What causes cowl shake
Discussion in 'The Hokey Ass Message Board' started by RDAH, Jul 11, 2012.
  1. RDAH
    RDAH
    from NL, WI
    Yes I did a search, but here's the deal. "27 Speedway kit I put together 2.5 years ago & now have 900 miles on it & why now is it shaking ? When I built it I put 60 feet of 1" square tubing around the doors, cowl & all the way to the back. Front end has 7* of caster & 1/16" of toe. This shake mostly happens at around 60 mph. Everything under the car still seems tight. Any remedies would be appreciated.
  2. Greaser Bob
    Greaser Bob
    Funny how a lot wheel problems seem to happen from 55-65. Are you all balanced when it comes to tires? Could be a simple fix:)
  3. Terrible Tom
    Terrible Tom
    Yup, had a similar problem and it turned out that a front wheel was slightly bent. You might try swapping wheels and see what happens.
    Tom
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    most dont call it "Cowl shake"..so if you have been looking it up or searching it on this site using that wording..thats why you havent found it
    search death wobble or front end shake
    advice....check to see if you have any play in any of your front end components..tie rods , perches, steering box., king pins..etc..
    than check wheel runout..and balance of the tires..also roundness of the tires if they are bias
  5. Ole don
    Ole don
    You said you put in steel tube, is it glassed to the body pannels? I built three cars with glass bodies, I glassed wood in. I used 3/4 inch plywood to reinforce the firewall, then 3/4 poplar around the doors and the back, and 5/8 or 3/4 marine grade plywood for a floor. Double glassed in all the way around. The bodies get heavy, but solid. Wood and fiberglass have nearly the same coeficient of heat expansion, steel grows more.
  6. monc440
    monc440
    A steering dampner will help. We have had a couple A's that we couldn't find the problem, tires & rims good, king pins good, tie rods good, gear box good, just couln't find it. put in a dampner and 10,000 miles later still no shake and no failures.
  7. flatoutflyin
    flatoutflyin
    What type tires are you using? My severe 55 MPH cowl shake was directly related to out of round bias-ply tires. I tried a dampener, balancing, various tire pressures. I trued my tires and fixed the problem. That's me, camera in one hand, at 70 MPH.
  8. I know that it is only 900 miles but in 900 miles even short jaunts a lot of things can happen. I think if it were mine I would start crawling around and tightening and looking for things that may be cracked.
    That is the first thing I would do anyway.
