Technical We talked about changing oil, how about the filters?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 17, 2019.
  1. I ran across this in depth article and it seems to shed some much needed light on what's available in different oil filters, interesting read. HRP
    Best Oil Filters 2019 – Buyer’s Guide and Reviews
    by Anthony Becker | Last Updated May 1, 2019
    We’re sure you’ve heard some form of the popular saying, ‘running like a well-oiled machine’?
    This cannot be truer when it comes to oil and your car. Simply put, if you don’t have oil then you’re car isn’t going to make it from point a to b.
    We all know that engine oil is needed to keep your vehicles’ engine ticking over smoothly.
    But did you know that an oil filter is a crucial component in this lubrication system?
    As oil moves through your engine, it picks of debris, particles of metal and other contaminants. Over time, the oil will get more and more dirtier, and begin to lose its ability to clean and lubricate your engine, eventually causing permanent damage.
    Hence, you need an oil filter to clean this oil and get your car purring like it was brand new.
    Many manufacturers recommend getting a new oil filter every time you change your oil. This can be anywhere from 3,000 to over 15,000 miles. That’s a lot of miles, so it makes sense to get the best oil filter possible.
    The problem is, not all oil filters are created equal… some will do a better job and do that job for longer.
    Determining the best oil filter for your vehicle whether that be a car or truck, motorcycle or auto-racer, is no small feat. That’s why we’ve done the hard work for you and have reviewed dozens of models to bring you the top ten best oil filters for 2019.
    Without further ado, let’s begin!
    Name
    Media Type Shop
    1. Royal Purple Extended Life Oil Filter Synthetic Check Price
    2. Purolator PurolatorOne Premium Oil Filter Blend Check Price
    3. AMSOIL Ea Oil Filter Synthetic Check Price
    4. Bosch Premium FILTECH Oil Filter Blend Check Price
    5. Mobil 1 Extended Performance Oil Filter Synthetic Check Price
    6. WIX Spin-On Lube Filter Synthetic Check Price
    7. Motorcraft Oil Filter Cellulose Check Price
    8. K&N Performance Wrench-Off Oil Filter Cellulose Check Price
    9. Baldwin Heavy Duty Lube Spin-On Filter Synthetic Check Price
    10. ACDelco Professional Fuel Filter Cellulose Check Price
    1. Royal Purple Extended Life Oil Filter – The best oil filter
    View on Amazon
    Royal Purple is an American manufacturer specializing in lubricants for many different types of vehicles. They’ve been around since 1986, which is pretty short compared to some of the other big players out there. Despite this; they’ve developed a large and loyal fan-base thanks to their high quality products.
    In the extended life oil filter, Royal Purple have shown why they continue to be one of the leading manufacturers when it comes to all things auto-care.
    Let’s get down to the important thing – the numbers. This filter provides 99% efficiency at 25 microns thanks to the 100% synthetic micro-glass media. The synthetic fibers are extremely compact and fine, preventing almost all contaminants from getting through. You can be assured that the dirty oil entering the filter is coming out clean and ready to service your engine.
    All components ooze quality. A nitrile rubber base gasket is used to prevent leaks as well as a silicone anti-drain back valve to prevent dry starts. The end caps, centre tube and bypass valve are all metal and will provide a lifespan comfortably over 10,000 miles. It’s an impressive number and makes the relatively high cost of this filter well worth it. The shell housing the filtration system is extra thick as well, which will keep the internal components safe from things like road debris.
    When it’s all said and done, it’s pretty hard to figure out what truly is the best oil filter. There are just so many variables. If you were to ask 5 people which one they prefer, you’d end up getting 5 different answers.
    However; based on all our research and from speaking to customers who’ve purchased this filter, all signs point to a product that may well be the best of its category. We wouldn’t blame you for going with something else a little down this list but we will blame you if you don’t at least consider this excellent oil filter from Royal Purple.
    Pros
    • Durable design with premium components (including metal backing of silicone media)
    • Expect at least 10,000 miles of use before filter change required
    • 99% cleaning efficiency at 25 microns
    • Brand with a reputation for producing leading products in the auto-motive industry
    • Well priced – you get what you pay for
    • Nice purple paint job
    • Extra thick shell
    Cons
    • Premium oil filter demands a premium price
    2. Purolator PurolatorOne Premium Oil Filter – Best budget oil filter
    View on Amazon
    Purolator – ‘pure oil later’ – have been around for over 90 years and provide some of the very best oil filters you can get your hands on. We’ll tell you why.
