Hot Rods W 409 build...
Discussion in 'The Hokey Ass Message Board' started by MOTOV8N, Apr 6, 2015.
  1. heard from them '09 boys the overlooked truck block is now where it's at....some are running BBC cranks and such.....good luck with it.....
    MOTOV8N and volvobrynk like this.
  2. loudbang
    Cut them down a bit cavman so you can see them without clicking on link:
  3. BSL409
    BSL409
  4. BSL409
    BSL409
  5. indyjps
    indyjps
    mgtstumpy likes this.
  6. cavman
    cavman
    I bought a '32 5w, and got sidetracked.
    It's a '65 truck block, .040 over, Ross 11 1/4 : 1 pistons.'61 335 HP 348 heads, pocket ported, bronze guides, BB screw in rocker studs, and good stainless valves. Crane "Thumper" cam I don't remember the specs right off hand. The headers started out as Speedway BBC fenderwells for a tri-5 Chevy cut and pasted to fit '09 flanges. Backed by a Super T10, and a '66 Chevelle 12 bolt with a spool for now. I have never even heard it run yet..
    I want to work on it so bad, but the '32 has got to be done first.....
    Thanks loudbang for sizing the pics...
  7. liv4ths
    liv4ths
    I stopped by motov8n's place yesterday to shoot the breeze and check out the 409. It's going to look killer once it's all put together!!
  8. Hey someone put those carbs on sideways. :D :D
    mgtstumpy and loudbang like this.
  9. MOTOV8N
    MOTOV8N
    from Manitoba
    Well, fellas...i have to admit that this is my first time assembling an engine, but after doin a pile of research, this is the plan...
    Cylinders are .030 and it's a stock steel crank ground .020. i 'm goin with a hydraulic flat tappet Thumpr Comp cam with .512 intake and .498 exhaust valve lifts with a 107 lobe center. Two brand new non-ferrous Edelbrock heads with Crane Gold Race roller rocker arms and a dual-quad intake with two 500 CFM carbs are gonna sit on top.
    i hope You guys don't tell me that it's not a good set up because i already bought the parts haha! ImageUploadedByH.A.M.B.1428445428.054043.jpg
    i am definitely excited to get it put together, but i gotta go outta town for work...but i'll be on it as soon as i get back!
    mgtstumpy, liv4ths and cavman like this.
  10. MOTOV8N
    MOTOV8N
    from Manitoba
    By the way, thanks for posting those wicked photos fellas!!
  11. saltflats
    saltflats
    from Missouri
    I would have picked a different cam but if we all did the same thing we would all be married to the same gal.
    You will have a bunch fun with this 409.
  12. MOTOV8N
    MOTOV8N
    from Manitoba
    Haha!!...this is true!!
  13. saltflats
    saltflats
    from Missouri
    Here's a shot of mine with some different valve covers.
  14. saltflats
    saltflats
    from Missouri
    mgtstumpy, loudbang and MOTOV8N like this.
  15. MOTOV8N
    MOTOV8N
    from Manitoba
    Man-o-man...that's too cool! Is that sittin in a '63?
  16. blowby
    blowby
    from Nicasio Ca
    Been doing a little history reading on the Ws. According to the Wiki, the combustion chamber design, quench area and spark plug location gives a wide power band with good low end. Super Chevy says it was a cost decision which allowed compression ratio changes without retooling the cylinder head castings. Hmm, they managed to change the small block compression with just piston changes..
    So what was the real reason for this unique design?
    http://www.superchevy.com/features/sucp-0801-348-409-w-engines/
    http://en.wikipedia.org/wiki/Chevrolet_Big-Block_engine
  17. saltflats
    saltflats
    from Missouri
    mgtstumpy, MOTOV8N, Baron and 3 others like this.
  18. MOTOV8N
    MOTOV8N
    from Manitoba
  19. saltflats
    saltflats
    from Missouri
    Thanks it is kind of a cave and pave car but its better than a Honda.
  20. Larry T
    Larry T
    The bottom one in post 15 is in this. All numbers matching, all casting dates right. Not mine, I just built the engine, I don't have the temperment to chase all the "correct" parts. The correct wheels are in his garage, along with SS and small hubcaps.
  21. Were 409s noted for bearing problems? Back in the mid 60s, my dad drove a 63 chev tilt cab semi tractor with one. The rod bearings were good for about 20,000 miles. I know of 3 times that they rebuilt it, once with a new crank, thinking there was something wrong in the crank. After the third rebuild, his boss got rid of it.
  22. Tony
    Tony
    Adding to my other post :)
    Here is the one i screwed together in its "home" in my old 62.
    The one that GM built i posted is the #s match motor to my 63 i'm building now.
    I can't help it...just love these damn things!
    And MOTOV8N, you've some nice stuff there.
    I was originally going to build a stroked 409 and use it in my 32, but the purchase of the original 409 63 changed all that.
    Long story that isnt worth getting into. Simply put that motor went into the 62 because i built a '09 clone out of it.
    Tony
    mgtstumpy and MOTOV8N like this.
  23. MOTOV8N
    MOTOV8N
    from Manitoba
    i have no doubt that those 180 degree black/white wheel turn grey when ya get 'em spinnin fast enough!
  24. MOTOV8N
    MOTOV8N
    from Manitoba
    Just took this photograph 8 minutes ago...just snowed up here in Canada, but this is what i plan on dropping mine into in the future ImageUploadedByH.A.M.B.1428454925.061417.jpg
  25. Tony
    Tony
    Badass!!
    Love 63's! Had a few of them.
    Any more pics of yours?
  26. Road Angels
    Road Angels
    Ok lets all sing along....She's real fine my 409........She's real fine..my 409....my 409....... getty up getty up 409....... getty up getty up 409, if you know the rest damn your old
    i.rant and loudbang like this.
  27. Larry T
    Larry T
  28. Tony
    Tony
    Larry T....thats cool man :)
    Still showing its pride even without the chrome. :)
  29. blowby
    blowby
    from Nicasio Ca
  30. MOTOV8N
    MOTOV8N
    from Manitoba
    Those fuel lines look super-slick!
