Time to let her go, I've owner her for 30 years maybe someone else can admire her for a while. For Sale - Original factory built Pat Bilbow, 1959 Lyndwood "Eliminator II" dragster, Fully restored ,98" wb, blown-injected SBC. Has all the correct Lyndwood bells and whistles accept a Lyndwood steering wheel. Found locally in PA in 1989 in a scrap yard, Chassis restoration done & restored as a injected 331 sbc ,C/D circa 1962 and ran in nostalgia exhibition till '95. Chassis was identified as the Solomon & Rorres A/D out of Havertown Pa in late '99. 355 ci, 010 4 bolt main block,arp main studs, resized "Pink" rods w/arp bolts, blower pistons, steel crank cut .010/.010,clevite bearings, moly rings, ARP head bolts,Fuelie heads, milled .010, 2.02/1.60 sst valves,aftermarket springs, 3 angle valve job, Hydraulic blower cam,+ matched lifters,crane roller steel rockers (to clear finned valve cover) guide plates,hardened pushrods, HV oil pump, early corvette oil pan, hilborn gear drive, timing cover, fuel pump, pump extension,shut off valve, 2" - 1.2 pitch drive set up,hilborn 2 port injector and scoop ,vertex magneto ,new headers, new fuel lines. injector barrel valve/injectors & bypass pill is set up for Cackle/display running . Ansen 2 piece cast iron blow proof bellhousing (NHRA Appr), Hays 45 lb flywheel, Zoom single disc clutch, manual chevy 3 spd w/ low & high set up (no 1st or rev gears), 57 chevy posi rear, olds axles w/extended studs,drum brakes. 15 x 8 american 4 hole magnesium wheels with new (er) Rader 8.20 x 15 slicks. Will need some mechanical TLC, I never finished configuring the bell crank to the injectors but it works. , new engine/blower have not been fired , has been in a museum for the last 5 years. what you see is what you get. $15000.00 , Serious offers considered,If you looking for something like this IM me and we can talk no dreamers or tire kicker please. thanks, Paul View attachment 4506750 View attachment 4506751 View attachment 4506756 View attachment 4506757 View attachment 4506763 View attachment 4506764 View attachment 4506767 View attachment 4506769
