Hot Rods Were quick changes used in drag racing?
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Oct 3, 2017.
  1. JimSibley
    JimSibley
    i am wondering if quick change rear ends were used in the early days of dragsters?
  2. jimmy six
    jimmy six
    Yes, especially with flatheads. I bought a complete narrowed one with a spool and the brass adjustable steady rest for the ring gear. Bought it in 81 and used it at Bonneville and the lakes. It had solid mounts welded and 50 Merc narrowed axles and drum brakes.
    Deuces, oldsroller, rjones35 and 2 others like this.
  3. JimSibley
    JimSibley
    I'm wanting to build a vintage style car, either a flathead or a 6 cylinder , about 110 inch wheel base and I have a nice quick change.
    Deuces likes this.
  4. mohead1
    mohead1
    You will be fine, not enough torque to shock load it and break it.....would certainly look at any upgrades avail to keep it alive
    Sent from my SM-G900V using Tapatalk
    Deuces likes this.
  5. Mike VV
    Mike VV
    from SoCal
    A simple look into old car photos and you see MANY drag racers with quick change axles in them. From flat head powered cars to blown Chrysler Hemi powered cars.
    Remembering the rear tire advancement of the time...
    Mike
  6. dreracecar
    dreracecar
    from so-cal
    Most QC were designed for rolling starts and not instant launches. They could get away with it back then because tires were hard, no traction to speak of, and the lack of serious horsepower we have today, but they still come apart and a containment shield was a must even back then. Todays tires and track prep (even with low hp) makes the use of a QC a bad choice if one plans to run it on a strip. The one we used in the IVO repop was broken and re-welded, but no interest in making a pass with it. upload_2017-10-3_8-3-43.jpeg
    Deuces, Blues4U, Hombre and 4 others like this.
  7. When I was Racing from 63-74 we Did Not use them especially from69-
    to early 75 put out High Horsepower, running Ripple wall Slicks ( Goodyear )
    I used to Come out of the Hole at 8500 rpm. & Shift at 8500, BBC
    Just my 3.5 cents
    Live Learn & Die a Fool
  8. Wheel Hop is the big enemy of a quick change.
    I would suggest a Champ or 201 style quick change far more rugged then the V8.
    The Champ is more common is oval track racing, but not unheard of in drag racing.
    This is mine with V8 adapter plates to run early Ford side bells.
    [​IMG] [​IMG] [​IMG]
    Deuces and chryslerfan55 like this.
  9. Ivo's four engine dragster has a Champ in the front.
  10. southcross2631
    southcross2631
    Try it, break it . Repeat as needed. Yes they were used in the early days of poor track prep and hard slicks. Drove a K-88 flathead digger with a quick change in the mid 60's, but probably only had 275 hp.
    rod1, Deuces and chryslerfan55 like this.
  11. mohead1
    mohead1
    Look at Ivos in that pic, highly modified, floater axles,ade specifically for the use. Regular old QC will break under a shock load....old cars.had no traction technology like modern day tire compounds, track compounds/chemicals,.etc
    Deuces likes this.
  12. That is the Champ rear not the V8.
    I will be running this set up with 12 spline 3/4 ton Ford truck axles in my rear.
    This was a very common stockcar set up, however I have seen it in some vintage drag cars.
  13. pnevells
    pnevells
    Champ rear in my gas dragster in 1978
  14. Boss 302 Mustang
    Boss 302 Mustang
    from Duxbury MA
    Didn't they run the champ rears in funny cars for a spell in the early 70s?
    Deuces and Gary Reynolds like this.
  15. mohead1
    mohead1
    Load it up, and run it...break it, fix it....wats the big deal.
    wrenchbender likes this.
  16. southcross2631
    southcross2631
    If you break it at least you will look cool doing it. Anybody can break a 9 inch Ford or a Dana 60, but not everybody can look as cool as you when the track crew is sweeping up your parts and gear oil.
    Go for it !
  17. mohead1
    mohead1
    Love the smell of gear oil all over the starting line in the morning
    Deuces likes this.
  18. JimSibley
    JimSibley
    If I run it, I will be using less than 300 hp, and a 3000 rpm stall on a foot brake.
  19. mohead1
    mohead1
    Like i said awhile back, low horse pressure, u will be fine. U get up in the 500+ range w big sticky tires...gonna be some life expectancy issues in a shock load situation
  20. Yes
    Deuces likes this.
  21. YeP. It was THE thing for a while, didn't last too long though.Not sure why they ran them or why they stopped running them. drag racing was always monkey see, monkey do.
  22. Gman0046
    Gman0046
    No one I knew ever actually used a quick change at the track. I'll bet you 99.9% are used for looks only.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I've often wondered what was the purpose of having a quick change in a drag car? Nearly all strips are / were 1/4 or 1/8 mile. Did anybody change gears to run 1/8 vs 1/4? Now days buddies who have tried optimizing for one strip length or the other only see about 1/10 of a second difference in the 1/8 mile time. Of course most cars now have hi-stall converters so I suppose it matters less now than when hi-stall converters were not de rigueur. (I run 4.30 for both 1/4 and 1/8 mile bracket racing. Its not worth the hassle to change over to gain a tenth.)
    Deuces likes this.
  24. pnevells
    pnevells
    The champ rear in my dragster came out of a BB/FC
    Sent from my SM-G920V using The H.A.M.B. mobile app
    Deuces likes this.
  25. Damn straight QC's were used in drag cars!
    Deuces, jnaki, Speedwrench and 2 others like this.
  26. 0ldracer
    0ldracer
    Ditto to what Dean Lowe said^^^^
    rod1, Deuces and Dean Lowe like this.
  27. NHRA outlawed them in the Gas classes by about '64. They were the cats ass for a street legal car like Gas coupe/sedan. Drive it to the strip change gears and race, change the gears again and drive it home.
    Deuces likes this.
  28. dreracecar
    dreracecar
    from so-cal
    Any questions?????
    Deuces, Blues4U and pnevells like this.
  29. We did that same thing at the '63 Winternationals. Almost hit Bob Beezer. He didn't dance directly behind cars on the line anymore! It was the third broken V8 Halibrand. Then we switched to a Champ QC, and no more rear end problems.
    Deuces and jnaki like this.
