Features Vintage Multiple Carb Intake Pictures
Discussion in 'Traditional Hot Rods' started by PKap, Feb 9, 2013.
  1. PKap
    PKap
    from Alberta
    Hi guys, I have always have loved the look of the old hot rod engines with multiple carb set ups, especially the very early home made ones. I did a thread search, and could not find a comprehensive picture thread showing these.
    Dual quads are cool, and my favorite look is multi-stack injection, but I especially want to see multiple single and two barrel carbs that look Hamb appropriate. I have seen a lot on here, mostly 97s and frog mouth scoops seeming to be the most popular. What else looks right?
    Any photos that show linkage and fuel line details would be awesome. I am putting a '68 472 Cad engine into my 53 dually truck. For the fun of it, I want to build my own multi carb intake to give it a vintage hotrod look.
    So if you have them, please post the coolest looking vintage intake pictures.
    Thanks!
  2. PKap
    PKap
    from Alberta
    Guess I shouldn't start a topic at midnight! B.t.t.
  3. tommy
    tommy
  4. 296 V8
    296 V8
    from Nor~Cal
  5. RayPrager
    RayPrager
    [​IMG][​IMG]
    My 62 Chevy ,short step....235 warmed up with twins ,exhaust and cam...
    sorry for the picture quality
    Ray
    Roger Loupias and 6inarow like this.
  6. PKap
    PKap
    from Alberta
    Hi Ray, are you using a Fenton intake? Do you have a picture of the other side?296 v8 are you a hoarder? Looks like a cool stash.
  7. PKap
    PKap
    from Alberta
    Thought I would post a couple pics I stole from different threads. These are cool, and I know lots of you guys have more. Please put them up. ImageUploadedByTJJ1360534031.125129.jpg ImageUploadedByTJJ1360534055.157391.jpg ImageUploadedByTJJ1360534069.587692.jpg ImageUploadedByTJJ1360534088.372619.jpg
    ls1yj likes this.
  8. 60 Belair
    60 Belair
    A couple of mine
    Bob Lowry and Roger Loupias like this.
  9. PKap
    PKap
    from Alberta
    That setup on the blower is cool. Is that something you fabricated?
  10. Deuces
    Deuces
    I like this one....
    Bob Lowry likes this.
  11. Off my old '55.
  12. 1952henry
    1952henry
  13. doinbad
    doinbad
    from celina tn
    on my old t had just fired it hadn't finished it up yet but was only pic i could find
      22 KB
  14. topfuel55
    topfuel55
    from Hebron IN
    Not exactly vintage but mos def home built. 4 twos built at home with my mill and lathe. I started with a tbi intake and milled it down to the top of the bottom runners. Intake Free, Carbs Free, Milling Labor Free, needing 120$ worth of rebuild kits, and 120$ worth of scoops, Priceless.
    Deuces likes this.
  15. SinisterCustom
    SinisterCustom
  16. topfuel55
    topfuel55
    from Hebron IN
    What I currently have on my car. It's on loan from my buddy. We rebuilt the carbs and replaced on metering block. Runs ok still needs some tuning. Looks bitchin with the linkage moving around going down the road.
  17. PKap
    PKap
    from Alberta
    Top fuel, have you run that 4x2 setup yet? Did you take any pictures of how you blended the carb mounting plates into the intake runners?
    1952henry, I never saw a twin manifold quite that tall before. Can't really see, but I assume flathead? Who made it?
  18. MERC 55
    MERC 55
    302 with 3 autolites
  19. topfuel55
    topfuel55
    from Hebron IN
    I have not run it yet, still collecting carb parts. trying to get enough 2gc cores to get similar parts, then I have to buy or make jets that match. The intake was a dual plane and I milled the top plane off, so all 8 ports are connected thru the lower runners. It won't be the same as a ManAFre set up, but it should be easier to tune with the runners blended. Hopefully easier to jet. Overall the jetting demands on each carb should be less being it's not IR runners. I don't know if I have any pictures of the manifold without the carbs, or I can take them off to show you. I can tell you I left the center port divider and ground it to a soft radius between the siamesed intake ports.
  20. PKap
    PKap
    from Alberta
    I assume the linkage will run all four the same, will you be using 4 chokes as well? The vacuum signal should be pretty even with the way you mounted them. I am really interested to hear how well this works. Thanks!
  21. 29tudor
    29tudor
    66 401 Buick with low rise drag star and 94's
  22. olskl_dave
    olskl_dave
    I like this one.....:D:D
    Regards Dave,
    Elcohaulic likes this.
  23. 64falconsix
    64falconsix
    from Daphne Al.
    I consider this vintage, it hit the market in 60 not long after the Falcons hit showrooms. Holman Moody built 1 or 2 of the Tri-power six cars called the Falcon power pack as a promotion in 60 or 61.
    54EARL and 6inarow like this.
  24. 1952henry
    1952henry
    For a flathead Ford, made by Thickstun.
  25. PKap
    PKap
    from Alberta
    Is that Thickstun run well at lower rpm, or is more of a wot design? Does any one run one on the street?
  26. mgtstumpy
    mgtstumpy
    My old 6x2 Edelbrock log manifold which I just sold; and the one I am now using, a 6x2 Edelbrock crossram manifold, can't wait to hook it up.
    ls1yj likes this.
  27. Larry W
    Larry W
    from kansas
    2x2
