What is the best way to drop a Ford F100 with twin I Beam?
Discussion in 'The Hokey Ass Message Board' started by Jasonic, Dec 16, 2004.
  1. Jasonic
    Jasonic
    Just found a smoking deal on a 66 F100 - will be just what I need for work. Can anyone point me in the right direction for parts or the best way to get this thing closer to the ground?
  2. tatts
    tatts
    im most likely wrong but ive heard of fliping the i beam or take a blade and flatten the tires
    either way good luck
  3. cut and step the frame rails 4" between firewall and crossmember.[re mount engine....and radiator cradle]
  4. metalshapes
    metalshapes
    Tech Editor
    Elpolacko makes a Dakota kit that is real nice.
    He is in the HAMB O'Dex.
  5. Mor-drop use to drop twin I-beams , maybe they still do..if they are still in business?
    Belltech makes 3" drop twin I-beams , not sure if they do for your application
  6. burger
    burger
    from burbs
    Do a search on Google for "Dream Beams".
    Ed
  7. slammed
    slammed
  8. Spedley
    Spedley
    [ QUOTE ]
    [/ QUOTE ]
    what would flipping the axle??? I'm gonna get struck by lightning, but I put an '80 z28 clip in mine.
  9. Spedley
    Spedley
    [ QUOTE ]
    [/ QUOTE ]
    what would flipping the axle do??? I'm gonna get struck by lightning, but I put an '80 z28 clip in mine.
  10. fordiac
    fordiac
    from Medina, Oh
    if you want to go lower than 3" drop, cut that shit out and put something else in. I have seen volare clips, mustang based, and LTD clips. like mentioned, ElPolako makes dakota kit.
    dropped I beams can only get you 3". once you start cutting springs to drop it, the tires get tilted in on the top. for the rear end, lowering shackles, lowered leafs, or put the axle on top of the spring for a big drop.
  11. hollywud
    hollywud
    Im gonna hijack here ...I have a 56 Effie..Which would be the best for changing to IFS.MustangII,Volare?Im just starting to tear into this thing.
  12. hatch
    hatch
    from house
    Drop it off a cliff....definitely lower. [​IMG]
  13. hollywud
    hollywud
    Lower than "WHALE SHIT"?
  14. fishtank
    fishtank
    You can get dropped beams as mentioned, but they will kill your ground clearence. The front crossmember is huge on these trucks.
    I plan on using an 84 lincoln front, and flipping the rear end. I am pretty sure that they make a four bar kit for it. Check with Godfathers. As mentioned earlier, you can get a spring and shackle kit for them, but only for a maximum of about 4-4.5".
  15. a front steer Camaro stub. Got my twin-I-beam 79 F-100 shortbox in the ruts! Drove wonderfully too.
  16. fordiac
    fordiac
    from Medina, Oh
  17. Smokin Joe
    Smokin Joe
    I'm with Hatch. Take it out of gear, release the E-brake and push it over the edge. [​IMG]
    Then go buy yerself a 55, 56 f-100 and go from there.
  18. SnoDawg
    SnoDawg
    I have a friend that is putting a Aerostar IFS in his 66 looks like a pretty easy swap. And he got the Aerostar really cheap $100.00 (After a close encounter with a Moose) then stripped out the carcass sold the tranny for $200.00 he is way ahead the game.
