Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. Today’s mission is to move the wood burner and get this last bay done. There’s a lot of work in the gables.
    After the new year I’ll start the final and finish work on the boiler room, boiler and radiant floor heat.
    The wood/oil burner with heat exchanger and man oh man really really kicks out the heat. Last winter in the sub zero bitter cold I slapped and slammed it together with the goal of getting it going as fast as possible then I had every intention of finishing it off nice. The problem is you can’t work on it when it’s running and there’s a million other things more important when it’s warm and you don’t need it running.
    069ECA48-5F80-44F5-8702-67F40F621897.jpeg 166C3D3E-FB42-477F-96BB-AF299B2E8723.jpeg A04468D5-32B6-4D2A-B5F0-CFA3CA18024A.jpeg 94A8736D-6BC4-4B93-803D-8D3B039A1886.jpeg 8FCCE3FE-24AB-48C2-8E93-EC17553DFCBA.jpeg
  2. UNSHINED 2
    UNSHINED 2
    I am at work now, but this morning I took delivery of this new to me project. If all pans out, this may get a build thread. Believe me it wont be what you're expecting.
  3. Did not get a lot done with the holiday coming up. Removed the track bar from the coups rear, installed new joints and polished the bar to a near mirror finish. Worked on my ladder bar plan a little. My hands are beat to hell from working on customers OT rotten junk. I have been replacing brake lines on cars and trucks for weeks. Everybody has rotted brake lines.:mad:
  4. ERguitar
    ERguitar
  5. Which one, butt, nipples, side boob or Army girl boobs ??? Or the Henry J ?
  6. UNSHINED 2
    UNSHINED 2
    The Army, side boob nipple, girl butt one...
  7. Mostly chased after the ignition problems on a 305 chev engine. should of looked at the ignition long ago instead of blaming the carb and crappy corn gas. But I eventually got it fixed. I need to use that truck to go and cut up and haul home the Spartan trailer I bought a month ago. Its winter time and it has a good heater.
  8. Side boob, keep that one send me side boob
    Sent from my SM-A102U using Tapatalk
  9. WTF really
    WTF really
    Got some POR15 put on all the wheel wells and floors 20191222_163534.jpg 20191222_163509.jpg
    chubbie, woodsnwater, Lil32 and 3 others like this.
  10. Finished making a little bulkhead deal to run the brake lines from the 90 degree under-dash master out thru the firewall. Figured it would be easier; last couple cars like this were kinda of a hassle running the lines up thru the firewall then bending and flaring in place.
    Tim, woodsnwater, Lil32 and 5 others like this.
  11. The37Kid
    The37Kid
    Another birthday, threw in the towel on the '29 Steelback project. Going to finish the two cars I have that don't need wiring. "Smart man knows his limitations" Bob
    stillrunners and osage orange like this.
  12. LAROKE
    LAROKE
    Still working on my '37 Chevy pickup rebuild.
    December 23rd 2019 All the hinge leaf screws were small but stubborn. I was successful at getting the driver side upper hinge cab side screws out with manual impact driver but none of the others would bust loose. I also tried MAP gas, Kroil penetrating oil and air-powered impact wrench, all to no avail. I got the driver side lower hinge leaf door side screws loose but they had hex nuts inside the door and I had to take off the inner door panel to get at those. I finally got the door off with the upper hinge still on the door and the lower hinge still on the cab.
    Went to the passenger side door and found more of the same despair. Then, palm slap to the forehead! I'm overthinking things again. I was doing things here the way I did when I took BillyBob's doors off but Billybob has concealed hinges. Deerslayer's doors have exterior hinges. All I have to do is drive the hinge pins out with a punch! I did and the passenger side door was off in five minutes instead of the hours long ordeal of the driver side door.
    Damnation! Some days the bear gets you and some days, you iz the bear. Beer of the day was Southern Barrel Brewing Company's Damn Yankee IPA.
  13. Black_Sheep
    Black_Sheep
    Got the front axle welded up, added steering arms and built a tie rod on the Tot Rod. Steering column and drag link are next... image.jpg image.jpg
  14. Caprice89
    Caprice89
    Cleaned the OT daily Throttle Body; it idled a bit rough.
    Cleaned the shop, sorted some parts and found the Rochester single barrel carb that came with my Mustang 22 years ago. Needless to say it ran terribly.
    Sent from my online shouting device
  15. Made the S10 tailshaft housing fit my Ford WC 1999 T5 transmission.Wouldnt go on by 3/8 of an inch.I have the reverse brake tab on mine.I measured the housing depth on the Mustang so I knew how much to remove from the surface behind 5th gear which is a stepped ring area."milled" the area down with a Dremel to correct Mustang depth.Using the Dremel I cut a new notch to the left of 12 oclock on the outer edge of the ring for the brake tab to rest against.Test fit housing...….slide right on.
    osage orange likes this.
