Hot Rods What are these wheels for?
Discussion in 'The Hokey Ass Message Board' started by 8-Track, Sep 3, 2017.
  1. 8-Track
    8-Track
    I have 4 of these wheels not sure what year Ford they are for? DSC06121.JPG DSC06122.JPG DSC06123.JPG
  2. Budget36
    Budget36
    Those trim rings look real nice
  3. bowie
    bowie
    I'm thinkn' 40's Lincoln? Edit: Totally missed the untapered squared off inner rim surface. The add on clips threw me...agree they are later pickup wheels.
  4. flatford39
    flatford39
    If they are 15" they may be Mercury.
  5. rustythumb
    rustythumb
    look like 70's & 80's ford pick-up!
    302GMC and Hnstray like this.
  6. jcmarz
    jcmarz
    from Chino, Ca
  7. Winner..... Those are disc brake wheels, may be as early as late 60s but definitely 70s/80s, even into the 90s on the strippers.
  8. redo32
    redo32
    1965 Ford pickup that somebody added the clips.
  9. 8-Track
    8-Track
    The wheels have a ford logo stamped in them. I thought they were from a 40s truck. they are 15 inch x 7
  10. BenD
    BenD
    Alliance Member
    70s F-100 pickup wheels
    Hnstray likes this.
  11. Hnstray
    Hnstray
    from Quincy, IL
    The four hub cap retaining bumps (vs three) are a dead giveaway as to them being, as said, later model Ford pickup wheels. The trim rings are from the same application and era, only the red paint in the grooves is missing.
    Ray
  12. 302GMC
    302GMC
    from Idaho
    Looks like they had '39 Ford caps ???
  13. manyolcars
    manyolcars
    That bolt pattern fits most Fords from 1928 to about 1994? except 36-39 and not passenger cars after 1948 except Lincolns in the 1950s. thats worded bad. maybe someone can clean up what I said
  14. Ford kept the 5-on-5.5 bolt pattern all the way to 2000 on F100/F150 trucks (except for the very last F100 in '83 which had 5-on-4.5) and their derivatives (Bronco, not the Bronco 2), as well as many of the lighter-duty E series vans. As noted, there was a break in '36-39 for the 'wide five' wheels, then in '49 it disappeared permanently from Ford passenger car use (except for some early '50s Mercs and Lincolns).
    Hnstray likes this.
  15. Chiss
    Chiss
    from S.C.
    As mentioned above, Wheels are late 60's up. the Hubcap Nub's is on the outside of the ring, Earlier rims have the nub inside.
