Vintage Mickey Thompson Speed Parts
Discussion in 'The Hokey Ass Message Board' started by 55Bomber, Dec 17, 2008.
  1. backnda60s
    backnda60s
    from bham,ala
    does anyone know where to get the cam gear that drove the distributor on the M/T offset cover for the sbf ,,,,and the crank seal number? thanks
  2. grazy
    grazy
    I just sold a very early timing cover that came off of a 283 Chevy labeled THOMPSON only .Guy that had it ran it in early 60's with Hilborn injection in a 32 3-window . Cool piece ( SORRY NO PICTURES ) but I'm Ford guy I know Mickey was tied in close with Pontiac did he do much Ford stuff ?
  3. Muttley
    Muttley
    Yes, tons.
  4. hotroddonnie
    hotroddonnie
    Looking for old school aluminum valve covers for my 429, any good sites? Not looking for any particular brand.
  5. pontman
    pontman
    Will the 70's work for old school? If so look on e-bay, automotive vintage speed parts, then search Mickey Thompson. You will find more than you need if you look enough!
  6. pontman
    pontman
    I bought one at the Spokane, WA. swap meet for 10 bucks. Mine is cast iron, Same with yours? I will buy your header cap story for nothing, but it sounds good to me.
  7. Yes, cast iron.
  8. pontman
    pontman
    This Mickey Thompson injector hat is on e-bay right now. High bid as of 9/13 is $355. Bidding ends on 9/18. I bet it goes over the $500 mark.
  9. boutlaw
    boutlaw
    I've got a M/T crossram intake for the FE I'll be installing in the 31. Finally got the distributor machined to fit as the intake requires a short drive adapter to be run between the manifold and the block. The adapter has the distributor drive gear, and the distributor used just uses the stock shaft that sticks through the shaft hole in the manifold and into the top of the adapter. The only problem with mine is that some genius machined off the M/T logo on top of the manifold.
    Does anyone know if M/T ever made an aluminum front cover for the Ford FE engine family?
  10. OneRustedDodge
    OneRustedDodge
    ThiS thread is rad, thanks.
  11. Algon
    Algon
    Boutlaw, If you look at the 64 catalog cover Muttley posted above the engine is a FE with the finned M/T timing cover which were also made with marine mount "legs"
    What is often lost is that M/T got serious about making parts for the Ford FE and SBF due to the GM racing ban. He's smiling because he just got a brand new Thunderbolt and doesn't have to fight with Pontiacs any more.:D
  12. pontman
    pontman
    M/T magnesium 62 Olds 3rd member, went for $202. and change. Not a bad price for a rare old part.
  13. titus
    titus
    It was broken.
  14. pontman
    pontman
    Cool old M/T Pontiac parts.
    Engine mount for boat?
    Beehive oil filter mount?
  15. Algon
    Algon
    Yes the versions with the "marine legs" were intended for boats but Iam surprised they were not commonly used as motor plates as sturdy as they are vs what we use today. I have an NOS FE mag drive marine cover which is very tempting to use in a dragster or Altered but it's a tale tell of a modern build with a miss used part.:D
    The oil coolers were available with adapters to mount them directly to the engine or to be used as a remote mount.
    Here are a few things I have... but I'm in great need of an FE blower manifold.
  16. mutant55
    mutant55
    Ok, FNG here, saw this thread and felt I needed to post to it with one of my recent finds for my 55 Chevy project, I am installing an Olds rear end in both cars, and found this M/T piece, not sure what year it is, as I see a couple of different styles, but I figure by looking at some of the other pictures, this must be a leter version, due to the changes for reinforcement around the flange, and the shape of the ribs. If anyone knows more about these........
  17. dirt
    dirt
    from norco, CA
    i picked up this m/t sbc blower intake with some other goodies a few weeks ago.
    here is the rest of the stuff i picked up. yes, that is a corvette fuel injection intake converted to a tunnel ram.
  18. toxic waste
    toxic waste
    from Iowa
    Hi
    I would like to buy a M/T Beehive oil filter . If anyone has one or knows where one is at please P.M. me. Does anyone know what replacement oil filter these use ?
    Thank you
    Toxic Waste
  19. pontman
    pontman
    Here is my M/T swap meet find from Monroe, WA. The seller is a Pontiac guy thru and thru, had them listed as for a Ford? Scored them for a $100.
      517.8 KB
      463.7 KB
      492 KB
  20. Danger Diaz
    Danger Diaz
    not a speed part but still cool.
  21. impalamike
    impalamike
    from Texas
  22. Nik
    Nik
    Do anyone else have a set of MT valve covers that the diing strip in the oppisie direction? I have a couple where eh stripe starts hign on the left, and then goes to the right. Was it a factory screw up or where there othere?
  23. Algon
    Algon
    Most of the cool stuff was obsolete in 64....and the only reason it's amazing is because no has ripped them off yet and it takes time,effort and cash to dig this stuff up. Offenhauser makes retro parts for catalog thumpers and that's the way it should be. You guys would freak over Cal Custom valve covers too if they didn't make millions of them over a thirty year period. The only reason those are not as cool as early M/T stuff is because everyone has them.:rolleyes:
    The story on the cigarette lighter is that M/T sold them to anyone with $3 and postage but leave to Ebay hustlers to make up that it's a one of one item owned by M/T himself and suddenly a Metro cheap knock off Zippo is worth $300. LOL:D
  24. pontman
    pontman
    So much for so little. These went for $500. plus?
  25. 51farmtruck
    51farmtruck
    I don't know how rare these are, but the front wheels on my 32 sedan are mickey thompson's. They are 15x5 early ford bolt pattern. I've never seen another pair that size let alone 5x5.5" bolt pattern
  26. 51farmtruck
    51farmtruck
    My dad has a pair of mickey thompson 15x8.5 chevy bolt pattern 5 spokes. I believe I have seen some other pairs of those on ebay before.
  27. INJUNTOM
    INJUNTOM
    Looking for the M/T catalog with the minibike on the front. Will pay good money for one.
  28. go-twichy
    go-twichy
    i've got a magnesium "thompson" front cover for my 392 that i'm collecting parts for. there is something magical about some of these vintage speed parts thats for sure.
  29. Mojo
    Mojo
    are the aluminum with a steel rim? I have some 14x6 small ford pattern M/Ts like that.
  30. impalamike
    impalamike
    from Texas
    I'd still like to have them and the other items in these catalogs:
