Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. UNSHINED 2
    UNSHINED 2
    Responded to a local ad for 1940 Ford front and rear axles. When I got there, I got talking to the guy selling and he said he was upgrading his truck and I asked if he had anything else.....he says yes, that it was a real old build and had a '59 283 and Ford 3 speed. So I ended up with these goodies too, along with the toploader 3spd and axles. Axles had basically new brakes in them....
  2. flux capacitor
    flux capacitor
    Yes , we have a constant flow of his buddies coming over to check out the progress & learn too & we let join in on the fun. They’ll remember what they learn because they want too. I sincerely do appreciate the safety concern, the Pic I took was before we fired up the steam cleaner , next I placed old rims ,2 floor jacks & monster jack stand under the frame for backup before we laid on a foam mat staying outside but definitely not under it so if it moved it’d still be supported. Plus the steam cleaner bouncing hot crud in ones face stings. Sadly I’ve lost a fellow racer pal not long ago & had two car buddies suffer life altering injuries from jack stands that rolled forward thus pinning them under their hot rods. Jack stands scare me too. I grew up in a garage & machine shop & never take safety for granted. Now that it’s clean up on the lift it’ll go! Flux
  3. Lil32
    Lil32
    took coupe out for a battery charge before we fly to USA 31 May
    flux capacitor, Deuces and Stogy like this.
  4. Stogy
    Stogy
    Hey Lil32 are you and Hudson48 taking turns...:D
    May you have a majorly great time...;)
  5. Lil32
    Lil32
    Stogy
    Paul (Hudson 48) is a good friend of ours here in Brisbane
    Noel
  6. Hole sawed out a slug of nylon wear shoe, "turned" it on a drill press, inserted a 10-32 tapped brass tube, set screws, and a flattened brass screw to be a horn contact on the '35. Worked out good. '40 column with a smoothed bowl hooked to a 525 box, Jeep brush on a homemade copper shaft contact.
  7. oj
    oj
    chryslerfan55 and RICH B like this.
  8. Marty Strode
    Marty Strode
    OJ, I get an error code, without any video.
    chryslerfan55, Stogy and RICH B like this.
  9. TrailerTrashToo
    TrailerTrashToo
    Same here
  10. Pinstriper40
    Pinstriper40
    Chopped a '40 chevy coupe last weekend. I'll finish up the metalwork and cruise down to the dirt drags in Monte Vista, CO IMG_20190527_221339_489.jpg next weekend!
  11. oj
    oj
    Sorry guys, I'm not savvy enough to load the video. I think I'm getting a different version of it this afternoon and maybe I'll be able to post it.
  12. Dick Stevens
    Dick Stevens
    Post the video on youtube and then post the link on here!
  13. oj
    oj
    I don't have clue how to do that, remember I smashed my last laptop because I couldn't cut & paste. This one has been agreeable to a point, best not test it doing links and all.
    Maybe I can get the person who took the video to post it up.
  14. Stogy
    Stogy
    I'm not at all surprised...you fellas do get out and about in a big way...safe travels
  15. Mr.Racer
    Mr.Racer
    from Ohio
    Mocked up 2 blowers to go double whammy on the Studebaker and learned that it’s not for me. I had high hopes too....
    chryslerfan55, j-jock, Stogy and 8 others like this.
  16. UNSHINED 2
    UNSHINED 2
    Today I made a stand for painting doors.
    Man, those old trampoline frames you see sitting out on the curb for free come in handy. Only cost was the swim noodles and chain. $10 investment. Need to make another. I dont know how many tables and racks I've made from those things... 20190528_185131.jpg
    chryslerfan55, Lil32, RICH B and 6 others like this.
  17. rudestude
    rudestude
    Got one of the Studebakers ,the only one that had an engine in it, running. It had been sitting for several years , out side in the weather, it had already been converted to 12v so I charged up the battery and checked the fluids , had to replace one peice of rubber fuel line and blow out the rest put some gas down the carb , turned the key , nothing , ignition switch was broken replaced that ,again put gas down the carb turned the key and it fired sputtered then died did it again it fired blowing alot of smoke out the exhaust from what I put down the cylinders to crank it first with the plugs out, then it cleared out and idled down against the auto choke then down to its final notch and purred with 40# oil pressure even with the rotten ,stinky old gas that was in it ..
