  1. HEMIDAV
    HEMIDAV
    from FL.
  2. HEMIDAV
    HEMIDAV
    from FL.
  3. HEMIDAV
    HEMIDAV
    from FL.
  4. HEMIDAV
    HEMIDAV
    from FL.
  5. HEMIDAV
    HEMIDAV
    from FL.
  6. HEMIDAV
    HEMIDAV
    from FL.
  7. HEMIDAV
    HEMIDAV
    from FL.
  8. HEMIDAV
    HEMIDAV
    from FL.
  9. HEMIDAV
    HEMIDAV
    from FL.
  10. HEMIDAV
    HEMIDAV
    from FL.
  11. HEMIDAV
    HEMIDAV
    from FL.
  12. HEMIDAV
    HEMIDAV
    from FL.
  13. HEMIDAV
    HEMIDAV
    from FL.
  14. lewislynn
    lewislynn
    When chains might be required carry a 2x6 or thicker block no longer than the distance between the cross chains. Place the chains on the ground with the block between the cross chains. Drive the vehicle onto the block. Now your chains are free and under the tire. The vehicle is on solid surface. You can actually do both sides at the same time, no jacks required. The chains can be adjusted and tightened without moving the vehicle again.
    To safely stop on slippery roads, slightly keep power to the wheels to prevent them from locking up. Works best with four wheel drive. Not for quick stops obviously. Coordinating with brake and accelerator takes practice but it could save lives...It will also kill the engine on stick shift vehicles. Better the engine than lives.
  15. swi66
    swi66
  16. jeepster
    jeepster
    from wisconsin
  17. tommyd
    tommyd
    from South Indy
  18. tommyd
    tommyd
    from South Indy
  19. tommyd
    tommyd
    from South Indy
  20. Of course !!!!
    down-the-road and tommyd like this.
  21. tommyd
    tommyd
    from South Indy