    It all begins with a high density synthetic blend media that results in 99% + efficiency and up to 10,000 miles of usage when used with full synthetic oil. Generally, an oil and filter change is typically recommended every 5,000 miles, so using this oil filter will save you a decent amount of coin over the long-term.
    Purolator have provided a ton of value considering the modest asking price. All components are built with premium materials including a silicone anti-drain back valve, metal bypass valve and metal center tube and end caps. In short, if there is one oil filter that can withstand the rigors of day to day use, this is it.
    Keep in mind that due to the high density of the media, the maximum oil flow rate will take a hit. The filter will still work perfectly well for most vehicles in most situations, but we’d advise to go with another filter that is specifically designed for high performance engines if that’s your specific need.
    It’s also worth noting that the media is not wire backed which is supposed to help maintain structural integrity. As it turns out, the wire backing isn’t needed since synthetic blend media is a lot easier to mold and more stable then its more advanced synthetic counterpart.
    Overall, the PurolatorOne is very well received by its customers and provides the best bang for your buck. Whilst it may not be the number 1 choice for high performance vehicles, if you are looking for something reliable, durable and affordable, then you should definitely have this filter on your wish list.
    Pros
    • All metal and silicone components for increased durability
    • Filters at least 99% of dirt
    • Decent, higher than average capacity of 15 g
    • Very well priced
    • Trusted brand
    Cons
    • Not the best for high performance vehicles like racers
    Purolator also offer 2 other lines of oil filters, the Purolator Classic and the PurolatorBoss.
    • The Purolator Classic is an entry class filter and a couple of dollars cheaper. You’ll get at least 5000 miles out of it but keep in mind that the construction isn’t as good as the PurolatorOne. It uses a rubber anti-drain back valve and cellulose media which results in a lower 96.5% efficiency.
    • Purolator’s most premium model, the PurolatorBoss is similar to the PurolatorOne but features a more durable design. It’s also almost double the price. You can expect at least 15,000 miles of use at 99% efficiency. The media is also fully synthetic with a premium silicone anti-drain back valve and full metal construction.
    Considering the prices of all three, it’s a no brainer that the PurolatorOne offers the best value for money. For most customers, the difference in performance between the PurolatorOne and PurolatorBoss will be negligible. However; if you demand the very best of the best, than the PurolatorBoss will be right up your alley.
    3. AMSOIL Ea Oil Filter – Premium oil filter at a premium price
    View on AMSOIL
    Since 1972, AMSOIL have been a leading producer of synthetic lubricants and filters. Every industry has a premium standard, and when it comes to oil filters, AMSOIL is it.
    We wouldn’t expect AMSOIL to use anything but the very best materials when it comes to their oil filters. They’ve used metal and silicone components as well as a wire backed synthetic media which offers an amazing 98.7% filtration efficiency at 20 microns. If you need your oil squeaky clean, than this is the right filter for you.
    You’ll be able to use this thing for at least 15,000 miles or 1 year (whichever comes first) before needing a change. Even more so, if you decide to get the other type of filter which is designated with the product code EaO, then you can expect this number to be pushed up to 25,000 miles. However; this is only guaranteed if you use AMSOIL synthetic oils.
    You may be wondering why this filter isn’t out top pick?
    Well, it’s basically the same as the Royal Purplse extended life oil filter which we’ve ranked as number 1. The only difference is that the AMSOIL filters cost more and don’t sport a fancy purple paint job. Take a look at this video if you don’t believe us. If you need further proof, they are also both made by Champion Labs.
    If we had to choose one over the other, we’d go for Royal Purple’s filter as you’ll save some money. Having said that, if you’re already a loyal fan of AMSOIL’s products then we wouldn’t blame you for going with this filter – after all, it’s still a fantastic product.
    Pros
    • Premium metal and silicone construction
    • Fully synthetic media
    • Last at least 15,000 miles or 1 year
    • Trusted and reliable brand
    Cons
    • Same build as Royal Purple oil filter but more expensive
    • Only available through limited vendors (best to purchase through Amsoil website)
    4. Bosch Premium FILTECH Oil Filter – Class leading filtration
    View on Amazon
    We don’t think a list about the best oil filters could ever be complete without the mention of at least a couple of German brands. After all, we all know that German engineering is considered a class above the rest.
    Bosch have been around since the 19th century and are the world’s largest supplier of automotive components.
