Hot Rods We goofed , 36 dash in 28 tudor.
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Aug 4, 2019.
  1. Kiwi 4d
    Kiwi 4d
    62BDCA41-FA0B-45CC-8699-5A8CFB4DC2A6.jpeg 17FBE506-A5C4-4817-97DE-2AE306E54B47.jpeg F30DA809-8791-4186-9CBC-AE451966FCD5.jpeg Well we are making progress on the 28 tudor with Y block and 5 speed with Winters quick change. But as per the rules when you change one thing it affects two other things. The rule reared its head when we fitted the 36 dash to our 28 tudor , we made a new dash rail and brought the dash out some to give a small glove box and additional clearance for the cable drive 36 speedometer to 28 gas tank ,sweet that looks good.
    A while later we fit the doors and realise the window winders run smack into the dash,darn . Even short winders will hit the dash .The first pic is the short winder (possibly a vent window winder ,maybe?) second is a standard winder.
    What are folks thoughts on a solution??
    Yes the floor is some mockup pattern wood .
    And no we are not using the big condom shifter or boot>
    Stogy and kiwijeff like this.
  2. loudbang
    Convert to some of the new electric window winders?
    fordflambe, Bandit Billy and Hnstray like this.
  3. oldiron 440
    oldiron 440
  4. Black Panther
    Black Panther
    from SoCal
    Cut a scallop into the dash...looks kinda square towards the door anyway..might make the transition from dash to doors a little more elegant..
    Woogeroo, Blues4U, Hnstray and 3 others like this.
  5. clem
    clem
    Find a shorter winder, perhaps from an early Ford rear window? Or cut one down.
    Got any dimensions of the two shown ?
    Stogy likes this.
  6. Windows? We don't need no stinkin Windows...:D
  7. garth slater
    garth slater
    from Melbourne
    Is there anything housed in the dash that would be effected if you welded in a “reverse blister” for clearance?
  8. Move the mechanism back,
    Move the mechanism down
    Power windows ,,,, there’s that retrofit unit with the motor that goes onto the winder shaft.
    Use the racers seat belt trick
    Stogy likes this.
  9. How about these, Can,t get much shorter. I believe 1946 Ford vent window winders.
  10. Stogy
    Stogy
  11. catdad49
    catdad49
    Model A coupe "winder" handles are approx. 2 3/4" long from the front to the center of the shaft. Hope this helps, Carp.
  12. I never ride with the front windows up. Just open the door to put them up or down!
    Dash looks awesome. Gave me some more ideas...
  13. topher5150
    topher5150
    not only that but you put the steering wheel on the wrong side:D
  14. Offset
    Offset
    from Canada
    Worst comes to worst install power windows and use the window crank as the switch.
    26 T Ford RPU and blackjack like this.
  15. 34Phil
    34Phil
  16. catdad49
    catdad49
    lothiandon1940 and Stogy like this.
  17. WB69
    WB69
    from Kansas
    Had to do just that before. Opening the door that is.
    Stogy likes this.
  18. Country Joe
    Country Joe
    those are chevy, I think but that was going to be my suggestion also. Vent window handles.
    Stogy likes this.
  19. oldolds
    oldolds
    Switch the doors to the other side!
    49ratfink and Robert J. Palmer like this.
  20. Exactly what I was thinking. :rolleyes:
    Tilt an inch (25mm) forward, window up. An inch back, window down. A pair of microswitches and centering springs to hold it in the neutral zone when at rest. I think the shorter type handle would be the right touch. The ivory spinner knobs are talking to me....... but if that clashes with the dash knobs, then chrome spinners are a generic blend, I suppose.
    Offset likes this.
  21. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    WHAT?
  22. goldmountain
    goldmountain
    I had the same problem with the window cranks using a '40 dash in my T coupe. Look up Canuck's post "Bear claw latch and window regulators - install in a 1930 Model A coupe". He does an excellent explanation on how he used Jeep Cherokee window regulators. The only problem I encountered was using the 1946 Chev window cranks. They fit the splines on the Jeep Cherokee but I'm still puzzled on how to utilize the retaining clips. I sent Canuck a PM about this, but he couldn't remember what he did so obviously it was something simple. I'll just keep trying. However, by mounting the window crank lower with this regulator, they clear the dash just fine. This is a very easy swap and in my case, I had cut my door glass a bit short and they would rock a bit and bind going up with the Model T regulators but with the Jeep units having a rack and cable setup aligning the glass vertically, it solved this problem. IMG_1107.JPG
  23. alchemy
    alchemy
    I'm also for moving the mechanism back a couple inches. It should still work fine. Especially if the top is chopped. Shorten the arm the same distance you move it back.
    (Do a mock up first to test the theory)
    Kiwi 4d likes this.
  24. Similar Black Panther's thought you could cut the high lighted areas flip them side to side and make a recessed area for the window cranks.
    However the steering wheel and pedals being on the wrong side would be my greater concern.:D upload_2019-8-4_16-57-51.png
  25. lostone
    lostone
    from kansas
    At this point I think your best recourse is to stop all and any work and save yourself a lot of aggravation and just send me the car.
    I know I know it's no problem, I'm happy to help ;)
    kiwijeff and Boryca like this.
  26. clem
    clem
    Whilst I see this as a possibility, would there be enough room for your hand/fingers to work the crank the winder without hitting the dash ?
    Hnstray and Kiwi 4d like this.
  27. Country Joe
    Country Joe
    Or just open the door to crank the window then shut it when you're done. :)
  28. s55mercury66
    s55mercury66
    from SW Wyoming
    One more vote for trying to relocate the regulators.
    32fenderless likes this.
  29. Kiwi 4d
    Kiwi 4d
    We don’t think we will recess the dash , imagine having to point your little pinky out in a dainty drinking fashion to crank the handle . there wont be enough room to get a decent hold on the winder.
    So if we chop the car say 4” we can move the regulator down a similar amount and still have enough travel in the window.
    Had some 4dr regulators and panel but gave them away, darn.
