  1. OKG853
    OKG853
    from Indiana
    I used to be a designer for company that used H. Armstrong Roberts pics a lot, mostly for church bulletin covers. They have become classic, vintage images.
  2. Spyder64
    Spyder64
    Please say some more, because I am quite puzzled...
    Do we see a wheel just before breaking into pieces?
    Do wheels deform this much at the start of a run?
    Is it an error in the picture?
  3. billsill45
    billsill45
    from SoCal
    It's a wrinkle-wall drag slick, designed to work with only a few pounds of air pressure (approximately 4 - 8 lbs.) The purpose is to have a maximum sized contact patch to improve traction when the car launches. There is a tube and/or liner inside the tire to maintain the shape. The current generation tire used in top fuel, etc. racing requires a wheel that clamps the wheel rim (bead lock) to the tire.
    Edit: Example of a bead lock wheel ... when the tire is mounted, the outer (gold) ring bolts to the wheel rim, securing the tire bead to the wheel. This style wheel is also often used on off-road vehicles.
    I'm sure the veteran drag racers among us will elaborate on the finer points of this style tire, cause that's all I got !!
  4. walpolla
    walpolla
    I don't think he means the tire. Look carefully at the wheel itself and you will see what he means.
    regards,Rod
  5. billsill45
    billsill45
    from SoCal
    Maybe I'm missing something ... I looked at the photo of the wheel again and don't see the problem. If you mean the color variation in the center of the wheel, I attributed that to the funkiness that real magnesium wheels have when they haven't been regularly cleaned.
    But I may be wrong ... happens all the time, according to my wife !
  6. Wensum Valley Rods
    Wensum Valley Rods
    from England
    I just looked at the picture and it does look like the slots in the wheel at about 7 oclock and 5 oclock are a bit out o shape. My guess is just an optical illusion as I can't for the life of me see wheels changing shape like that and then returning to their true shape again.
    Paul
  7. 4tl8ford
    4tl8ford
    from Erie, Pa
    That distortion could be from the camera and the film being used - Those tires are starting to spin up
  8. billsill45
    billsill45
    from SoCal
    I vote for optical illusion ... see the attached photo of the Eastwood & Barakat '32 magnesium Halibrands ... same deal. I've polished the damned things several times, so I can guarantee that they are not bent or deformed !!
  9. walpolla
    walpolla
    I am inclined to agree with you. The original pic of the dragster wheel most likely appears distorted by camera angle and shadows.
    Your shiny wheel shows the same characteristics.
    regards,Rod
  10. foxlincoln
    foxlincoln
    from Deland Fl.
    It looks like the shot was taken when the wheel started to turn and the wrinkle wall had not caught up,as the GOODYEAR was not distorted.
  11. KRB52
    KRB52
    from Conneticut
    As I recall, bead locks became a requirement when the wheels reached the point where they were spinning so fast and hard that the tire was actually pulling away from the rim, causing a loss of air in the tire. I believe that there are pictures from the 70's or early 80's where you can acutally see daylight between the tire and the rim. My dos centavos.
  12. 296ardun
    296ardun
  13. DrJ
    DrJ
  14. skipperbob
    skipperbob
    from Upstate NY
  15. Spyder64
    Spyder64
    Thanks Rod and others, I meant the wheel itself indeed. Tires warped like this I had seen before, but this seemed like a flexible wheel.
    okay, it is just a strange effect in the picture. Still an awsome picture of brute power. Great timing.
  16. NHRANUT
    NHRANUT
    from Western PA
    Unless the camera lens is centered exactly in the middle, and at 90 degrees, each slot is viewed from a different perspective, thus the illusion of them being different sizes.
  17. jroberts
    jroberts
    Shell 4000 Rally
    1961 Studebaker First and Second Overall
    1962 Studebaker First Overall
    1963 Chevy II First Overall, Ford Falcons First Place Team, Studebaker Winners of the Coup desDames
    1964 First Overall Volvo
    1965 First Overall Volvo
  18. jcmarz
    jcmarz
    from Chino, Ca
  19. 345WindowOregon
    345WindowOregon
  20. Novadude55
    Novadude55
    from CA
    Balboa Blvd Orange County Ca 1950s
    [​IMG]:cool:
    Hobie HQ Dana Point 1960s
    HB Electric Huntington Beach 1960s
    Tustin PD. Vintage Orange County CA 1950s
    Old Huntington Sheraton pier in background 1964
    Balboa Orange County Ca 1920s or 30s
    Huntington Beach 1920s
    OC Airport, 1967 Photo courtesy Orange County Archives — at John Wayne Airport, Orange County CA
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The capture of stillness and the motion. Just one milli second sooner or later would be just complete stillness or complete motion.
  22. hudson48
    hudson48
    I was reading a book I purchased back in 2009 when we did Route 66 called "Route 66 in Chicago". Hadn't looked at it for awhile.The book was published in 2007.
    Found these few interesting shots.I think the last one is more recent with the 32 5 window looking like a later hot rod but in traditional style.
  23. Hakro
    Hakro
    It's Formula One racing car Mercedes-Benz W196 from 1954–55.
  24. Add to all that, the depth (width?) of the wheel and the illusion becomes even more severe.
  25. swi66
    swi66
  26. swi66
    swi66
  27. swi66
    swi66
  28. swi66
    swi66
  29. swi66
    swi66
  30. SouthUrn
    SouthUrn
    from US