    When it comes to motor oil filters, they sure know what they are doing.
    What makes their Premium FILTECH oil filter stand above the rest is the whooping 99.9% filtration efficiency. Particles as small as 20 microns will get caught in the cellulose and glass blended media. Bosch have followed the trend of ‘bigger is better’ and feature a media with 42% larger area and 30% thicker than other similar oil filters.
    Even though the blended media isn’t as high performing as a full synthetic media, the extra surface area (71 square inches to be exact) ensures industry leading filtration efficiency.
    The larger media results in about a 14 gram capacity. It’s more than enough, but about half that of Mobil 1 extended performance oil filters.
    Build quality is top notch. There is a silicone anti-drain back valve and metal bypass spring. Unlike other models where the bypass spring is something that can be detached, Bosch have decided to build the spring into the end cap. At this price point, it’s a very nice touch and will greatly increase durability and performance. The gasket design is also worth mentioning as it’s pre-lubricated to ensure a tight and easy fit to the engine.
    This oil filter is a fantastic pick for the price and features an all-round premium construction and high end filtration ability.
    It’s a top quality product that should be on your radar. If you’re budget conscious, then you can’t really go wrong with choosing an oil filter from Bosch or the previously mentioned Purolator PureOne oil filter.
    Pros
    • Durable design with built in bypass spring
    • Well respected German brand
    • Lubricated gasket for easy but firm fit
    • Fantastic efficiency
    • Very affordable
    Cons
    • Uses a blended media which isn’t as good as synthetic
    5. Mobil 1 Extended Performance Oil Filter – Great for high performance engines with industry leading capacity
    View on Amazon
    Almost everyone has heard of Mobil. They are a powerhouse in the American oil industry and have been around for over a century. When it comes to all things oil, Mobil is the company many people turn to.
    In comes the Mobil 1 extended performance oil filter and it’s no surprise that this is one of the top sellers.
    The filter sports a 99.6 efficiency at 25 microns thanks to the synthetic media material. Perhaps the most impressive feat is the class leading media capacity which can hold up to a staggering 28 grams of contaminants – double that of many competing products. Mobil have stated that this filter should last 15,000 miles (with synthetic oil) before a change, and with that sort of capacity we don’t doubt them.
    On top of this, you also get a premium silicone anti-drain back valve which prevents oil from pouring back into the filter when the engine stops. This ensures no dry starts since you’ll always have oil in the engine. There is also a metal bypass valve which is activated if the medium is clogged and can’t provide adequate flow rate to the engine. It’s a common safety you’ll find in almost any filter.
    Lastly, this unit can withstand up to nine times the usual operating pressure. In numbers, this equates to 615 Pascals per square inch which is higher than pretty much any other filter out there.
    Why is this important? Well, pressure changes depending on the strain on your engine. If you’re travelling at high speeds in hot weather for example, your engine will need more oil resulting in higher pressure. This fact makes Mobil 1’s oil filter perfect for high performance engines that demand a high oil flow rate.
    There are two nit-picks worth mentioning however. The first is that you can expect to pay a couple of dollars more over similar brands. The second is that the media does not have a wired back. You’ll commonly find a wired back in other premium oil filters to provide extra stability to the whole structure. Why Mobil didn’t include this in the design is beyond us.
    Despite these niggling drawbacks, you’ll find a powerful and premium oil filter here. Mobil 1 have provided a massive line-up of oil filters, covering 97% of vehicles in operation today, so you’ll have no issue choosing the right size for you. Whatever vehicle you have, there will be a Mobile 1 oil filter for you.
    Overall, this oil filter comes with our recommendation. It is constructed to a very high standard and offers class leading capacity. If you require a filter that can withstand the pressures of a high performance engine, this is it.
    Pros
    • Exceptional durability – premium metal and silicone components, and can withstand up to 9 times operating pressure
    • Up to 15,000 miles of use when used with synthetic motor oils
    • Synthetic media provides 99.6% cleaning efficiency at 25 microns
    • Trusted and leading brand in the oil and automotive industry
    • Excellent for high performance engines that require a high flow rate
    • Industry leading capacity of 28 grams
    Cons
    • Price is slightly bumped up due to Mobil 1 branding
    • Silicone media not reinforced with metal backing
    Tip: When installing a filter onto your vehicles engine, it’s handy to dab a bit of motor oil on the gasket. This helps make a better seal and will also make the filter easier to remove.
