Hot Rods Voltage Regulators Brand Specific?
Discussion in 'The Hokey Ass Message Board' started by Crankhole, Aug 14, 2018.
  1. Crankhole
    Crankhole
    Are vintage voltage regulators brand specific? Not sure the application of this but was wondering if there's any reason it wouldn't work on a Ford flathead.
  2. wheeldog57
    wheeldog57
    Are you running 6 or 12 volt? The ones I have are stamped 6 or 12 volts on the back. Besides that, I believe that they are pretty much universal.
    Sent from my E6810 using The H.A.M.B. mobile app
  3. 302GMC
    302GMC
    from Idaho
    Niehoff was a quality part. Wouldn't hurt to look inside for any fuzz on the contacts from long term storage.
  4. Crankhole
    Crankhole
    This one is 12 volt, as is my car.
    Inside looks clean.
  5. Truck64
    Truck64
    from Ioway
    Check the the specs, I think where problems can arise is when a 40 amp regulator is used with a 30 amp generator, for example. The reverse would probably be OK. Should be good to go though.
    Definitely want to dress the voltage/current/cutout relay points with a spoon file or jewelers file. Using wet dry will work temporarily but likely cause them to burn.
  6. wheeldog57
    wheeldog57
    I bought an old 12 volt one at a swap meet ( still in the box). Mounted it and wired it up, no issues. Good luck
  7. Crankhole
    Crankhole
    Thanks for all the advice.
    302GMC and Truck64 like this.
  8. goldmountain
    goldmountain
    I remember there are two different types - A and B. Unfortunately that was a long time ago and I really wasn't paying attention. Google is your friend.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  9. Crankhole
    Crankhole
    You have to be a rocket surgeon to understand what the differences are. -Google :D
    Maybe I should be asking if this will work with an early Ford ('39ish) generator, converted to 12v. The regulator is 12v/35amps.
