What good will come out of a 331 Hemi????
Discussion in 'The Hokey Ass Message Board' started by edgeabilly, Aug 10, 2007.
  1. edgeabilly
    edgeabilly
    I bought it off Ebay and I would like suggestions. That would be should I run 2x2, 3x2 or 6x2 maybe 2 4's ( TUNNEL RAM?). Let’s hear it guys what do you think I've got my ideas lets hear yours.
    Oh it's going in a 27 Dodge sedan or a 34 Ford coupe.<!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" o:preferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <v:path o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" alt="" style='width:12pt; height:12pt'> <v:imagedata src="file:///C:\DOCUME~1\Shelton\LOCALS~1\Temp\msohtml1\01\clip_image001.gif" o:href="http://www.jalopyjournal.com/forum/images/smilies/biggrin.gif"/> </v:shape><![endif]--><!--[if !vml]--><!--[endif]-->
    If you've seen my other posts I also have a Ford flatty 337 that was going in the Dodge but I thought I'd keep it real with the Hemi and the Ford w/ Ford.:cool:
  2. Dreddybear
    Dreddybear
    Congrats. That motor's gonna rip it up. If you're going to run stock compression I'd go with 3x2. Looks killer and will be (a little) easier to tune then 6x2's. Of course Bass's coupe is bitchin with 4x2's....
  3. edgeabilly
    edgeabilly
    hEY MY KIDS LIVE IN aUSTIN.
    Maybe I'll see next year for the show. Yea I like 3x2 but my bro is running that on his 28 ford coupe aND HE'll think I'm coping so it must be else.:rolleyes:
  4. George
    George
    Depends if you're going for efficientcy or looks. A single 4 bl is best. 2X4, 2X2, 3X2, 4X2 will all work. Tunnel rams work best on the strip. 6X2 tends to be a pain.
  5. edgeabilly
    edgeabilly
    I like the 4x2 look.
  6. hemi35
    hemi35
    from Australia
    The cheapest & probably the most effecient is the hotheads single four but it depends on what look you are after. The multi carb intakes can really run away with your wallet but look the best.... jmo
  7. edgeabilly
    edgeabilly
    I don't mind the money just want to be cool:D
  8. crapshoot
    crapshoot
    or what about a blower with 6x2s nothing cooler than that!
  9. Stoner
    Stoner
    What year is your 331? Here's my '53 – even the longbells can work!
  10. I run Two - Fours on my 331, it's a '54 with '55 354 heads. It has an Edmunds 2x4 intake with Carter WCFB's and Hemi truck exhaust manifolds. Makes pretty good power.
    Johnnie.
  11. edgeabilly
    edgeabilly
    Also a 53 what tranny are you running?
  12. Dreddybear
    Dreddybear
    Wilcap has adapters for the extended blocks. Lotso different trannys
    http://wilcap.com/Hemi.html
    Pm me and I'll send you a bunch of good hemi sites.
  13. 4tford
    4tford
    Two fours were part of the hemi look.
  14. strombergs97
    strombergs97
    Hello..Street Rodder, April and May have a 331 build..good info..The intake is your choice...Should handle anything except a 6x2, all working..
    Duane..
  15. mortecai
    mortecai
    I think that two fours are easier to maintain and just look right homey on the top of a big Hemi!
  16. Mercmad
    Mercmad
    from Brisvegas
    331's had factory twin fours ( heavy cast iron manifolds) and there was even a factory twin four manifold in alloy .This was one I had on my own 331 ( 121mph in first on the salt..yes they do go ) it was designed for WCFB's ,which are too small in my opinion for a hemi to make real power. And they require a lot of expertise to make them run right.There were also two different carbs,a front one and a back one.
  17. edgeabilly
    edgeabilly
    I think I'll go 2x4.. It just looks cool:cool:
  18. I ran four Strombergs till this winter. She's got a 671 and two sixties Pontiac AFB's now. I ran mid thirteens with the Strombergs and got pretty fair mileage with the progressive linkage. Can't wait for the HAMB drags to see what the blower will do.
  19. edgeabilly
    edgeabilly
    You got to be kidding me!!!1 That blower is sick:D
  20. Thanks man. No matter what the rest of us tell you, build the engine your way.
    BTW If you were closer I'd be very tempted to buy that 337 from ya! That'd make and interesting HA/GR car.
  21. edgeabilly
    edgeabilly
    Yeah that 337's not for sale. Now that I've got the Hemi I'll take my time and build it and have fun with it who knows where it'll end up for now in a 34 coupe. Something like this
    http://i76.photobucket.com/albums/j4/GeeRam/Hot Rod Hayride 2007/P1000420.jpg
  22. wedgeii1
    wedgeii1
    from california
    If only I had a Hemi!!!!!!!
