What kind of engine do i have? Whats it worth?
Discussion in 'The Hokey Ass Message Board' started by surfcaliforniasurf, Sep 2, 2013.
  1. surfcaliforniasurf
    surfcaliforniasurf
    Here are the photos of the numbers.
  2. blyndgesser
    blyndgesser
    from Georgia
    Context, please.
  3. surfcaliforniasurf
    surfcaliforniasurf
  4. surfcaliforniasurf
    surfcaliforniasurf
    burned a little oil thats why i pulled it out...
  5. henry29
    henry29
    Looks like 62 corvette 327 m/t 340 HP,
    whats the casting number?
  6. tfeverfred
    tfeverfred
  7. surfcaliforniasurf
    surfcaliforniasurf
  8. Jay Tyrrell
    Jay Tyrrell
    Looks like a 62-65 327 small block. I got one of those in my chevy!
  9. dubcee
    dubcee
    1962 vette 360 horse fi manual trans
  10. henry29
    henry29
    casting numbers are for 62-65 327 250-375 hp
  11. falcongeorge
    falcongeorge
    from BC
    RF can mean '57 283 truck or '62-'64 FI 327. In conjunction with the casting number, I would have to concur with the others, it looks like you may have a "fuelie".
  12. Atwater Mike
    Atwater Mike
    If it's tapered LESS than .008", ball hone it and fit it with a set of Grant rings. (cast iron)
    ...and don't forget the valve guides...
  13. falcongeorge
    falcongeorge
    from BC
    Or sell it and buy a crate motor, or two...:D
  14. surfcaliforniasurf
    surfcaliforniasurf
    What's a fueled worth?
  15. surfcaliforniasurf
    surfcaliforniasurf
    Fuelie dang auto correct
  16. surfcaliforniasurf
    surfcaliforniasurf
    Without fuel injection unit
  17. 296 V8
    296 V8
    from Nor~Cal
    Try on the other HAMB ........ the Hokey Appraisal Message Board :D
  18. Dane
    Dane
    from Soquel, CA
    :D high 5!
  19. surfcaliforniasurf
    surfcaliforniasurf
    Touché
  20. Larry T
    Larry T
    It's worth a lot---------------------------------------if you have the original car it came out of.
  21. falcongeorge
    falcongeorge
    from BC
    Seriously, try some of the corvette forums. You will probably start getting offers PDQ.
  22. 302GMC
    302GMC
    from Idaho
    Let's see the cylinder heads ...
  23. Black Panther
    Black Panther
    from SoCal
    Hey is it RF or RE? Either way....its a 1964 Corvette engine....see how the vin stamp starts with a 4? Its a '64 engine...
  24. DD COOPMAN
    DD COOPMAN
    Whoever owns '64 Corvette serial # 194374S103393 (coupe) OR 194674S103393 (convert) is lookin' for that block. Engine assembled October 17, '64. DD
  25. 327Eric
    327Eric
    Ditto. What are the casting numbers and date codes for the heads?
  26. falcongeorge
    falcongeorge
    from BC
    If they are original to the block, they will probably be #461's or 461X's.
  27. surfcaliforniasurf
    surfcaliforniasurf
    Thanks for the info...got it figured out
  28. Black Panther
    Black Panther
    from SoCal
    I am sure it was assembled October of 1963 for 1964 model year....GM nomally stopped building any certain model year in July-August....
  29. falcongeorge
    falcongeorge
    from BC
    Yup, I was just gonna say the same thing. So when you say you "got it figured out" whats the story? Alot of us want to know how this is gonna end. Was it re-stamped? Whats the story?
  30. DD COOPMAN
    DD COOPMAN
    DUHHHHHHH....I knew that date sounded "not right". How about assembled Oct '63? Sorry for the dumb info. Just for grins, what's the casting date on block above bellhousing flange? DD
