Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. ZZ Top Chop
    ZZ Top Chop
    I took the brake pedal mount off the Merc, made some pie cuts to change the angle. Kind of hard to tell, but it feels better. That was using flux core, on a Hobart Handler 210. "Can't see the lines, can you Russ"? 20200209_130309.jpeg 20200209_160646.jpeg 20200209_161917.jpeg
    Sent from my SM-A102U using The H.A.M.B. mobile app
  2. 62rebel
    62rebel
    I bought it through rockauto but it came from ACC. Better pricing than the other vendors selling the same product.
  3. ZZ Top Chop
    ZZ Top Chop
    Thanks, I'll be replacing mine in the next few weeks. Does your carpet have sewn edges, I don't have sill plates, I wonder if they do that
  4. 62rebel
    62rebel
    The back edge is bound, but the sides are not. You should get a pair of step plates to keep the door from shoving them up and in the car. Fit is pretty good.
  5. el Scotto
    el Scotto
    from Tracy, CA
    I’ve given up on trying to build it nice and just want to drive the stupid thing. Today was working on the brakes, messing with the column drop/angle of the dangle and fooling around with an accelerator pedal. I drilled, I tapped, I bolted and unbolted. Made progress at least.
  6. 65pacecar
    65pacecar
    from KY, AZ
    It sure looks nice and beautiful in that picture
  7. WB69
    WB69
    Cut down and burned a couple large, diseased and dying pine trees. Hate having to cut them down, but have no choice.
    osage orange and Lil32 like this.
  8. I hate body work so much and have such little patience with it, that I say to myself “the longer you work on it, the lower your standards go.
  9. LAROKE
    LAROKE
    From the BillyBob Shop Log
    February 10th 2020 Freed up my tranny jack from the gas tank sitting on it and got the Borg-Warner T5 Transmission out. I try to schedule the heavy lifting for the weekends 'cause, after twelve hours in the Krash Kubicle on the weekdays, I usually don't have the gumption to roll around on the floor and get greasy.
    The Jimmy 302 engine block and bellhousing will be the last major Item to exit the chassis. We are now basically down to bare bones. Most items now coming off the truck will be cleaned up and put right back on. We're movin' into a scraping and painting phase. Beer of the day was Fulton Brewery's Lonely Blonde American Blonde Ale.
  10. Rodsports
    Rodsports
    I sat here reading the HAMB in my undies and drinking port :)
  11. buzz4041
    buzz4041
    from Texas
    More primer sanding and tig welding practicing after an 8 hour day at work.
    osage orange likes this.
  12. Terrible80
    Terrible80
    Finally stabbed my OT LA 360. Wouldn't go in for nothing. Took it all apart to measure. Found clutch disc went on one way but hung up on flywheel side. Sanded with emery cloth , filed grooves , still pretty tight. Mind you this is 3rd try. So I hung the pressure plate on the bearing retainer where the t-o bearing rides, slipped the disc on and then stabbed the motor. Got the pp bolts in and stuck it the final half inch. Never did it like that before, but it worked!
    Sent from my LG-TP450 using The H.A.M.B. mobile app
  13. Continued on installing dropped spindles on the F-1 and mounted my
    'Year of Manufacture" plate. Hid the back-up camera under it, old age, can't turn and look back as easy. By the way, there's my led on a stick work light in the picture.
    osage orange and LAROKE like this.
  14. j hansen
    j hansen
    We got some paint on the Funny Car . Skärmavbild 2020-02-10 kl. 16.24.29.png
    swade41, Lil32, osage orange and 2 others like this.
  15. alanp561
    alanp561
    It sounds to me like frustration has set in. I think you should let me get it out of your sight so you won't have to fret about it anymore. As a humanitarian gesture and to show how sincere I am about relieving the tension you must have, I am willing to bring my trailer from Tennessee, load up this problem that's making your head hurt and haul it to my house. I'm even willing to pay
    for
    the gas both ways. ;)
    lothiandon1940 likes this.
  16. toml24
    toml24
    I will donate blood today at the Red Cross. This will be my 103rd donation in 41 years. Today will be a "Power Red" donation, meaning they take 2-pints of red blood cells and return the balance of the blood ingredients back to me.
    Also, my O+ blood is "CMV Negative", meaning my blood can be given to babies and children who have serious medical issues and need blood, and are too young to have the antibodies required to defend against CMV, a common virus in adults.
    Please donate blood.
    i.rant, Terrible80, swade41 and 8 others like this.
  17. You have a pass for the obligatory "pictures or it didn't happen" mantra.
  18. ^^^^^^thank goodness:D
  19. WB69
    WB69
    A lot of people THANK YOU!
    lothiandon1940 and osage orange like this.
  20. WB69
    WB69
    Ditto....
  21. Got my stick finished today. Third leg![​IMG][​IMG]
    Sent from my SM-A102U using Tapatalk
    MO_JUNK, 40two and Lil32 like this.
  22. toml24
    toml24
    I'll do this again in 112 days.
  23. N2hotrods
    N2hotrods
    Fabricated a metal top for the 29 Tudor and worked on the 30 tudor finished the wood platform behind the front seat. 7C35A17C-368C-4A03-A18D-8FE724F65F26.jpeg 59D9042B-5D7F-46C1-A160-3E410ADB506D.jpeg
  24. VNTGE41
    VNTGE41
    from l.a.
    Took the boy on a cruis3 to the dog park 86C7C6C8-CFCD-42AC-8052-3CE9A12AACF8.jpeg D9BA59F5-660F-425B-8018-05E8557AD561.jpeg
  25. Jalopy Joker
    Jalopy Joker
    went to Rancho Cordova, Ca with a couple of buddies to pick up a pair of custom louvered 20200210_104625.jpg 20200210_104628.jpg 20200210_104636.jpg panels - had a unique flathead, and more, sitting around shop - then to Sacramento Vintage Ford, at their new location
  26. Jalopy Joker
    Jalopy Joker
  27. I could not not buy these, so I did.
    swade41, Lil32 and impala4speed like this.
  28. Fiddled around with the '33; bent up a couple brake lines to run from the bulkhead giz I made up to the master cylinder; still don't care for that modern CuNi line. Figured out the electric panel is going to get pretty crowded; lotsa more crap to mount yet.
    LAROKE likes this.
  29. impala4speed
    impala4speed
    Need more people to do that Tom. I do the Power Red donation as well. Much prefer doing that rather than the regular donation. Can't give again until May 14th.
  30. toml24
    toml24
    Thank you for your comments Denny. Great to hear from a fellow Power Red donor. My next day is June 1st.
    We need to try to get a HAMB blood drive going. Members would go to the Red Cross donation center near their own community and report the results here. That would be a very cool and noble thing to do.
    impala4speed likes this.