    6. WIX Spin-On Lube Filter – Great for vehicles with long idle times
    View on Amazon
    WIX are a well known brand with a specific focus on oil, air and fuel filters. If you need some sort of filter for you car, the boys at WIX probably have something for you.
    When it comes to oil filters, they offer 3 types for drivers of regular and light trucks. The one that stands out the most and provides the best value for money is the WIX spin-on lube filter.
    It’s built with a nitrile sealing gasket that is hydrogenated to improve durability in high temperatures. Other premium features include a steel baseplate, metal end caps and metal center tube. The bypass material is also a coiled spring as opposed to something like plastic. Lastly, the anti-drain back valve is made from silicone which is far more durable than rubber, and will do a better job at keeping its form under extremely low or high temperatures.
    The construction is excellent, but the media is also premium quality. It’s made from a synthetic material with an area of 55.5 square inches and provides an efficiency of 99% or more for most particle sizes. Oh, and one more thing, it’s also wired backed which is a sort of ‘scaffolding’ that helps keep the whole thing together.
    Keep in mind that this filter does have a fairly odd shape which may demand a specific wrench. However; once screwed on the gasket will do its job and firmly keep it attached to your vehicle.
    WIX is a favorite for vehicles with long idle times and lots of highway driving. Think trucking across the country. It makes sense that it is built with the highest quality components to give you the assurance that you won’t be stranded somewhere in no-man’s land. It’s a reliable brand and you can’t do wrong by investing in one of their oil filters.
    Pros
    • Excellent build quality with metal and synthetic components
    • Well priced
    • Excellent filtration ability with full synthetic media
    • Trusted brand
    • Good for vehicles with long idle times
    Cons
    • Odd shape will require a specific wrench to screw on
    For those looking for something with an even more durable design, you can take a look at the WIX XP spin-on lube filter. It’s better suited if you use your vehicle for trucking or towing or you typically drive in extreme temperatures. Simply put, if you’re vehicle is used for things that does not involve typical commuting, the XP filter is a good choice.
    7. Motorcraft Oil Filter – The most affordable oil filter
    View on Amazon
    The Motorcraft oil filter is the OEM (Original Equipment Manufacturer) for Ford, Lincoln and Mercury model cars. It’s trusted by these popular brands and by the people who drive them.
    The reason is simple – this is an affordable, well made and reliable oil filter.
    Starting from the construction, the filter features a steel, ‘ironed’ case. Basically, it is thinner where it should be and makes for a more solid fit over some of the other filters out there. It’s also painted to help prevent rust build up and corrosion. The fluted case end design will ensure an easy removal when you’re performing a filter or oil change.
    If you’ve been hanging around oil filter forums like we have, you’ll notice something unique with Motorcraft oil filters – they have a threaded (as opposed to the typical dome) end bypass valve. In the rare event that the media becomes clogged, a bypass valve will come into effect to ensure continual oil flow. The threaded valve in theory should do a better job in preventing dirt in the media from entering the oil flow, thereby minimizing any damage to your engine.
    For some, this feature is enough to choose a Motorcraft oil filter over any other. However; since a clogging event is so rare, most manufacturers don’t build such a valve and the majority of consumers simply don’t care for such a feature.
    When it comes to pure filter ability though, this filter falls short with an efficiency of 93% due to the cellulose media. On top of this, a capacity of 12 grams is very respectable but still significantly less than some other brands like Mobil 1.
    Despite the somewhat lackluster filtration, Motorocraft oil filters are some of the most affordable on the market. Considering the quality brand label and build, we highly recommend this product for fans of Motorcraft and those looking to save some money.
    Pros
    • Durable design with stamped steal bypass valve built into end cap
    • Extremely affordable
    • Trusted OEM for Ford, Lincoln and Mercury model cars
    • Threaded bypass valve for better performance in the event of a clogged media
    Cons
    • Lower filtration efficiency due to cellulose media
    8. K&N Performance Wrench-Off Oil Filter – Great for engines that demand a high oil flow rate
    View on Amazon
    The K & N Pro Series oil filters are designed for high performance vehicles that demand a high oil flow rate.
    Everything about this oil filter is designed for engines that need a lot of oil – think of racing and trucking. K & N have opted for an impregnated cellulose media. Whilst this does not offer a filtration capacity as high as fully synthetic media, it is found to allow a higher flow rate for heavier oils typically used in racing. Rest assured you can still expect a filtration efficiency of 99% for most particle sizes thanks to the large 94 square inches of media surface area.
