Technical What kind of screw is this....
Discussion in 'The Hokey Ass Message Board' started by RMONTY, Sep 9, 2017.
  1. RMONTY
    RMONTY
    I run across these from time to time, and can get by with making a small tip to get them out, but it would be nice to have a nice screwdriver to get these out. They always seem to strip when I try a homemade tip..... Screw.jpg
    lothiandon1940 likes this.
  2. DC40
    DC40
    I think they are called clutch head screw.
    Hnstray and fourspeedwagon like this.
  3. oldolds
    oldolds
    What he said^^^^^^^^^^^^^^^^^^^^^^!!!!!!!!!!!!!!!!!!!
    Hnstray and lothiandon1940 like this.
  4. TagMan
    TagMan
  5. DDDenny
    Public restroom stall screws.
    Truck64, LostBoy, tommyd and 2 others like this.
  6. 302GMC
    302GMC
    from Idaho
    Oh, come on ... everybody calls 'em $&%^&*(*^&*er screws ....
    Or Chevrolet screws. Apex brand was the best set of 1/4'' drivers
  7. They are also available at Ace Hardware. HRP
    6inarow likes this.
  8. BJR
    BJR
    Lots of old canned ham campers used them also.
  9. RMONTY
    RMONTY
    Awesome thanks for the answers! I just didn't know what they were called.
  10. Yep, clutch head. Had to buy a set of drivers when I had my 56 Chevy P/U.
    5 or 6 sizes.
    catdad49, deucemac and JB36LaSalle like this.
  11. Try getting them out when they're rusted in, I've drilled out my fair share and yes i have the correct screw drivers and bits to get them out.
  12. RMONTY
    RMONTY
    Should be called PITA screws
    milwscruffy and belair like this.
  13. belair
    belair
    Yup. They shut me down today. Can't find my bits.
    RMONTY likes this.
  14. Bandit Billy
    Bandit Billy
    My 62 Nova used them to secure the horn ring in my column. I found a medium Phillips head screw driver did the trick.
  15. get the correct driver and use a mapp torch to heat them use a couple times to help remove them. most of all be patient and if the heat doesn't work use a mix of 50/50 acetone and old ATF! nothing better!
  16. When I bought my '51 GMC the po gave me a handful of clutch head screwdrivers. Very thoughtful of him-
    Now if I just had the original door latches instead of the chinese tinfoil bullshit he replaced them with I wouldn't worry about falling on the ground every corner..
  17. Any napa should carry the clutch driver tools...
  18. verde742
    verde742
    1. a veteran died today
    Use "needle nose vise grip" Pliers to get first one out to take to "tool store".
    AFTER you get proper tool, as you twist anti-clockwise direction, tap with hammer on end of handle, to remove.
    chevy step vans interiors are assembled with them.
  19. tubman
    tubman
    About 15 years ago, I bought a selection of "odd" bits in a plastic case. I think there are 4 rows of about 20 bits each. It has just about every size of everything. For example, it has all of the sizes of Torx bits and all the same sizes of Torx bits with a hole in the center. (It seems there are Security Torx screws that have a pin in the center of the head to prevent the use of regular Torx bits.) Anyway, they have come in real handy for many things over the years, and since they are all in a single case, I can always find what I need. I can't imaging having 40 or so specialized screwdrivers cluttering up a few drawers someplace.
  20. sunbeam
    sunbeam
    GM used a lot of them in the late 50s early 60s.
  21. s55mercury66
    s55mercury66
    from SW Wyoming
    Here is a slightly OT tip...try not to use the tamper-proof, or security type torx bits on torx fasteners without the tamper-proof pin. The bits are pretty brittle, and will break easily without the pin in the center to support the hole in the bit.
