Technical What fuses are these?
Discussion in 'The Hokey Ass Message Board' started by thebearded1!, Mar 16, 2019.
  1. thebearded1!
    thebearded1!
    from Maryland
    What do you call these fuses and where can you find them? 15527672428751533280325.jpg
  2. 28dreyer
    28dreyer
    from Minnesota
    Common German fuse used in early VW-s and other German cars and perhaps other European as well.
    3340, Mr48chev, thebearded1! and 2 others like this.
  3. maneri
    maneri
    from ohio
    nailed it (6 mins)
    tommyd likes this.
  4. Yep, European fuses. Used at various points by just about all of them. IIRC, the size range isn't quite as wide as the SAE fuses used here, but it's close.
    thebearded1! likes this.
  5. junkyardjeff
    junkyardjeff
    I have some if you need more,my mom had a couple VW beatles and still have fuses for them.
  6. G-son
    G-son
    from Sweden
    Bosch type fuse, seems to often be called torpedo fuse in english. Shouldn't be too hard to find.
    Don't really like them, bad connection against the fuse holder a bit too often.
    loudbang and RidgeRunner like this.
  7. Klusterfökken
  8. bigdog
    bigdog
    We've got them at O'reillys.
  9. TrailerTrashToo
    TrailerTrashToo
    I had them in 1960's Volvos. Occasionally spin the fuse a couple of turns in the holder, that brakes thru the corrosion that forms at the fuse ends.
    Long term solution is a partial re-wire using a late model fuse holder.
    thebearded1!, G-son and RidgeRunner like this.
  10. clem
    clem
    Just use a glass type fuse if you can’t find any.
  11. TrailerTrashToo
    TrailerTrashToo
    Glass fuses will not fit in the European style holder.
    54vicky and Dirty Dug like this.
  12. clem
    clem
    Ok. Thanks.
    My only experience with them is with tractors, and I don’t recall any problems.
    Maybe I was using the European type fuse in a glass holder type and not the other way around.
    My apologies.
    TrailerTrashToo likes this.
  13. gimpyshotrods
    gimpyshotrods
    There are glass fuses with torpedo ends.
  14. edwardlloyd
    edwardlloyd
    from Germany
  15. thebearded1!
    thebearded1!
    from Maryland
    Great thanks for all the replies guys! I'm probably going to look into just replacing the fuse block with one that holds the glass tubes or even blades.
  16. TrailerTrashToo
    TrailerTrashToo
    Thanks, my turn to learn something new.
  17. Halfdozen
    Halfdozen
    The fuse holder is two parallel tabs with holes in them, the pointed ends of the fuse fit into the holes in the tabs. This results in a very small contact area at both ends, problematic for high current six volt systems. As TrailerTrashToo said, you need to roll them in the holder regularly to maintain contact, just wait till the circuits have been off for a while as the fuse can get quite hot. I had lots of frustrating experience with these in '60's Volkswagens...
    VANDENPLAS likes this.
  18. stuart in mn
    stuart in mn
    They should be available at any auto parts store. Otherwise, harvest some from an older BMW, Mercedes, VW, etc. at the salvage yard.
  19. gimpyshotrods
    gimpyshotrods
    I used to have a few small drawers of these, back in my Porsche days.
    The "open air" style are still in regular production, and can be had online, for cheap, by the handful.
  20. Atwater Mike
    Atwater Mike
    In a 'pinch', some fellows have substituted 'rounds' from .22 long rifle.
    Watch your inseams and crotches... could get a real 'bang' outa that.
    RidgeRunner likes this.
  21. clem
    clem
    I personally would go with the blades, because as time goes on the older type will only get harder to find.
    Even though it’s not traditional.
  22. clem
    clem
    The ones pictured above with the torpedo ends were the more common ones down here ( New Zealand) before the blade type took over.
    Probably where the confusion comes into it.
    Our stuff back in the ‘60s - ‘70s was mostly European.
  23. Rich S.
    Rich S.
    Tip towards the firewall is preferable.
    clem and lothiandon1940 like this.