    K & N have even designed their filter for high speed situations. You’ll find a 1 inch nut on one of the end caps which ensures an easy fit. The nut also contains a hole where you can fit a safety wire that will ensure the filter stays put during bumps.
    When it comes to the construction materials, there is a silicone anti-drain back valve and a spring metal bypass valve. The end caps and center tube are also metal. These are premium materials and will outperform similar oil filters that use plastic and cardboard for their components.
    K & N have decided to skip on reinforcing their media with a wire backing though. It has been speculated by some that a wire back may actually reduce the flow rate. We’ll never truly know why K & N opted out of using such a feature but it doesn’t deter from an impressive oil filter.
    Overall, this oil filter has been specifically built for high performance engines and you’d be doing yourself a disservice for not considering it if you drive a vehicle that requires a high oil flow rate. The filter will accommodate and perform well on blended or conventional oil, though we doubt you’ll be using it with anything but synthetic oil.
    Pros
    • High flow rate for high performance engines
    • Very affordable
    • Designed for easy installation and removal
    • Suitable for all oil types
    • Good efficiency rating
    • Excellent build quality with safety wire feature
    Cons
    • Media isn’t wired back (though this may increase oil flow rate)
    9. Baldwin Heavy Duty Lube Spin-On Filter – Truckers Number 1 choice
    View on Amazon
    Baldwin is known to produce some of the most heavy duty oil filters in the world. So much so that the Baldwin heavy duty lube spin-on filter is a favorite amongst trucking circles.
    It features a robust spring loaded metal bypass valve which allows oil to continue to pass through the filter when it has reached capacity. After all, dirty oil is better than no oil right? When you’re dealing with an expensive engine as is common in trucks or larger vehicles, the last thing you want is a dry engine.
    Apart from this, you get the standard components like a nitrile rubber anti-drain back valve and steel end cap. Interestingly, the media has 44 pleats. This is pretty average amongst many oil filters and we can probably guess it allows the oil to have a high flow rate which meets the demands of larger engines, like those found in trucks.
    In terms of cleaning efficiency, numbers are pretty hard to come by as Baldwin doesn’t provide these figures on their website. From our research, it looks like you can expect an average efficiency of 85.44% between 12 and 30 microns, which is below many of the oil filters out there.
    Despite this, Baldwin remains a favorite amongst many customers, but especially truckers. It’s a highly durable design which will withstand the rigors of any terrain and environment. And hey, the bold red paint job is a pretty nice touch as well.
    Pros
    • Durable design with metal components
    • Trusted amongst trucking circles
    • Nice red painted casing
    Cons
    • Relatively low efficiency rating
    10. ACDelco Professional Fuel Filter – Durable with a high burst strength
    View on Amazon
    ACDelco have been around for over 100 years and are owned by General Motors. You’ll find automotive brands like Chevrolet, Buick, GMC and Cadillac all sporting ACDelco factory parts.
    In the ACDelco professional fuel filter, we have a capable unit that is built to last.
    The filtration media is a wired-backed cellulose and has a 98% filtration efficiency at 25-30 microns. Pretty impressive.
    Truth be told, cellulose media isn’t as good as a synthetic material, but it’s also a lot cheaper. Overall, you’ll be paying a lower price for something that shows little practical difference. However; if filtration efficiency is a priority to you, you’re better of looking further up this list at one of the filters that use a synthetic media.
    Filtration aside, the most impressive thing about this product is the quality build. It features metal end caps and center tube as well as a silicone anti-drain back valve.
    A thermosetting adhesive seal inside the filter casing holds the filter media in a permanent position once the temperatures rises to a certain level. This effectively increases durability and results in an oil filter that has a burst strength 5 times greater than many engine oil operating pressures. You can rest assured that pressure spikes caused by thicker engine oil or due to hot or cold weather won’t pose any issues.
    It’s a super durable design and you can expect to get at least 12,000 miles which is covered by the warranty. Considering the relatively low price, it’s a great incentive for those of you who are sitting on the fence.
    Pros
    • Very durable design with metal and silicone components
    • Exceptional filter seal for increased burst strength
    Cons
    • Cellulose media offers less efficiency than synthetic
    Oil Filter Buyer’s Guide
    Now that we’ve listed our picks for the top ten oil filters, let’s take a look at the things you should look out for before buying your next one.
    What makes a good oil filter?
