Hot Rods Wade Superchargers
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Apr 27, 2015.
    Deuces and Speed Gems like this.
  2. zacattack
    zacattack
  3. cac646
    cac646
    Does anyone have any manuals or specs for r building these? I've been into a couple 6-71's but these are way different
    Deuces likes this.
  4. Legendlives
    Legendlives
    They were quite common in the UK, and often fitted to the Rover V8 (Buick 215) engine.
    From my recollection they did not take to high revs very well, so were not really a 'performance' blower without serious money being spent on them.
    I had one on a Rover motor back in the 80's with quad sidedraft SU carbs on it which ran OK, but I never really leaned on it.
    Deuces likes this.
  5. cac646
    cac646
    I was able to get a manual for this blower. PM me if you need a copy.
    Stovebolt likes this.
  6. mgtstumpy
    mgtstumpy
    3 cylinder horizontally opposed 2 stroke diesel. There should be a few still laying around down here as they were quite common in the day, you couldn't mistake that unique engine 'Knock' that gave rise to the name 'Knocker'. Like most things English, a lot of components, body and mechancial were sourced by those in the know and exported back to the 'mother country' to assist in restorations over there.
  7. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, hotroddude;
    Any more pics of the Essex roadster? Usual side, rear, 3/4, interior, etc?
    TIA.
    Marcus...
    Deuces likes this.
  8. 270ci
    270ci
    Has a familiar look to me. It's been awhile since you posted your pic, so I was curious if you finished the Holden engine and got it running? Any progress to report?
    Deuces and Outback like this.
  9. Outback
    Outback
    from NE Vic
    does any one know of someone making snouts & or manifolds?
    Deuces likes this.
  10. Stueeee
    Stueeee
    from Kent, UK
    Here's a Wade RO 34 from a Commer TS3 fitted to my brother's Morris Minor. The motor is a 3.5 litre/215 Cu inch Rover V8.
    The blower's "snout" is fabricated from steel sheet. The manifold is an Offenhauser manifold which I milled the top off to be flat, then a 3/8" ali plate was TIG welded on -this work went out as I didn't have an AC TIG set at the time. As much metal as possible was milled from the blower mounting flanges as we really wanted to ensure that the Holley 600 DP would fit underneath without needing to cut the bonnet/hood.
    The blower provides 8 lb guage boost and runs at 1 1/4" engine speed, which does tend to cause a lot of wear on the gears (which are a cast Iron Bronze combo) As someone noted earlier in the thread, the RO 34 blowers ran at a very low speed on the source TS3 motor, so aren't really suitable for long life at high revs in our experience.
    I have the "new" 4 bolt main Rover motor for this car under build up in my workshop at the moment. When it's finished It will be getting an Eaton blower from a Jaguar V8 instead of the Wade.
    Drylake, ross59, Deuces and 2 others like this.
  11. Stovebolt
    Stovebolt
    Like your setup STUEEE (Stewart to your parents????)
    These blowers have an upper rpm range of 5000rpm. maybe that's why you are going thru gears. Also how are you lubricating them? Interested in knowing if you have sealed self-lubricating bearings.
    Drylake, Deuces and Outback like this.
  12. Stueeee
    Stueeee
    from Kent, UK
    Yes, understand that the wear is due to RPM and the gear setup, but machining a set of steel gears isn't a trivial task; The blower doesn't have sealed bearings, lubrication is ep90 gear oil.
    When this conversion was done 20 or so years ago, there wasn't a really any scrapyard alternative of a better blower in the UK. The Eaton blowers from modern Mercedes and Jaguars don't look as "period" as the Wade, but they are relatively cheap now, and they don't require any challenging work to install.
    Deuces likes this.
  13. Outback
    Outback
    from NE Vic
    Thanks for the info @Stueeee, I'm planning on running one on an 8ba flatty, it'll be stage 2 of the car once it's on the road, just keen to scrape up all the info I can. The wade is appealing as it is the right era & looks to be available.
    Drylake likes this.
  14. Outback
    Outback
    from NE Vic
    That Morrie would sure suprise a few folks!
    Drylake likes this.
  15. fullhouse296
    fullhouse296
    from Australia
    I have cast loonymum front cover ,finned rear cover and inlet plate for the Ro34 models . Also a nice Flathead blower manifold to suit . contact me if I can help you .
  16. 41rodderz
    41rodderz
    from Oregon
    Wow. :cool:
  17. I make Flathead V8 blower intakes. One is to suit a 471 blower and the other is a multi purpose one where you bolt an adaptor plate to the top and then you can bolt most types of blowers to it. Made from a high quality alloy, heat treated and cnc machined. 100 % Australian made P1080021.JPG P1080019.JPG IMG_0807 - Copy.JPG 24210248_2073715162914777_2732824474756665384_o.jpg
  18. Speed Gems
    Speed Gems
    Thanks for bringing this one back up @fullhouse296 i completely forgot about it.
    Deuces likes this.
  19. Stovebolt
    Stovebolt
    @fullhouse296, I'd love to see these parts
    Deuces likes this.
  20. junkyardgenius
    junkyardgenius
    from Kernow
    I,ve got some info on stripping and rebuilding these. I,ll dig it out.
    Drylake, Deuces and Stovebolt like this.
  21. nutrocker
    nutrocker
    I’ve just acquired a four banger with a Wade RO34 blower fitted. For the banger motor it’s the right cfm and rpm. At the moment it’s 20% over driven but I’m changing it to 1:1 so it’ll Rev out about the same time as the banger. The banger also has a scat crank, rods and forged pistons, along with an over head conversion.
    44835692-0B02-4170-9047-85BABF0DDD9E.jpeg DB1AE153-8CCD-497D-A043-2850AD5BE2C9.jpeg 971CA666-45DA-40F5-B5B9-83AD59CD2C16.jpeg 516563D6-D17E-46AD-A393-3B1ADFCF280B.jpeg 7BBCF355-F39F-48D9-8493-FC9BDC98211C.jpeg
    Drylake, Deuces, Kiwi 4d and 4 others like this.
  22. Old thread I know but we are trying to pull the gears off the front of a small older Wade blower. It is not going well. Anyone have any tech on disassembling one of there units???
    Speed Gems and Deuces like this.
  23. harpo1313
    harpo1313
    from wareham,ma
    have you tried freezing it?
    Speed Gems likes this.
  24. Drylake
    Drylake
    I just did a rough mock up of mine today. 20230501_130630.jpg 20230501_104251.jpg
    Stovebolt, Outback and Speed Gems like this.
