Technical What guages are you guys using
Discussion in 'The Hokey Ass Message Board' started by sdluck, Feb 4, 2020.
  1. Almostdone
    Almostdone
    Same as DDDenny. Mechanical speedo. You might like a GPS Speedo if you are going change gears much.
    Elcohaulic and mgtstumpy like this.
  3. sdluck
    sdluck
    Nice thank you guys.
  4. Dave Mc
    Dave Mc
    Can't beat the accuracy of GPS , no matter the Tire size or Gear Ratio, (second pic is the GPS Sensor) IMG_0516.JPG IMG_0523.JPG
    brEad likes this.
  5. I was going to say that I like S/Ws. I have been known to robe the Lucas gauges from an English sports car too.
    As for speedo with your quicky it really don't matter the speedometer cable attaches to the tail shaft of the transmission or the front of the torque tube if you are using a conventional speedometer.
  6. Dino 64
    Dino 64
    from Virginia
    SlamIam, ekimneirbo, i.rant and 7 others like this.
  7. Malcolm
    Malcolm
    from Nebraska
  8. Dino 64
    Dino 64
    from Virginia
    Have no idea how that happened :eek:
  9. pirate
    pirate
    from Alabama
    Auto Meter, Pro Comp Ultra Lite
    AChopped1950ford and joel like this.
  10. mgtstumpy
    mgtstumpy
    VDO in my 35 Chebby (Standard with Master cluster)
    New VDO movements in my OEM 46 Olds cluster
    Shadow Creek likes this.
  11. mgtstumpy
    mgtstumpy
    I've not yet looked to determine what brand these are in my 64 Ford
    Jonneville likes this.
  12. fleetside66
    fleetside66
    Everyone knows that two is better than one...unless it's years behind bars.
    town sedan likes this.
  13. flamedabone
    flamedabone
    Big ass Moon speedo.
    More big Moons.
    Stewart Warners.
    -Abone.
    kadillackid, brEad, SlamIam and 4 others like this.
  14. 4speed411
    4speed411
    Yes....beverage holder...Kool Cup
  15. Blue One
    Blue One
    from Alberta
    Forgot to add pictures. Classic Instruments hot rod series.
    4FC11762-7E75-4AF1-8988-EF52520CBB43.jpeg B8EC88AC-138A-4E10-A466-0E2F42280FF7.jpeg B0E3B753-EB58-4868-AFC0-DCEC67D7081D.jpeg
  16. Seepwater
    Seepwater
    Once used S/W gauges from an old Jeep...
    triumph 1 likes this.
  17. I have the Marshall gauges. I like them but the LED odometer doesn't look traditional. They do seem to be accurate.
  18. sdluck
    sdluck
  19. Blue One
    Blue One
    from Alberta
    4 5/8” speedometer and tach and 2 1/8” gauges.
  20. panhead_pete
    panhead_pete
  21. southcross2631
    southcross2631
    I use Bosch gauges . In fact I just bought a new tach for my SEGA super stock project. DSCF3594.JPG
    Bosch tach, Sun blue lines and SW 2" temp gauge phantomed behind the stock lens. Wanted something accurate with numbers on it!
  23. Dave Mc
    Dave Mc
    Those are from Speed Hut , on their website , you can choose background color , Dial types Etc. in other words , Build your own set . >>>>>>>>>>>>>
    https://www.speedhut.com/
    Just Gary likes this.
  24. alanp561
    alanp561
    What's the matter with the old gauges and what do they look like?
  25. mike matters
    mike matters
  26. sloppy jalopies
    sloppy jalopies
    I ran stock 6v gauges in a '47 tudor running 12volts for 2 years, sold...
    I ran the hot wire to all but amp gauge through a "momentary switch",,,
    depress it, read the gauges, let off the button and they sleep … HIH.
  27. ydopen
    ydopen
    E32A5E89-A18F-424E-ABAE-81093D0131BF.jpeg Classic,s. You can compare indicated speed with a phone GPS and use a chart to calibrate the
    Speedometer for any tire or gear ratio. Very simple.
    John
  28. edcodesign
    edcodesign
  29. Elcohaulic
    Elcohaulic
    I like the new Stewart Warner gauges but I read of people having issues with them.
    MMM1693, Just Gary and Atwater Mike like this.