    If you were to rip the outer shell off an oil filter, it’ll look something like this:
    Media: This is the paper looking bit of the filter that works to clean your vehicles oil and remove contaminants. There are three types – cellulose, synthetic and a blend of both.
    SyntheticCelluloseBlend
    Generally synthetic media (can be made from nylon, glass or polyester) is the most efficient because the fibers can be manufactured at a much smaller scale than the large plant based fibers of cellulose. The fibers are tightly ‘criss-crossed’ and can pick up smaller dirt particles, whilst allowing for higher oil flow rates and greater capacity and durability. Seems all good right? Well the only downside is that synthetic media is more expensive to make and will bump up the price of an oil filter.
    The media type, its surface area and how many pleats it has helps determine the filtration efficiency of an oil filter.
    Warning! Many oil filters will show a filtration at a certain micron level which can be misleading.
    So for example, a filtration of 99% at 50 microns is much worse then 99% at 20 microns. Then there are other factors like nominal and absolute ratings as well as the various test methods employed by manufacturers. Suffice to say, it is very hard to find the true ability of an oil filters filtration efficiency. But don’t worry; the oil filters we’ve listed are generally considered the best the industry has to offer and have universally very high filtration ratings as well.
    Capacity: An oil filters capacity is its ability to hold the contaminants from the oil that passes through and is determined by the build and type of media. Theoretically, a larger capacity means a longer mileage change interval. If capacity is reached, then the bypass valve will come into effect to allow unfiltered oil to continue to pass through. Virtually all oil filters offer more than enough capacity (at least 10 grams). As long as you follow the recommended filter changes you shouldn’t have any issues.
    Oil Filter Construction: A good oil filter is made of metal end caps and center tube. You’ll find cheaper oil filter to make these components out of plastic or even cardboard.
    • The bypass valve is a component which activates when the capacity of the filter is exceeded. It allows oil (not filtered) to continue passing through to the engine. You usually want this to be made from stamped steel or a metal spring. This is far more durable than something made from plastic.
    • The anti-drain back valve works to prevent oil from draining back into the oil filter when the vehicles engine is off. This feature prevents dry starts. The anti-drain back valve should be silicone as opposed to rubber. Silicone is superior because it can better hold its structure under very low or high temperatures.
    • Lastly, some oil filters feature a wire backing for their media. This is sort of like ‘scaffolding’ and holds the media in place. You’ll usually find this accompanying synthetic or blended media which cannot be treated and molded as easy as cellulose media.
    These materials are what you can expect in a high quality oil filter. Rest assured that the oil filters we’ve featured in our top ten list are all built with premium materials.
    When is it a good idea to buy an oil filter?
    In many cases, it’s good enough to use whatever oil filter came with your vehicle. However; if you are looking to squeeze the most performance (and mileage) out of your car, then buying a premium oil filter is the way to go. This goes hand in hand with also using a premium fully synthetic motor oil.
    Synthetic motor oil lasts a lot longer than conventional motor oil, so it makes sense to get an oil filter that will last just as long. That way, you can easily get at least 10,000 – 15,000 miles of use before changing the oil or the filter. It may be a bit more expensive upfront, but you’ll help minimize potential engine problems in the future.
    Of course; buying a good oil filter is also recommended if your vehicle is used for specific purposes like auto-racing, trucking or off-road driving.
    ladyhrp, KoolKat-57, 3W JOHN and 3 others like this.
  2. Mr48chev
    I didn't even know Royal Purple made oil filters I usually run the Wix XP filters in most of my rigs. I've only got one out out of the batch that has synthetic oil in it and it takes going to the special order page to get it's filter.
    You have to remember that just about every filter manufacture plays the "mine's best and here's why" game though even though one or two put all their money in advertising and not in the filters.
    ladyhrp, 3W JOHN, VANDENPLAS and 2 others like this.
  3. FRAM, is a prime example of that! HRP
    dan griffin, ladyhrp, 3W JOHN and 2 others like this.
  4. Atwater Mike
    Atwater Mike
    My young counterman @ O'Reilly's sawed 7 oil filters in half, including Bosch (my former favorite, for Porsche/BMW)
    WIX is the shit! (the 'good stuff', described by millenials)
    I use nothing but Wix now. ("Oh, but its shape takes a weird wrench!" Sissy...Buy a wrench, or use BMW 'forcept type')
  5. I have used Motorcraft on my Fords for many years, Wix is my go to on Chevy engines. HRP
  6. BamaMav
    BamaMav
    from Berry, AL
    I put Baldwin as about the same as a Fram......junk!
