Technical What guages are you guys using
Discussion in 'The Hokey Ass Message Board' started by sdluck, Feb 4, 2020.
  1. alchemy
    alchemy
    Old Stewart Warners.
  2. Almostdone
    Almostdone
    New Stewart Warners with an old Sun tachometer in a 60-s flavor A. EF035D9D-325F-42A1-94F2-BECA12839743.jpeg 4BFC3593-6E66-4BD8-A820-9311A4AFFB59.jpeg
    Just Gary likes this.
  3. Atwater Mike
    Atwater Mike
  4. theHIGHLANDER
    theHIGHLANDER
    I went with New Vintage in my 39. Haven't run it yet but the product seems great, fit like it should (direct fit to my 39 dash), and all the needed essentials and paperwork is thorough. The speedometer uses a pulse sensor on the car's torque tube and calibration seems easy as pie with a simple 1 mile drive and push of a button. I like the looks too.
  5. G'day, With the amount of drag racing we've done and the extremely good luck we have had with Auto Meter Pro Comp gauges that is what I will use in the Corvettes. Plus I have a road box full of new Auto Meter liquid filled pro comps that I have pack ratted away. I believe there are four full sets including blower boost gauges.
    When cleaning out the parts that came with the 1959 I found a box with the complete original cluster that was in better than fair shape. The original odometer has less than 3 miles on it. The car has been a drag car all of it's life with after market gauges so they were never used. Tempting, but I do like my Auto Meter stuff.
    I do have way too much stuff boxed up and stored so this summer I am planning on going through the parts supply and a lot of stuff is going away. Too hard to sell up here so it will probably be dumpster time for a lot of vintage stuff.
  6. D32E3498-EDBC-4AEC-98CA-F27A2BB5B24D.jpeg I guess it depends on what kind of car you got. If I a got a early hotrod then I’d say Stewart Warner.
  7. fleetside66
    fleetside66
    Agreed. There are other period manufacturers, like U.S. Gauge & MMG&E, but Stewart Warner seems to have been more focused on cars than industry. I'm running early 1950's S/W Wings gauges & an early 1960's Son "Football" tach. They work great & are quite accurate.
  8. BrandonB
    BrandonB
    from nor cal
    Vintage art deco speedo, vintage stock oil pressure & temp gauges out of ??? and vintage Stewart Warner.
  9. alchemy
    alchemy
    Brandon those temp and OP gauges are from an Autocar truck. Maybe Cord too. Possibly used in other off-brand applications as well.
    BrandonB likes this.
  10. 36 dash.jpg Vintage Stewart-Warner Curved Glass in my 36 ( Survey Speedo) and Football tach..
  11. Desmodromic
    Desmodromic
    I use 19 or 20 for sheet metal, usually 11 for chassis.
    theHIGHLANDER and Just Gary like this.
  12. gene-koning
    gene-koning
    Speed Hut for me. Made in the USA to order, come with all the senders & wire. Programmable speedo, or GPS speedo. Several style choices, then several options in each style. Gene
    firstinsteele likes this.
  13. Dave G in Gansevoort
    from Upstate NY
    Gauges, we don't need no stinking gauges!
  15. fordf1trucknut
    fordf1trucknut
    I have vintage Stewart warner and a vintage 1953 sun tach. 20210129_212846.jpg
    I do have a factory gizmo somewhere that goes in line of the speedometer cable that changes the speed. It came off an old truck with a 2 speed rear... so you may be able to use something like that if you were only going to change between 2 gears with your quickchange.
    continentaljohn and kadillackid like this.
  16. Combination of new & old SW Deluxe.
    ffr1222k and kadillackid like this.
  17. connielu
    connielu
    1. A-D Truckers
    It may have been mentioned already, speedhut makes a gps drive box that will work with any vintage speedometer. Hides away out of sight too. It's called a "speedbox." Pricey but a good solution it seems
  18. connielu
    connielu
    1. A-D Truckers
    Malcolm likes this.
  19. I have 6 Marshall gauges in my El Camino and have been pleased with them.
  20. rockable
    rockable
    I used the Autometer Antique Beige gauges in my Plymouth. When I found out my transmission didn't have a speedo drive, I was lucky to be able to use their GPS module. Works great and looks great, IMO.
    https://www.autometer.com/gauges/antique-beige.html
    Jalopy Joker likes this.
  21. Roothawg
    Roothawg
    So what is everyone doing about the 1940 Ford dashes? I want all of my gauges to be as accurate as possible, but still have the look.
  22. I seem to remember that there is a 70's Dodge Dart? cluster that fits the 40 standard gauge bezel. It's not as cheesy as it sounds, it looks pretty good and gives you more accurate gauges. Here's a pic and the thread I found it in. Paging @mj40's https://www.jalopyjournal.com/forum/threads/40-ford-dash-in.318841/
    brEad, Elcohaulic, mrspeedyt and 5 others like this.
  23. Automotive Stud
    Automotive Stud
    brEad, 36and63, alchemy and 1 other person like this.
  24. blowby
    blowby
    from Nicasio Ca
    I'm using blood pressure and pulse ox. My car is using what it came with.
  25. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
  26. nochop
    nochop
    from norcal
    My dad built the dash in the 50’s I added the gauges as the originals were MIA 1DA4FC9B-0AF9-4E1F-917B-20F4DEBD918B.jpeg
    brEad and Just Gary like this.
  27. 57JoeFoMoPar
    57JoeFoMoPar
    I have white faced Moon gauges in my 57 Ford, as well as a few in my 61 Olds. The older ones, from approximately 2004, were made by Autometer and are really nice quality, and have performed very well in the years I've had them. The ones I bought a couple years ago for my 61 were made by Dolphin, and I have to say I am somewhat disappointed in them. Some of them were lit differently than others and looked weird in the dash. Also, the oil pressure gauge and water temp gauges are "not to scale", meaning the midway point between 2 numbers is not necessarily the midway point in actual reading. I think that's bullshit. If I wanted to guess as to what the readings are I would have just left the idiot lights in the dash.
    I put a cheapo set of Speedway mechanical gauges in my 56 Olds last year and they've been OK. The water temp gauge was a little sticky for a while, and would be stuck bottomed out even when it was obvious the engine was up to temperature, but it seems to have broken itself in.
  28. 41rodderz
    41rodderz
    from Oregon
    Stewart Warner Wing gauges here .
  29. deansrr
    deansrr
    I have Auto Meter in my 74 Roadrunner, with GPS. I'm going to be using NVU in my 30 Tudor, also going to use GPS, it makes it simple
