what gearing should I run?
Discussion in 'The Hokey Ass Message Board' started by ACinSD, Mar 19, 2013.
  1. ACinSD
    ACinSD
    What gearing should I run in the rear? Relatively stock flathead 8 with T5 trans is the setup in a '31 Roadster. Rear tires are 7.50R16 = 31.5" tall. Let's hear the opinions. :confused: :D
  2. Jay Tyrrell
    Jay Tyrrell
    I run a tremec 5 speed with a .64 overdrive a 30 inch tall tires and a 4.44 gear in a nine inch rear end? Best of both worlds!
    Jay
  3. 1951Streamliner
    1951Streamliner
    from Reno, NV
    with my t-5 the 4.11s worked great.
    peppy around town and could cruise at 70 at 2.200rpms
  4. MATACONCEPTS
    MATACONCEPTS
    3.08 + T5 = 30+MPG
    My 327/4speed 68 chevelle moves great. Faster than most mustangs.
    when I blew up the 3.73 & went to 3.08 i was happy. I dont burn rubber in that car anymore tough it'll break parts, 245 Bf TA' 3200 pound car.
    Now a T5 has a better 3.27 first that will still spin even a 2.50 gear rear with those skinny no grip tires & 2000 pound roadster but It'll get like 35MPG!!!
  5. MATACONCEPTS
    MATACONCEPTS
    anything over 3.50 will be overkill
  6. ACinSD
    ACinSD
    My initial thought was somewhere between 3.00 to 3.50's.... I'll probably settle on 3.25's but thought I'd solicit some opinions.
  7. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Personally I think 3.73's are my favorite for a T-5.
  8. 57Custom300
    57Custom300
    from Arizona
    Running a 3.50 in my 57 Ford T5. Had a 4.11 in it for a while and it seems like 1st gear was done before I got thru the intersection. Im thinking a 3.25 would be better for my car.
  9. MATACONCEPTS
    MATACONCEPTS
    Ooohh, not particularlly on this car, it's weighs twice as much as a 31 roadster. T5s, well most stock 5 speeds are the weakest of the stickshifts. That car looks heavy, big gears like 4.11 take alot of stress out of the drivetrain, that's why BibBlock Chevelles came with 3.73, 4.11, & 4.56.
    3.50 would be the lowest i'd go with a 0.64 5th = a 2.24 final gear ratial.
  10. 4.11: 1 or deeper. 4.44 as has been mentioned or maybe even a 4.56 would get you real close to being perfect. The flathead is a low RPM engine but you don't want to be at idle on the highway either.
  11. 296 V8
    296 V8
    from Nor~Cal
    Lots of people w a V8 and T 5 are running 410 - 390 - 373 range
    Im going with 389’s in my 9”
  12. ACinSD
    ACinSD
    Thanks for the links and feedback guys.
  13. KidAgain
    KidAgain
    Nobody asked you want you want out of it? Smokin' all the way through 1st and 2nd or sipping gas? Ya kant have both. Pick on and go for it. Personally I like mpg if it's driven much, if not go for the smoke!
  14. GassersGarage
    GassersGarage
    With a 3.27 first gear and a .76 overdrive, I went with a 3:42 rear end gear. It was a BBC in a '65 Biscayne, Richmond 6 speed.