  7. When it comes to anything Chevy, I prefer to run ACDelco. Will run WIX in a pinch as its usually in stock at the parts house. ACDelco has also been doing retro looking filters for a few years now as well. So they have that classic 68/69 look.
  8. Truck64
    Truck64
    from Ioway
    Oil Filter Directions since oh, prolly 1916: Hand tight + 1/4 turn.
    People who overtighten oil filters should be flogged.
    ladyhrp, R A Wrench, 3W JOHN and 4 others like this.
  9. RmK57
    RmK57
    How about Napa gold ? Heard they were made by Wix.
    Personally I use Motorcraft FL-1A or Wix, depending if I feel like driving to the Ford dealer.
  10. KenC
    KenC
    Good read. But, has the same issue as most articles on net discussing filters.
    excellent observation on material and construction. No data on the actual, measured performance.
    I know, or at least I'm reasonable confident, that all the makers have tested them. various flow rates, contamination types and sizes, etc. Sure wish they would make the raw data available to the customers so we could make real, informed decisions.
    Bob is the oil guy has a lot of data, maybe too much.
    I guess I just have to keep trusting brands that worked in the past for me. Anything from Wix, (Napa gold/Oreilly's ) or Mobil.
  11. NAES
    NAES
    I try and run Wix as much as possible.
    Its available everywhere around me and has a great reputation as well as affordable.
    Sent from my SM-N910V using The H.A.M.B. mobile app
  12. OLDSMAN
    OLDSMAN
    Yes NAPA filters are made by Wix. That's the filter that I use, NAPA . I agree Baldwin is a junk filter
    ladyhrp, 3W JOHN and HOTRODPRIMER like this.
  13. rockable
    rockable
    Wix here. Now owned by Mann + Hummel....German filtration company. I usually change every other time due to low mileage. Today's filter technology is eons ahead of 50's and 60's technology. The filters will capture smaller particles and hold more before the pressure drop goes to bypass.
  14. town sedan
    town sedan
    When my '60 Fairlane (223 L6 with a road draft tube) was my daily driver I'd change the filter (FL1A) with the oil change and then change the filter again at the half way point between the next oil change. Typical I'd go 2000 to 3000 miles between oil changes and the filter would get changed about every 1000 to 1500 miles. This helped keep the oil a little cleaner.
    -Dave
  15. LM14
    LM14
    from Iowa
    Always used a Motorcraft on my Fords. AC Delco on GM products. If those aren't on the shelf it's NAPA or Wix.
    I have walked away from good sounding cars or engines for sale if I walk up and it has a Fram filter on it. Tells me everything I need to know. The person that is selling it knows nothing about cars/engines. I hate them that much.
    SPark
  16. I’m surprised the Motorcraft filters aren’t that great compared to the better filters. They’re not cheap at Autozone. I found the one I need for my DD at Walmart for half of AZ. I may go back to using NAPAs filters but they also have Silver filters. I wonder how they compare to the Gold?
  17. OLDSMAN
    OLDSMAN
    You are so right on Fram filters. Years ago when I was a mechanic for the Ford dealership they had a display in the parts department with various oil filters cut apart. Motor craft, AC Delco Fram and a couple of others. Fram by far was the bottom of the barrel. You could see through the filter paper. Years ago Fram did a large amount of advertising, a lot of people swore by them because of the advertising.
  18. AHotRod
    AHotRod
    Only Wix filters for us … period.
    Remember, most of these new marketing filters are being designed for stock late model engines that in large are using oils that we do NOT use in flat-tappet cam engines and race engines. Just saw a SBC race engine go to crap on the dyno last week do to the incorrect flow rate of the K&N oil filter. Customer didn't know any better. Sad.
    Many of those others have taken down a good race engine.
    Do your homework.
    ladyhrp, HOTRODPRIMER and 3W JOHN like this.
  19. Nothing but Napa Gold (Wix) oil,. air and transmission filters in all my cars. Worth the little extra for a quality product. Mitch
  20. The two who do not like Baldwin, care to explain? I have always thought of them as good. Peterbilt Truck dealers use them.
    Too bad all percentages were not at the same micron.
    Thanks
    Ben
  21. 3W JOHN
    3W JOHN
    I have a brand new fram filter on the shelf in my garage,it has a thick coat of dust on the box and was the only thing in the garage when I bought the house 20 years ago,no engine will be damaged as long as it stays where its at.
    ladyhrp, town sedan and HOTRODPRIMER like this.
