Projects Voyage of the "Dawn Treader"
Discussion in 'Traditional Hot Rods' started by InstantT, Oct 17, 2016.
  1. joel
    joel
    It looks pretty good so far. Keep it up.
    InstantT likes this.
  2. InstantT
    InstantT
    from SoCal
    I haven't posted in a while because my 58 driver is falling apart.
    Found this while doing the front suspension.
    Sent from my LGLS992 using The H.A.M.B. mobile app
  3. InstantT
    InstantT
    from SoCal
  4. InstantT
    InstantT
    from SoCal
    My homemade spring spreader wasn't as strong as I thought it would be. Oops!
  5. InstantT
    InstantT
    from SoCal
    Hamb won't let me post photos!
  6. InstantT
    InstantT
    from SoCal
    Homemade spring spreader buckled and caused shackle destruction.
    But, I finally got the bones split. 20180708_160852.jpeg 20180708_161313.jpeg 20180708_164736.jpeg 20180708_173826.jpeg
  7. InstantT
    InstantT
    from SoCal
    I finally had a few minutes to mock it up and straighten the knuckles.
    I was pretty nervous, but hell, even glowing it takes a lot of force to twist. 20180722_005130.jpeg
    2bubbas likes this.
  8. joel
    joel
    It looks good to me and I've done this a couple of times. Check to ensure the wishbone shackle hole is tipped to match the spring in the vertical plane also. There might be a small caster change ( increase).
  9. InstantT
    InstantT
    from SoCal
    I was thinking about this.
    Right now they appear tipped down, but I'll have to get the axle at a normal height to check.
  10. InstantT
    InstantT
    from SoCal
    Dumb question:
    I'm guessing I need to adjust the rod ends to determine parallelism with the spring.
    Drive side seems closer than passenger with the same amount of threads showing.
    Passenger side seems reasonably close to parallel.
    Can I hook the spring up first, then adjust the rod ends? Or is the spring not necessarily square?
  11. joel
    joel
    The spring is not necessarily square. The first check would be to check wheelbase on each side; if it is the same, then your probably good unless the rear end is not square in the chassis. Another measure would be from the rivet where the center brace (the one that was damaged on your car) fastens to the bottom lip of the frame rail to the opposite side kingpin. Compare to the same measurement on the other side.
    Yes, hook up the spring first.
  12. InstantT
    InstantT
    from SoCal
    10/4.
    I was worried that if my knuckle bends weren't square enough, then ball joint adjustment would only amplify that. But I suppose the bushings will compensate fore slight deviations.
  13. InstantT
    InstantT
    from SoCal
    The more I play with the transverse setup, the more I think Henry had it way wrong.
  14. Wheeliedave
    Wheeliedave
    Millions of Ford cars and trucks drove many millions of safe miles with their transverse spring setups. If such setups are set up correctly today, they will work as well or better than those designed and built by Ford years ago.
    The problem lies with people who set them up incorrectly !
    X38 likes this.
  15. InstantT
    InstantT
    from SoCal
    That's probably true.
    I do heavy mechanics and parallel leafs make so much sense to me. I'm sure I'm over thinking this. But, hey! I'm a first timer.
    This car is gonna be badass!
  16. joel
    joel
    If the bends aren’t parallel to the spring eyes, it will put the shackles in a bind. If the shackles go together pretty easily, you’re probably ok.
  17. InstantT
    InstantT
    from SoCal
    They're pretty parallel right now, but adjusting the rod ends will throw that off very slightly.
  18. InstantT
    InstantT
    from SoCal
    VANDENPLAS, treb11 and joel like this.
  19. belair
    belair
    1. H.A.M.B. Chapel
    He gets blamed for a LOT of things.
    VANDENPLAS and InstantT like this.
  20. Put the spring on first, then attach the split wishbone ends. You can do this by hand. There is so much leverage with those long wishbones it's not hard.
    Also, why does that spring have a stock eye? You'll get another inch of drop with a reversed eye main leaf.
    Hombre and InstantT like this.
  21. InstantT
    InstantT
    from SoCal
    It came with that eye.
  22. If you want to get another inch drop, a spring shop will reverse that spring, or you can do it yourself, there are tech threads here on it. I would recommend it, the axle isn't enough drop in my opinion. STANCE IS EVERYTHING!
    EDIT: To give you an idea, a spring shop charged me $50 to reverse the eyes of the main leaf, remove a few leaves and install a spacer, so pretty cheap.
    Hombre likes this.
  23. InstantT
    InstantT
    from SoCal
    This one is set up with the drop axle and 2 leafs removed.
  24. InstantT
    InstantT
    from SoCal
    Quick update. Finished drilling for my engine mouns and started on the cylinder heads. 461 castings with 1.94 valves, but the chambers should be good for an extra point of compression.
    Unfortunately the guides need to be done. So off to the machine shop.
    Then engine assembly finally begins!!!!!!!!
    Holy smokes I can almost taste it.
    Also got the broken valve cover bolt out. 20180822_001729.jpeg 20180820_221115.jpeg
    Bandit Billy likes this.
  25. InstantT
    InstantT
    from SoCal
    Machine shop has everything. I decided to do the mag, surface, valve job, guides, and hot tank for about $275.
    The machinist asked why I thought 461 heads in a 39 ford were "period correct". Haha. He didn't get it.
    joel and belair like this.
  26. InstantT
    InstantT
    from SoCal
    Are front shock kits worth the price.
    Original plan was to back to knee actions.
    But I need new anyway, so......
    What say you all? Best ones available?
  27. YES! Tube shocks make a big difference. I used a Chassis Engineering tube shock kit, and sway bar. I also used a Drake tube shock and sway bar kit for the rear. My car rode and drove great. You still have the banjo rear? If not, disregard the Drake kit.
  28. InstantT
    InstantT
    from SoCal
    Chassis eng is now Heidts and the website is atrocious.
    I'm considering posies or PandJs.
    My rear is a TCI kit with a bronco 9.
    Banjo is stored for a rainy day
  29. joel
    joel
    I have Chassis Engineering shocks and sway bar in front on my avatar with their springs, shocks and sway bar in the rear. I have had the same combo on another 40 years ago and it was also very good. My 41 truck has the sway bar and shocks in the rear (Drakes) with buggy spring. It also works great. I think it’s well worth the money.
  30. 6sally6
    6sally6
    Wish-it had been a FoMoCo engine/tranny going in but........still lov'in the build!
    6sally6
