Technical website list; the source bible for H.A.M.B.ers
Discussion in 'The Hokey Ass Message Board' started by atch, Mar 17, 2019.
  1. atch
    atch
    In August of 2004 Brad54 started this thread called "SOURCE, Reference Websites List". It went 'til February 2016.
    In January of 2006 I started this thread titled "a hambers websites list; or every site you need to know about". This one went until March of 2016.
    Both of these threads were very popular, referenced extensively, and grew to include hundreds of links. However, many of the links in both of these threads are defunct so let's start another one with current websites. Please include enough of a description that it can be found by doing a search. Repeats of links in the two threads above very welcome if they are still active.
    Here are some to get started:
    broken off bolt/stud removal: broken stud removal
    early ford serial numbers: Early Ford Serial Numbers
    help you find out your speed... http://www.richmondgear.com/101032.html
    decoding Chevy engine numbers
  2. Back up for great information.
    Deuces, manyolcars and hotrodharry2 like this.
  3. Sporty45
    Sporty45
    Great idea, thanks! Unfortunately, the axle dimension site you posted is gone :(
  4. atch
    atch
    Thanx. Deleted. See what I mean about not being still in use?
    Deuces and Sporty45 like this.
  5. atch
    atch
    Bolt Pattern Guide and Lug Nut Chart: https://www.crawlpedia.com/bolt_patterns.htm
    Bolt patterns of numerous automobiles: http://www.teufert.net/wheels/bolt-pat.htm
    Bolt Patterns of Production Automobiles: http://www.roddingroundtable.com/tech/articles/boltpat.html
    Ford Rear Dimensions: http://www.mustangsandmore.com/ubb/FordRearDimensions.html
    Rear Axle Measurements: https://www.hotrodworks.com/technical-information/rear-axle-measurements/
    Rear End Widths: http://www.carnut.com/specs/rear.html
    Classic Car Database: http://www.classiccardatabase.com/index.php
    Car Manuals for Old Cars: http://www.tocmp.com/
    The Old Car Manual Project: http://www.oldcarmanualproject.com/
    Automobile Catalog - The Complete Catalog of Cars Since 1945: https://www.automobile-catalog.com/
    348 and 409 General Information: http://www.348-409.com/general.html
    Engine Compression Ratio (CR) Calculator: http://www.csgnetwork.com/compcalc.html
    Engine RPM Calculator: http://www.csgnetwork.com/multirpmcalc.html
    Ethanol-free gas stations in the US and Canada: https://www.pure-gas.org/
    Ford 1932-54 Transmission Gear Ratios: http://www.vanpeltsales.com/FH_web/flathead_trans-gearratios.htm
    Ford Top Loader Three Speed Transmission: http://www.vanpeltsales.com/FH_web/flathead_transID_3speed.htm
    Fuel Injection; What You Need To Know About Mechanical Fuel Injection: https://www.dragzine.com/tech-stori...need-to-know-about-mechanical-fuel-injection/
    Haudaille shock absorber manual: http://www.oldcarmanualproject.com/manuals/Ford/Haudaille/index.html
    How to Make Your New Chevy Engine Look Old: https://www.hotrod.com/articles/how-to-make-your-new-chevy-engine-look-old/
    plowboy at the Playboy mansion: https://iowahawk.typepad.com/iowahawk/2009/10/plowboy-playboy.html
    (just had to throw this in)
    Model A Ford year identification: http://www.mafca.com/whatyear.html
    Military Wiring Harness Lacing: http://selectric.org/manuals/lacing/index.html
    (I'm pretty sure that this is squirrel's page)
    Illustrated Model A Body Styles: http://www.gwcmodela.com/bodyphotos.asp
    Identifying Muncie 4 Speeds: http://www.5speeds.com/muncie2.htm
    roadsters.com (thousands of links): http://www.roadsters.com/welcome/
    Borg Warner Second Design ST-10 4-Speed Info: http://www.pontiacpower.org/BW.htm
    Ford Flathead V8 - 1932 thru 1953: http://www.btc-bci.com/~billben/flathead.htm
    Nailhead History: http://www.underhoodservice.com/tech-spec-nailing-down-the-misunderstood-buick-nailhead/
    Transmission identification: http://www.crankshaftcoalition.com/wiki/Transmission_identification#T-10
    Transmission identification: https://www.monstertransmission.com/Identify-Your-Transmission_ep_106-1.html
    threadlocker (LOCTITE) information: http://type2.com/library/chemicals/loctite.htm
    lubricating the Trico Vacuum Wiper Motor: https://www.mafca.com/downloads/Technical/Lubricating the Trico Vacuum Wiper.pdf
    Elcohaulic, beegator, pitman and 4 others like this.
  6. atch
    atch
  7. atch
    atch
    Deuces and lothiandon1940 like this.
  8. Thanks for posting, great info.
  9. atch
    atch
    Deuces, jaw22w and lothiandon1940 like this.
  10. dodgedifferent2
    dodgedifferent2
    You do realize that canada has a law that all gasoline has to contain 5% ethanol. Just an fyi
    Deuces likes this.
  11. Kan Kustom
    Kan Kustom
    Deuces likes this.
  12. pitman
    pitman
    Hear, hear!
    Plowboy rules!
    Where is the Grote-man?
    Under the hood somewhere.
    Just Gary likes this.
  13. atch
    atch
    dd2,
    I don't doubt your statement, but there are loads of Canadian stations listed on the website.
  14. dodgedifferent2
    dodgedifferent2
    There may be but I think they are lying to the consumer to make sales. If they have a refinery in their back yard it is possible. I think the cost of a back yard refinery is a bit steep
    Let me sell you some water free snow
  15. atch
    atch
  16. atch
    atch
  17. patterg2003
    patterg2003
  18. atch
    atch
  19. atch
    atch
  20. Back up - searching for - I think Jim/Squirrel posted the GM part # look up site.....looking for that....thanks.
  21. hotrodjack33
    hotrodjack33
  22. hotrodjack33
    hotrodjack33
