I bought a rebuilt flathead with under 1k miles on it out of a 46 Mercury about a year ago. All the signs says it's a 59 a-b but it passes the pencil test above the timing cover. Here are a couple pics please let me know what you think Thank you GotIt
The marker is not sitting on the timing cover either. Should have noted that. The water ports are two round lower holes in the center and a keystone or v shape at the top
Did you measure the bore when you had the heads off? Could be a wartime-ish replacement block, which got the 59 stamp, small bore, and then might have the early-style front slope to go with the small bore. Maybe.
I have never heard about the pencil trick. what does it mean?? Please tell this old man about it.. Thank You..
I would suggest you ask this over on the Ford Barn. Those guys know all about flatheads & the different variants with them. Bill
Just copied this from the ford barn The front area of the block above the timing cover on a prewar block comes down like a "J", leaving a space where you can rest a pencil right above the cover. A normal 59A comes down like "/", and a pencil rolls right off. There have been sightings of 59's presumably made with a mix of foundry patterns showing the early front... But whatever you have, you'll be happier keeping your pencil in the glove box.
