Vacuum port location
Discussion in 'The Hokey Ass Message Board' started by Phred, Jun 27, 2010.
  1. Phred
    Phred
    from IL
    I want to use a vacuum gauge to test/tune on my engine with single downdraft 97. The carb has no vacuum port, nor does the intake manifold. I can drill and tap into the neck of the intake just below the carb to put in a vacuum port.
    Is this as good as a location as any to do this, or is there a preferred location for a vacuum port?
    Thanks in advance.
  2. tommy
    tommy
  3. Normal Norman
    Normal Norman
    from Goshen IN.
    phred, Yes, put it lower than the carb base. That will provide manifold vacuum. That is what you want for tuning. Normal Norman