    My other Studebaker was the same way when I got it , it had been sitting for 19 to 20 years out side , I bought it from a family that was having a estate sale in 2 weeks I got the car home changed the fluids converted it to 12v cleaned the point's and plugs blew out the lines cranked it over 3rd hit it fired up and samething idled down and ran great even drove it back up to the farm on the day of the sale and let the family members look it it over took some for rides ,it was there dads car , and I drove it for six years , first year new water pump, and hoses , third year new plugs and a accelerator pump ,points and wires now it down and getting go fast goodies and suspension...but what is it with the old cars ? They can sit for along time and with a little cleaning usually start up and function, a friend of mine parked his 92 Chevy pu for 6 months and went to get it on the road again and the distributor had to be replaced it had all corroded up same with the throttle body most of the switches didn't work, I realize the newer stuff has more electronics but still every thing else just rots away..oh the clutch is stuck on the Stude so that's today's fix and then the drive.
    Notice the color of the gas on the bowl and it's running on that..I am draining it today and putting in fresh crap new gas, probably won't run now.. 20190517_191422.jpeg 20190527_185430.jpeg 20190527_185402.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    chryslerfan55 and UNSHINED 2 like this.
  18. mopacltd
    mopacltd
    Taking the wife in for surgery
  19. rudestude
    rudestude
    That is a really cool setup, I did one a couple years back it worked out pretty good, but I did have the instructions...and I do have a extra hood...no really that is cool hope you get it ironed out . 20190529_090525(0).jpeg
  20. Deuces
    Deuces
    I have that model kit... :confused::rolleyes:
  22. Mr.Racer
    Mr.Racer
    from Ohio
    It was really cool to finally see it and I wanted to try to replicate that model kit, but it’s just no good. With a couple small v-series blowers, the proportions might be ok but I’m not going that far. A friend stopped over with a showerhead Enderle after work and it looked way better with a single blower.
  23. rudestude
    rudestude
    Oh yes...that's it ,
    Damn and I just decided to sell this one , I just got it last week its someone's old Hot Rod , it's got a glass hood ,a dash and center panel full of gauges, the battery has been moved to the trunk over the right side of the rear end and its got a posi rear ,was set up for a 4spd , not sure of what engine it's got the stock mounts that have been redrilled a few times... 20190518_200855.jpeg 20190518_201046(0).jpeg 20190518_201012.jpeg 20190517_133102.jpeg 20190517_133048.jpeg 20190517_133032.jpeg
    chryslerfan55, j-jock, Stogy and 3 others like this.
  24. BLACK STUDE
    BLACK STUDE
    Installing a new radiator, new harmonic balancer, and a freaking diaper on the Stude so we can go drag racing this weekend. IMG_20190529_172513886_HDR.jpg IMG_20190529_172654965_HDR.jpg
  25. I finished up my impulse art project 20190528_150457.jpg 20190529_151450.jpg 20190529_211503.jpg
  26. Surprised when I got to the shop to find someone changed their mind and had the '33 frame powder coated red. Axle looked good in red, too, Mike said he spent 4 hours picking the baked on tape off the chrome, tho. Welded the centering rings in my backing plates, filled the extra holes too; but didn't get in the picture.
    IMG_20190529_110932 (Medium).jpg IMG_20190529_150312 (Medium).jpg IMG_20190529_132934 (Medium).jpg
    chryslerfan55, j-jock, Stogy and 5 others like this.
  27. rudestude
    rudestude
    Hope it's not serious, well I guess there's got to be some sort of seriousness or they wouldn't call it surgery...hope all goes well.
  28. mopacltd
    mopacltd
    Thank You so much. She is home this afternoon, but not all could be corrected and we will be returning after she recovers from this session
  29. The same thing I do almost every day. I took kids to da park. 20190530_134819.jpeg 20190530_095109.jpeg 20190529_110623.jpeg
    Sent from my SM-G920P using The H.A.M.B. mobile app
    Lil32, LAROKE, jnaki and 5 others like this.
