What kinda head is this?
Discussion in 'The Hokey Ass Message Board' started by overkillphil, Mar 10, 2009.
  1. overkillphil
    overkillphil
    So while hitting up a couple secret locations for stuff, I came across this head. It looks pretty cool, but I just can't figure out what it's from. Any help would be great!
  2. hotrod-Linkin
    hotrod-Linkin
    looks early chevy with extertnal rockerts
  3. overkillphil
    overkillphil
    That's what I thought at first, but the chevy ab had 2 intake ports and 2 exhaust ports not one, right?
  4. Slickster51_50
    Slickster51_50
    It looks to me to be off of a diesel engine!But i could be wrong.
  5. lentz automotive
    lentz automotive
    any head is good head
  6. oldblu65
    oldblu65
    from Tennessee
    Nothing gets attention quicker than using the word " head " in a sentence !:rolleyes:
  7. chopo
    chopo
    looks like a rusty metal one to me !!
  8. Pir8Darryl
    Pir8Darryl
    2 head bolts per cylinder? Bet they had head gasket issues with that one.
  9. I prefer it when Yankee Doodle is being hummed.
    Looks like the head from an edsel-alley ostrich. Built in about 19somethinorother.
    I have no idea what head that is but I'd just about bet if you can't find any other use for it that you could make on helliva trot line weight out of it.
  10. Dakota
    Dakota
    from Beulah, ND
    how aBOUT a willy Jeep Fhead, they had only overhead exhaust ports right?
  11. RichFox
    RichFox
    If it was an F head it would only have intake ports and valves, and clearance for the exhaust valve to open. No Willy
  12. Bruce Lancaster
    Bruce Lancaster
    With the flat bottom and general look...surely it is something from the Chevy/Olds family??
    On the other hand, a head Fox can't ID has to be something really wierd, quite possibly extraterrestrial. 1912 Finzi-Zamboni Tourist Trials model?
  13. overkillphil
    overkillphil
    Mmmmm, Zamboni.....
  14. theHIGHLANDER
    theHIGHLANDER
    I think it's an old diesel head. Can't see a spark plug hole, maybe those are injector holes?
  15. ugotpk
    ugotpk
    Must be one of them Hemi things
  16. The negitive Hemi. The dome was in the piston. :p
    I think diesel too.
  17. I suppose for a diesel you'd need more head bolts though. That wouldn't hold compression very well.
  18. DE SOTO
    DE SOTO
    You got good pics of the Top & Bottom .....
    But maybe some SIDE shots would help !!
    And whatever the casting Numbers are could help.
    My buddy has a 1916-17 Chevy 4 with external Valvtrain & i think its 2 port in & 1 port out. Don't rightly remeber but you could search that.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It's an early Chevy. Only the last couple years had two exhaust ports.
  20. hotrod-Linkin
    hotrod-Linkin
    this i said...
  21. RichFox
    RichFox
    I would be hoping it's a compressor head. It sure wouldn't hold much compression. It looks like the spark plugs fire into the hole between the valves. Never saw a compressor with spark plugs that was made to be a compressor. Thing would never live as a diesel
  22. blackrat40
    blackrat40
    Yeah...looks like a compressor.
  23. racinman
    racinman
    must be a whuppet
  24. OK, here's what it really is.
    It is a Chevy head, about a 25 or so. The earlier cars had a single exhaust port like the one pictured. About 1928, they went to a two port head. The two port heads are worth a couple of hundred if they're good. The Model "T" guys use them to create a "Poor Man's Rajo" setup. A spacer/adapter is used to make a combustion chamber and to adapt the head to the "T" block. On the Chev, the pistons did not come up flush with the deck, hence the flat surface on the head. Sorta like an early "W" block. I don't know if it would have any value to a "T" guy, but it may be worth grabbing just in case.
  25. hotrod-Linkin
    hotrod-Linkin
    i said all that...without the tech stuff
  26. Just tryin' to bring a bit of history into the post. If hopping up a "T" ain't traditional, then I guess I need to go work for Dwaine. I'll try to keep the "tech stuff" to a minimum. Maybe we can discuss pomade or tattoos.
    But I'll give ya' props, it is a Chev head as you stated.;)
  27. hotrod-Linkin
    hotrod-Linkin
    i was not dissing you.i was just stating that i identified it as chevy and it seems my post were ignored.as far as i'm concerned your post was good stuff
  28. RichFox
    RichFox
    You guys are right, but you already knew that. Heres a picture of one more togeather.
  29. No offense taken. Just bustin' yer balls a bit:)
  30. zzford
    zzford
    Or a whuppet out! ;)
