    I would be dead in the water without it. In fact i told myself not to buy other sizes untill i get some more 11/16ths ones. Dont see as many at the flee markets.
  26. 50Poopbox
    50Poopbox
    They are all over Large Caterpillar engine's, like 3508's and even a few on smaller ones like 3406's.
    If I remember correctly, the nut that holds my brakeline to the frame on my '59 F100 is an 11/16.
    I believe -10 hydraulic hose's use an 11/16.
    I use them frequently, not always on cars but regardless, you have to be an idiot to say their is no use for them or "That a 11/16 fastner doesn't exist"
  27. propwash
    propwash
    from Las Vegas
    I won a twenty dollar bet once that I couldn't name an American car that used a 19/32" socket. Rod cap nuts on most FE engines. Don't know what else, but that was first time I ever used one (67 GT500)
  28. Olderchild
    Olderchild
    from Ohio
    Throw all them away, then when you need one i'll rent you mine:D
  29. Mike51Merc
    Mike51Merc
    If you throw away all your 11/16" tools you will soon discover everything they're needed for.
  30. 296 V8
    296 V8
    from Nor~Cal