  16. The turn signals and brake lights on my wrecker worked in conjunction. the brake lights and turn signals both used the bright side of the bulbs. Today I cut the wires and separated those two functions. added 4 lights to my wrecker and two more to my light bar that I use on whatever is being towed. Ran a wire direct from the brake light switch to those extra lights bright side and wired the dim side of that bulb to the tail lights. I now have 4 tail lights and 4 brake lights on rear of the wrecker and two brake lights and tail lights on top of the headache rack. two rear turn signals on the truck and two turn signals on the light bar. And front turn signals and park lights on the wrecker.
    Boneyard51 and Truckdoctor Andy like this.
  17. WTF really
    WTF really
    Body is completely stripped. Epoxy sealer tomorrow. 20191223_162808.jpg 20191223_162544.jpg 20191223_162525.jpg
    chubbie, 40two, Black_Sheep and 11 others like this.
  18. Happy Birthday Bob!!! I did an R&R on a 49 windshield and back glass to replace the rubber. Pain in the ass!!! 20191104_144252.jpg
    40two, Jalopy Joker, LAROKE and 4 others like this.
  19. Helped load a couple of 40's Jeeps I sold that are off to a new owner and looking around the shop for a good QuadJet to replace a good Edelbrock/Carter on the 454......
  20. Not much done today; but did get the little brake line bulkhead deal from my earlier post mounted; worked out as planned (for a change) right next to the hole for the lighting wires.
    Found another high quality Vintique product that won't work for us. Their door lock does not accommodate the angularity needed in the '33 door. Dug out my Drake lock when I got home, no comparison, it should work in the '33 easily.
    Lil32, David Gersic and UNSHINED 2 like this.
  21. UNSHINED 2
    UNSHINED 2
    Had a great time today unloading the 61 Olds with all 4 tires flat and brakes locked up! Didn't know that because the car was loaded with a forklift.
    Max Gearhead, MMM1693 and Lil32 like this.
  22. LAROKE
    LAROKE
    A little further along with my '37 Chevy teardown
    December 24th 2019 While I was pondering the problems of clutch and brake pedal, and other obstructions blocking cab removal, I went to work on items that were relatively easy. The rear fenders gave me some trouble in the form of a few rusted bolts I had to grind off. Otherwise, the fenders and running boards came away easier than I expected. The running board supports are bolted in place, not riveted like BillyBob, so those "shin killers" will be removed too.
    lothiandon1940 and Lil32 like this.
  23. jimmy six
    jimmy six
    Climbed up and got the Clifford 3-2 manifold and carbs that set our early Land Speed records and set the carbs on the Howard. I’m looking at some work for progressive linkage and I’ll need some 5/16” flare fittings for the bowls. Took them off in 1975 and will never find them in all my storage. Still a ways to go but the Jimmy is starting to look like something that might run pretty good. Now I’ve to dig in my stash for the Nicson cast iron headers.
    Clifford in the background. B6758FC5-7F2F-4F9D-A638-7A212D0BF540.jpeg 9BBB03CB-8C14-4D58-BC0A-E5375F63BD88.jpeg
    lothiandon1940, 40two, LAROKE and 3 others like this.
  24. trollst
    trollst
    Got up at 3:30 am, at work by 4:45, loaded snow into waiting dump trucks till 11, stuffed those buggers till another flake wouldn't fit, 42 loads total. Not bad for a retired 65 year old, still got what it takes. Then, got a free breakfast out of it too. Gotta do it all again next friday, we got a dump of snow from hell, more snow in 24 hr than we get all winter, and still three more snow months to go. DSC07526.JPG DSC07532.JPG
  25. Turnipseed
    Turnipseed
    The wife and I drove the T-bucket to deliver loaves of home-made banana nut bread to some of our friends. No pictures, but it a beautiful, sunny 65 degrees here in south Texas. Merry Christmas to all!
    osage orange, Hamtown Al and Lil32 like this.
  26. WTF really
    WTF really
    Got the sealer primer on today. Filler primer tomorrow. 20191224_171148.jpg 20191224_155950.jpg 20191224_160002.jpg
  27. glrbird
    glrbird
  28. David Gersic
    David Gersic
    from DeKalb, IL
    Turned some 22 ga sheet metal in to scrap, practicing butt welding. Got better at it. Still not great.
    Made several of these prototypes:
    The first several were pretty nasty looking. This one came out pretty good.
    JOYFLEA, 40two, 61Cruiser and 3 others like this.
  29. shortypu
    shortypu
    Been putting my 31 chassis back together and today it became a roller. IMG_1795.JPG IMG_1831.JPG IMG_1836.JPG IMG_1845.JPG IMG_1848.JPG IMG_1849.JPG
    JOYFLEA, 40two, LAROKE and 8 others like this.
