Vin location on 56 ford fi00
Discussion in 'The Hokey Ass Message Board' started by rustynuts 1939 coe, Jan 17, 2013.
  1. rustynuts 1939 coe
    rustynuts 1939 coe
    Need to locate vin number on frame my frame has a nova front clip numbers were cut off are there any numbers vin at the rear of the frame ....hope someone has info so i can register this truck
  2. voodoo1
    voodoo1
    Usually it's on the passenger side of the frame, in front of the cab toward crossmember. In your case, it's probably gone since you have a clip. Did it have a tag in the glove box? Do you have a title for it? Mike
  3. I believe its on top of the drivers side frame rail just behind the cab.
  4. Scumdog
    Scumdog
    Never ever found the VIN on my '55 frame - all I ever found was a brass 'tag' with a chassis number screwed to the inside of the glove-box.
  5. no55mad
    no55mad
    That's where my 55F100 was.
  6. XWYNNSGUY
    XWYNNSGUY
    It should be on the drivers side, inside front door jam. It's a plate with Vin# trans & gear ratio. Send me an email and I'll pop a pic. Good luck
  7. Mine is on the tag inside the glove box cover! Which is a 55 Ford F-100 Panel
