Technical Vapor Blasting
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Mar 11, 2020.
  1. blazedogs
    blazedogs
    This really does n,t apply so much for car parts. I never seen this done before till now .It,s called vapor blasting used mostly for aluminum.This blasting does not remove metal but mostly polishes and leaves a nice finish before assembly, much cleaner that if we do it ourselves. It,s water under pressure with a media done in a cabinet.
    I,ve never seen this mentioned on the HAMB websight. Do any of you use this method and what do you think of it ? Gene
  2. $um Fun
    $um Fun
    from Nor Cal
    That all I use on my aluminum parts. This is a in and out box I did recently. 20180518_132135.jpg
    LAROKE and loudbang like this.
  3. pirate
    pirate
    from Alabama
    Vapor Blasting is used a lot in the Aerospace Industry. It is often used on machined pats to clean or gives uniform finish without removing material. It’s also used to clean used parts in preparation for rebuilding. Work’s equally well on aluminum and ferrous metals. Additives to the vapor blasting can inhibit rust or other corrosion. Vapor Blasting is sometimes used on a aluminum to give a uniform finish prior to anodizing and on ferrous metals before adding coatings such as paint, Teflon, etc.
    Hnstray and loudbang like this.
  4. Brand Apart
    Brand Apart
    from Roswell GA
    It's also used on Snap-on screwdriver tips. They vapor blast the chrome blades at the tips to give it an even better texture and grip also helps keep the chrome from peeling off when you beat on them unlike the cheap junk.
  5. I worked a job where the guys took old aluminum street signs and blasted them. They reused them after silk screening the new info on them. I was given free reign of the blast cabinet. It used spherical glass beads in water under pressure. I used it on everything from steel, cast iron to aluminum. Fantastic piece of equipment!
    DeLuxe 32 likes this.
  6. treb11
    treb11
    Rocky, with all due respect, that is not vapor blasting. True vapor blasting is carbon dioxide (dry ice) blasted onto a substrate. Usually for paint or coating removal on very delicate surfaces that the user does not want altered in any way. We used it to clean rubber seal molds of baked on elastomer.
  7. blazedogs
    blazedogs
    The parts I saw done were beautiful. The aluminum parts after being blasted appeared like they were polished. I'm surprised this isn't more popular. Maybe there is a cost factor ? Every crevice and indented area were like new in appearance. What I saw were on old ( aluminum motorcycle heads)
  8. Here are some carburetors I had vapor blasted prior to rebuilding them last year. Nice finish I thought.
    VANDENPLAS, LAROKE, mgtstumpy and 6 others like this.
  9. Vapor honing, blasting, wetblasting.....lots of names for the same this....but yes with reference to what we are talking about its a slurry of glass beads and waterr mixed with high pressure air. Can substitute other media such as aluminium oxide for a coarser finish.
    Sent from my SM-G965F using The H.A.M.B. mobile app
    LAROKE likes this.
  10. I've just ordered a bunch of bits to convert my sand blasting cabinet to a Vapour blaster....can't wait to get blasting. Heaps of DIY info on YouTube.
    stanlow69 likes this.
  11. earlymopar
    earlymopar
    Used to a great extent on injection molds and die-casting dies.
  12. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    High production assembly component Mfg's often use Dry Ice Blasters to remove excess weeping of glues / foam / sealers from edges / corners for ascetic purposes.
    Quick / Harmless.
    Desoto291Hemi likes this.
  13. Dry ice. eh? Have never heard of this. interesting.
  14. Tman
    Tman
    Just saw this done on an OT grungy Ferrari out of storage. Pretty impressive
  15. cfmvw
    cfmvw
    My last job did a lot of injection molding, and had a dry ice blaster to clean the molds. I used it a few times on some of my own stuff, it worked great!
    Roothawg likes this.
  16. Roothawg
    Roothawg
    We had one of our aircraft stripped with dry ice. Kinda cool. Everything that was left over evaporated.
  17. alchemy
    alchemy
    It doesn’t evaporate, it sublimates.
  18. Roothawg
    Roothawg
    Tomaters....... Tomaturs
  19. stanlow69
    stanlow69
    from red oak
    Post a link of a good example.
  20. woodiewagon46
    woodiewagon46
    from New York
    They also use the dry ice blasting in building renovation. It's used in extreme mildew situations or after a fire. It literally makes the wood look new, with zero residue from the blasting.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    A recent episode of the TV series This Old House used CO2 vapor blasting to remove the charred portions of wood damaged in a house fire. They said it was the only way to permanently remove the smoke odor.
    Advantages included there was no need for clean-up as the CO2 sublimes. But that also meant the operator needed an outside air supply to prevent asphyxiation. Very interesting
  22. LAROKE
    LAROKE
    It did a great job on my Carter 500 AFB (glass beads and water mixed with high pressure air)
    30tudor and DeLuxe 32 like this.
  23. alchemy
    alchemy
    If there are abrasives in the mix, it's not really vapor blasting, right? It's just (insert abrasive type here) blasting with a water vapor used for application.
    I've seen the dry ice blasting used on a local building to remove mildew. I wonder what it does to rust? I could see it being used to remove paint, but rust is tougher.
  24. stanlow69 and 30tudor like this.
  25. 31Apickup
    31Apickup
    Vapor blasting uses an abrasive with water. Dry ice blasting does not have secondary water. It’s two different things. I seen the This sold House episode with dry ice on the burnt wood, the main concern for the user with dry ice is adequate ventilation so you don’t suffocate.
    DeLuxe 32 and stanlow69 like this.