  22. lake_harley
    lake_harley
    Fram filters junk....um...OK. 342,000 miles on my OT Tahoe using mostly Fram oil filters. Oil consumption is maybe 1/4 of a quart of oil in 3,000 miles or more and have had zero engine problems.
    Lynn
    ladyhrp and HOTRODPRIMER like this.
  23. I have been running Amsoil filters on all my vehicles, both Diesel and gas, since 1977, and have been totally satisfied by the results.
    I actually ran a couple of Diesels with both a 1 micron Amsoil bypass filter as well as the full flow filter. The combination worked great, and having the spectromatic analysis on the oil, I was able to extend the time between oil changes to 30,000 miles. I found that because I don't put a lot of miles on my vehicles any more, I still use a bypass filter on my excavator, but sold the truck with the bypass unit.
    One filter brand that isn't getting mentioned, is Donaldson. I use 10 micron Donaldson filters in my excavator and the Bobcat. Excellent quality filter.
    A good friend of mine, that was in the auto parts business, had a new SB Chevy for his boat that came with a Fram filter. Every time he checked the oil, he found that the engine needed an abnormal amount of oil, and there was an oil film in the sump. He was going nuts looking for the problem.
    Finally, with the engine cover removed and with the engine running, he saw what he thought was a straw leaning against the filter. When he put his hand there to brush off the straw, he found that it was oil being blown out of a pin hole leak near the bottom of the filter. Even though he was in the auto parts business, he had to initiate a lawsuit to get compensated by Fram. Fram did settle when they were sued. I was a witness to all of this, and more because of their handling of the situation than the product, I would never use that product again.
    Bob
  24. BamaMav
    BamaMav
    from Berry, AL
    Cummins and Cat will void a warranty if they see one on their engines. Never seen a dealer use them for that reason. Most I've been in use Fleetguard.
    A friend of mine nearly lost a Big Cam 400 Cummins due to a Baldwin oil filter collapsing.
    I have seen the damage to crankshafts and bearings caused by one of their filters collapsing, not a pretty sight.
    I had a couple of Baldwin fuel filters collapse, causing the engine to quit. I learned pretty quick to use a better filter like WIX, Fleetguard, Luberfiner, or CAT.
    The only reason they sell as many Baldwins as they do is they are the "house" filter in a lot of quick oil change places like Speedco. Lots of big fleets don't worry about quality filters, they're only keeping trucks until the factory warranty expires anyway, so they use whatever is the cheapest filters. They could care less what happens in the long run, in the short run, saving pennies is their game.
    dan griffin, ladyhrp and HOTRODPRIMER like this.
  25. 19Fordy
    19Fordy
    What canister filter is best for the stock 1949-53 Ford/Mercury V-8?
  26. 49ratfink
    49ratfink
    my daily has an oil leak from the intake and I don't feel like messing with it. I add maybe 3 quarts every two months.
    I wasn't paying attention to how many miles I went and decided to change the filter... I cut the filter in half to look and the oil inside was thick and pure black while the oil on the dipstick was clean.
    I'll change it sooner next time.
  27. tomic
    tomic
    i'm skeptical that "YOURBESTPICKS.COM" knows anything at all about anything, never mind oil filters. that's just a compilation of marketing info. they write:
    "However; based on all our research and from speaking to customers who’ve purchased this filter, all signs point to a product that may well be the best of its category. We wouldn’t blame you for going with something else a little down this list but we will blame you if you don’t at least consider this excellent oil filter from Royal Purple."
    sorry, but this is bullcrap. where are the test results? who did the testing? "speaking to customers" means literally nothing. "used brand X and never had a problem" is fine personal experience. just because the glued-on end caps didn't fail doesn't mean it's "good".
    5 micron filtering is "better" than 25? how? can i actually see the difference in engine life? stuff needs to be quantified.
  28. No point in changing the oil if you don't change the filter. 4 quarts of new oil + 1 quart of old oil left in the filter = 5 quarts of dirty oil. If I was going to change one thing it would be the filter. Im surprised no one has mentioned the Frantz toilet paper oil cleaner? I use them and am convinced that they do what the manufacturer claims.
  29. 49ratfink
    49ratfink
    ^^ I love Frantz filters. they were made in Stockton and are all over the place at swap meets anywhere in and around hiway 99. they go for 10 - 20 bucks at swap meets and sell for $40- on up to $125-130 for NOS
