Customs weld rear fenders
Discussion in 'The Hokey Ass Message Board' started by 4ford, Jun 6, 2020.
  1. 4ford
    4ford
    from Eagan. Mn
    20200606_152221_resized.jpg 20200606_152238_resized.jpg Hi just wanting to know if any of you body guys would share and or give your 2cents worth on welding rear fenders on this 1941 ford. as you can see in one of the pictures its a little ways away from the body how would you fill? please give me some ideas. after I weld what kind of filler is best?
  2. flamedabone
    flamedabone
    Have you put the rest of the bolts in the fender to see how much it pulls together?
    -Abone.
  3. squirrel
    If you were able to make the fender and body fit each other as designed, would you still be interested in how to weld them together? I'm wondering why you asked about this, because welding fenders to the body on old cars usually results in a big mess.
  4. redo32
    redo32
    After getting the fit as tight as possible, cut a strip of metal 1"-2" wide depending on how tight a radius you want. Bridge the gap and tack and shape the filler piece.
    Finish welding and grinding then bondo with your favorite mud.
  5. Your car. Sheet metal, tin snips, weld.
  6. redo32
    redo32
    I did a search to find a good thread that would show you how to do this. Guess what I found? You asked this same question 6 months ago and got a couple of good references to illustrate how do this. So you're sitting around with cabin fever and bored?
    flatford39 and Casey Riley like this.
  7. The37Kid
    The37Kid
    FIRST, remove the Bondo off all areas you plan to weld, then post the photos. Bob
    49ratfink likes this.
  8. 4ford
    4ford
    from Eagan. Mn
    ha ha yes I must be going nuts sitting around...…..so then the question goes out in the bottom corner left as the picture shows the gap its rather large and the fenders are NOS so should I try and shape the fender to fit the body better and bolt the fenders on maybe massage them a little more
    VANDENPLAS likes this.
  9. flatford39
    flatford39
    Yes....do that before you start f$%&*%#$% welding on them.
    XXL__ likes this.
  10. 4ford
    4ford
    from Eagan. Mn
    I will a lot of guys say not to weld the fenders on the fender welting will cover some of the gaps up on it. cant go to any shows they have canceled them all :(
  11. squirrel
    If the fenders are NOS then perhaps the body is not shaped as it should be. Which is pretty common...and not too easy to fix, usually.
    Welding metal over the gap is one way to "fix" it, but not the way I would choose.
  12. evintho
    evintho
    As already stated, put the rest of the bolts in the fender, loosen them all, adjust the fender then tighten them down. I'll bet that'll get you where you need to be!
    flatford39 and squirrel like this.
  13. 4ford
    4ford
    from Eagan. Mn
    squirrel....how would you go about it??
  14. squirrel
    Start by bolting the fenders on tightly, and do what adjusting you can to get them to fit as well as they can. If there are still gaps, then inspect the body, to see if it needs some massaging to get the shape to match the fender. If the area has been worked on before, which it looks like it has, it might be necessary to strip to bare metal and move the metal around as needed to get a good fit, then use filler to finish the contour of the body.
    I don't know what your body work skill level is...mine is fair to midland, I can usually get panels to fit pretty well, but not perfect. Fortunately, my tolerance for panel fit isn't too far above my skill level, so it all works out.
    razoo lew and 57 Fargo like this.
  15. 4ford
    4ford
    from Eagan. Mn
    thank you for your ideas
  16. 49ratfink
    49ratfink
    NOS has nothing at all to do with the condition. just that they were never put on a car.
    X38 and The37Kid like this.
  17. Budget36
    Budget36
    Little work on the fender lip where it bolts to and a little work on the panel, should be all you need, i/e if needed, don't be afraid to do some bending on the fender lip to tuck the fender flush...assuming the panel is straight.
    squirrel likes this.
  18. 4ford
    4ford
    from Eagan. Mn
    your right about NOS just means at least you have a good start. may have to bend up the lips or mounting holes a bit to get fit better but I believe that the fender welting will cover up a lot also.
    thanks for the suggestions and if there are more please don't hesitate!! to add them. everyone has a different idea!
  19. goldmountain
    goldmountain
    I don't think welding on the fenders is a good idea but if you must, here is how the Ayala brothers did it. From the Rodder's Journal #39. Scan-200608-0002.jpg
  20. silent rick
    silent rick
    previous owner welded all four of the fenders on this car. plans called for molding in the rear like the ayala brothers in the above post, the formed strips of metal method.
  21. Also make sure your hood and grill fit right.
  22. 1946caddy
    1946caddy
    from washington
    What does the body look like on the other side? Get a cardboard template of the other side if it looks OK and compare sides to see if the body matches. My first step would be to get both sides to match and then look at working on the fender. If you still have a gap, you could split the fender about a inch from the edge and then get the fender aligned and weld in the patch.
