Technical Water Pump for '54 Ford 239 Y-Block
Discussion in 'Traditional Customs' started by LIVFRD, Jun 28, 2018.
  1. LIVFRD
    LIVFRD
    Has anyone successfully located a replacement water pump for a Ford 239 Y-Block? Looking for something new, preferably not eBay.
    Thanks!
  2. Ralphies54
    Ralphies54
    Rock Auto shows 2 brands, both in the 60 dollar range.
    LIVFRD likes this.
  3. LIVFRD
    LIVFRD
    Thanks for the lead, sadly the Rock Auto ones look to be mislabeled. What I've been able to figure out is that the water pump I need (for a '54 F100) was a one-off. With this being the first year of the Y-Block, it was a new design for the water pump and they changed it by '55. The impeller spins in reverse and is a little smaller than later years, I think.
  4. I got one at Napa a few years ago? Never heard of them being one off?
  5. miker98038
    miker98038
    The 239/256 motors used a different timing cover with a smaller water pump. They were first year only, but I don’t remember them turning in reverse. If no one has a lead, try the Ford Barn or Yblock forever.
    LIVFRD likes this.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Our member HOT ROD PRIMER is a long time member of 1954ford.com you might want to message him for leads.
    LIVFRD likes this.
  7. Mac VP
    Mac VP
    The 1954 Y-blocks used a different pump than the 55-63 variety.......smaller impeller diameter primarily. The next thing to consider is that the truck pumps had a unique fan mount cast into the pump body (at the top). So, the 54 truck pump is definitely a one year item.
    Unless you can find a pump on an auction site, or a rebuild kit for it, you’ll probably have to try to get it rebuilt by someone like Skip Haney in Florida. He specializes in pump rebuilding. You should contact him to make sure he can handle it.
    We still have a couple rebuilt 1954 car pumps left but they won’t do you any good if you’ve got a truck to fix up.
    LIVFRD likes this.
  8. LIVFRD
    LIVFRD
    Thanks for all the tips!
