Hot Rods Vintage drag racing guys, tire heighth question
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Dec 19, 2014.
  1. Roothawg
    Roothawg
    I have a set of 16x11 Halibrands on the Fly. The only tires I have been able to find are the 26x10-16 Hoosiers. I would really like to run a pie crust or something era correct like this http://www.mandhdragtires.com/12-00-16-nostalgia.html. The problem is, I am afraid with me running the 301, a 32 inch tall tire would just kill me off the line. That would be like a 6" jump in tire size. I am running a 301 with a glide, an 8" converter and a trans brake. I am running a 5.13 rear gear.
    Any suggestions?
  2. try radir tires. i think they make a 16 inch pie crust tire. mh makes a 16 inch smooth wall tire.
  3. Roothawg
    Roothawg
  4. blue 49
    blue 49
    from Iowa
    Towel City Tires has a 28 1/2" tall 10" wide 16" piecrust slick.
    Blue
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    How close are you to your redline now going through the lights ?
    Don
  6. Roothawg
    Roothawg
    Depends on how it acts out of the gate Don. I still have some left usually. I just hate the tires on the Fly. They hook ok, but just look wrong IMO. I don't get a warm fuzzy with recaps blue. I keep looking at them, but have a nagging in the back of my mind that says no. Always follow your gut.
  7. There's some real nice calculators out there that will help you figure out exactly what the change will do.
    If you want a taller tire and stay the same out of the hole, you'll need more in the gears. A deeper 1st or deeper rear gear.
  8. Roothawg
    Roothawg
    Yeah, the calculator would help. I just don't wanna kill my hole shot for looks. I could motor up, but then it wouldn't be as cool to me. These parts I'm running are dads old c/gas stuff.
  9. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Another case of a man who needs a Quickchange!
    31Vicky with a hemi likes this.
  10. hog mtn dave
    hog mtn dave
    The Hoosier DOT tires work well but I don't think they have the look you want. A T400 has a lower 1st gear than power glide. That's what I use with a 31" tire but our engine combos are different.
    http://www.race-track.com/news.asp?TOPIC_ID=532
  11. usmc50lx
    usmc50lx
    from St.Louis
    Root, what about gear change? Go taller slick and possibly a 5.20 gear if its available. Or maybe try them and see, it might not kill your launch as bad as you think and if it does a lower bar change or movement may get you pointed skyward again.... Just something to contemplate
  12. Roothawg
    Roothawg
    I stand corrected. I went out an looked at the size on my Hoosiers and they are actually a 28".
    I don't have any adjustments. My rear axle us mounted solid.....just like the 60's Bro. I am running a 5.13 so the next step would be in the 5.83 range.
  13. Danny G
    Danny G
    If you have a 9 inch I have a 5.42 I want to get rid of.
  14. Roothawg
    Roothawg
  15. CalGasser
    CalGasser
    M&H made a piecrust 16" tire but don't remember how wide. My buddy had it on his Big John Mazmanian Willys clone and it looked real good. Try getting in touch with M&H and see if still available.
    I believe the next ratio up from the 5.13 are 5.38's.
  16. usmc50lx
    usmc50lx
    from St.Louis
    I forgot.. I knew that fact and didn't think of it..taller tires and more weight behind the axle will fix that... Lol
