Customs What adhesive for lexan wing windows into steel frames?
Discussion in 'The Hokey Ass Message Board' started by ArtGeco, Jul 17, 2018.
  1. ArtGeco
    ArtGeco
    from Miami
    What adhesive for lexan wing windows going into steel frames?
    I searched and couldn't find anything and I'd prefer locally
    sourced options if possible. I'm kinda under a tight deadline.
    Thanks in advance.
    -Terry
  2. Mr48chev
    If it is the same thickness as the glass would be I'd think using the same glass setting tape you would use with glass.
    From experience, Lexan will look like hell after a while if you are not damned carefull with it. A lot o NO toucha da plastic windows, is required as it scratches real easy. I ran clear Lexan in my 48 side windows for years and it scratched and marked up too easily. Didn't break when some asshole threw a rock at it though.
  3. woodiewagon46
    woodiewagon46
    from New York
    I would think clear silicon would work.
    F&J likes this.
  4. 38-39 ford truck lover
    from duluth,mn
    sika-flex , Fastenal catalog should have the info
  5. F&J
    F&J
    A young guy at the local glass place talked me into letting him use black silicone on my W/S and side glass frames..
    It looks perfect to me. He did offer clear or white, but really pushed the black because it looks like black rubber seals.
    he made some "spacers" he said, those were to keep the glass centered in each frame...because the channel is wider than the glass.
  6. chargin03
    chargin03
    If I was going to use silicon it would be black so mildew would not show.
