Projects What!!? another 27 on 32 chassis!??. Scratch build body.
Discussion in 'Traditional Hot Rods' started by Mindover, Jun 5, 2011.
  1. GizmoJoe
    GizmoJoe
    " but be careful in how you fill it up........"
    Ahhh.. there's the problem.
    I keep looking at all the "stuff" I should have in garages and realize I would need more space than I could afford.
    Now if I only had helpers as you do. You are blessed.
    One question: what is that item in the foreground of that picture?
    It looks like a power cord is going to it.
    Joe
  2. Mark Fox
    Mark Fox
    Hi David. Can you knock a hole in the wall,to join the two workshops together?
    To save you running from one to the other, in winter.
  3. Mindover
    Mindover
    from England
    Hi Joe, Yep my girls are great and they worked like troopers on some of the hottest days we have had. The Oldest has just finished university where she gained a first class honors degree. The younger one is on summer break from college.
    The thing in the foreground is a garden blower, I used it to clear years of dust from the walls and floor. I blow my workshop through with it every now and then to keep the dust down.
    David
    Hi Mark, the landlord is OK with me knocking through but I can't afford to do it just yet. This is part of the building to the left of my main door as you face it, so if you remember from when you were here I will have to cut a hole in the wall where I have my wheeling machines and pullmaxes.
    The space is not as large as it looks it is about 800 square foot and I have two container units with stuff in that I am giving up and that stuff will have to come in to the new space. I will be able to spread out that is the main thing. I will also be able to get my hot rod in which is in one of the containers at the moment.
    David
  4. Okie Pete
    Okie Pete
    See if you can add a second floor . It looks tall enough .
    Good for you to get a larger shop. Keep your Girls busy maybe it will keep their minds off hairy legged boys or a well placed loaded bear traps :rolleyes:
  5. snopeks garage
    snopeks garage
    from macomb MI
    Where can I but one of these? That things awesome
  6. Mark Fox
    Mark Fox
    David. It will take a bit of planning, where to put your tools. When I said knock a hole in the wall. I forgot how much machinery you have in there. But having the extra space, will be fantastic .
  7. Mindover
    Mindover
    from England
    Sneaked into the office to get a drink ( sweating like a pig from running up and down the ladder) and saw your question here is a link for one in the 'states but google plasma circle cutting attachment and you will find quite a few links...
    http://www.usaweld.com/Circle-Cutting-Attachement-p/circle-cutting-parent.htm
    David
  8. Mindover
    Mindover
    from England
    Hi Pete, the problem with that is we have to pay rates (property tax) for all floor space, I am stretching myself taking this on. I can build large racking though.
    Hi Mark, I intend to leave my wheeling machines and Pullmaxes where they are but cut a four foot wide door. I intend to make a woodwork shop in the new area.
    I want to keep to the same amount of vehicles I have in now so I have more room to work.
    David
  9. GizmoJoe
    GizmoJoe
    Wow... wood work shop, large racking AND put your T in there to work on....
    Starting to sound crowded. ;)
    Would you have to pay more taxes if you built a rack-type "second level" that was removable?
    Toss up a ladder and you could store a lot and still have head room.
    Here I am giving you suggestions when you clearly have a plan. Sorry. ;)
  10. Congrats on the extra elbow room!
  11. Mindover
    Mindover
    from England
    As far as I understand it if you can walk on it you pay rates.
    David
  12. Mindover
    Mindover
    from England
    Cheers Mark.
    David
  13. snopeks garage
    snopeks garage
    from macomb MI
  14. Mindover
    Mindover
    from England
    You are welcome.
    David
  15. The new space looks like it will be great David! Always nice to have some extra room to move around.
  16. Mindover
    Mindover
    from England
    Thank you, space costs a lot here because we live on an overcrowded little island. I intend to do some metalshaping classes to offset some of the cost.
    David
  17. GizmoJoe
    GizmoJoe
    Ahhhh if I could only take those classes. Sigh...
    I've been studying and practicing gas welding panels using the method that you show in your DVD. Brilliant!
    I have to patch my A truck panels but I'm afraid to do the deed for fear of warping like when I used to do this with a filler rod.
    I hope you get back on this project soon but thanks for keeping it going until then.
    Joe
  18. Hi David, I always read your posts with interest. That is great that you are getting more space! Are you planning to start building the wooden framework for customer's cars? I know you have been displeased with the frames you have been supplied with. I'll bet the girls are having a good time working with you, that will make good memories.
    I have meant to tell you, my youngest daughter gave me your DVD for Christmas. I learned a few things from it that helped with a project I assisted a friend with. Lots of good tips.
    Keep posting, we'll keep reading!
    ~Alden
  19. Mindover
    Mindover
    from England
    Hi Alden,
    You are right I have had a lot of problems with ash frames built by other people. We have to do a lot of woodwork at times so I need to have my bandsaw and other machines so I can use them without having to shift stuff all the time.
    I am glad you have found the information on the DVD so helpful, thanks for your kind comments.
    David
  20. Mindover
    Mindover
    from England
    Still trying to sort out the extra workshop space that I took on, have not had time to paint the floor but I did one area and moved my T in, or at least the chassis and flathead. its so good to have it in the workshop instead of the container I had it in. I will be able to start working on it again soon. Just got to catch up with some customer work and paint the rest of the floor first.
    David
  21. Looking good....
  22. Mindover
    Mindover
    from England
    Thanks Bob, I am sorting out the parts for the T including the panels I have made now and still trying to get the new space ready to use. Back on it very soon.
    David
  23. David, that is great that you now have room for your car in the shop. It will be much easier to make progress.
    I am looking forward to seeing it come together. I am always intrigued by metal shaping, and you make it look easy. Every post of the work you guys do is interesting!
    Keep plugging away.
    ~Alden
  24. bambbrose
    bambbrose
    from So. Utah
    Just bought your DVD after reading this thread. Amazing workmanship. I'm looking forward to learning. I'm building a 27 roadster as well, but not from scratch!
  25. Mindover
    Mindover
    from England
    Thanks Alden, Like most skills once you understand a few principals it becomes easier. I have been working on the panels I made earlier to finsihe them off becaiuse I never quite finished any of them. I will have some more photos soon.
    I hope you like the DVD, let me know how you get on. Let know when you start a thread on your build.
    David
    David
  26. fleet-master
    fleet-master
    ....theres NEVER enough room Dave....:D:D:p
  27. Mindover
    Mindover
    from England
    Why has this thread been relegated to traditionally styled hot rods? It has a flathead, toploader trans, 32 chassis, banjo rear axle, torque tube, dropped original model A axle. Forties Ford brakes, ford wire wheels, I am building an exact copy of a '27 T body. It's totally traditional period perfect hot rod.
    David
  28. I agree ... PM one of the mods and see whats up.
  29. Mindover
    Mindover
    from England
    I don't know how to find the mods. I thought about sending Ryan a pm but I don't want to pester him.
    David
  30. austinhunt
    austinhunt
    Absolutely traditional. There is a ton of threads that are all in the wrong areas. They can't read em all so just let them know.
    by the way, I'm really curious just how you curved the frame rails up for the rear axle!?
