GM replacement dip stick tube, black stuff, like an enamel. I've tried every stripper I know, they won't touch it. So far they've made it dull. I know I can sand it off, but chemical strippers mean less polishing. I like that. Any ideas?
New dipstick tube? Probably powdercoated, only thing getting it off is a sandblaster and a lot of patience. You would be better off sanding it down a bit and painting right over it. BTW powdercoating makes for a decent prime coat on frames. Its flexible enough and adheres like crazy.
Don't think it's a powder coat. I tried gasket stripper, that normally eats powdercoat, Turns it into rubbery stuff you wipe/pull/and peel off. This stuff won't do anything. I can sand it off real fast, but it has a bracket fitted and that is a bitch to get at. Got to get it naked or the chrome won't take. Frightened to burn it incase it hardens. I might just sand blast the tricky area but it's thin, chemicals are best if I can find the right stuff.
More than likely it is e-coat, or electro coating. The stuff is put on all of the new vehicle dip sticks and is the same as the stuff that comes on new GM fenders. My shop that I work for deals in tubing for GM, and they require most of our parts to be e-coated. Heating it will take it off, but will leave a nasty residue, best bet is to use a sandblaster or hot tank it. You may be able to wire wheel it and take it off, we do that quite a bit at our shop. -Joe
Ah chrome, now I get it. I have had powdercoats get real stubborn. I occasionaly have someone powdercoat a frame before they bring it in for me to install a front suspension or something. I have even seen some dorks powdercoat thier polyurethane bushings, they never took them out of the four bars! I still say powdercoating given the latest EnviroNazi restrictions on manufacturers. I have gotten new engine pulleys and brackets that are coated with similar coatings.
Its probably a water base coating -bake dried.does any one remember the old red primer chevy used on 37-39 cars? that schit would stain into the metal and if original aircraft stripper will strip paint right down to it- AND STOP!it has to be DA'd off.......
