Technical Vacuum Advance on carburator
Discussion in 'The Hokey Ass Message Board' started by White_Attack, Jun 18, 2019.
  1. Having an issue with my Carter AFB where the vacuum sucks while idling and not while accelerating.
    How do you stop this from happening? How do we keep it from sucking in idling position?
  2. LM14
    LM14
    from Iowa
    What's wrong with advance at idle?
    SPark
    Montana1 likes this.
  3. Get a vacuum gauge and check the vacuum ports on the carb to find one with ported vacuum instead of manifold vacuum. Then hook that port up to the distributor advance.
  4. Scumdog
    Scumdog
    That's exactly how it should be - the lighter the load on the motor the more advance you get, the more economy you get - and that's just one advantage of using manifold vacuum.
  5. boltupal
    boltupal
    from western ny
    Vacuum advance needs to connected above the throttle blades. { spark ported}.
    egads likes this.
  6. distributorguy
    distributorguy
    from MN
    When you're accelerating, your engine vacuum drops to near zero. No vacuum advance under load is what you want, and its virtually impossible to set it up any other way. Try driving around with a vacuum gauge in the passenger compartment for a while so you understand what's actually happening. Switch between manifold and ported vac to see its exactly the same except at idle.
    If your ported vac had a signal at idle, either your throttle is open too far and its unshrouding the port, or the bushings are shot and the throttle blade is no longer covering the hole.
  7. town sedan
    town sedan
    Timed vacuum above the throttle plates. Manifold vacuum below the throttle plates. Which do you want?
    -Dave
    Jalopy Joker likes this.
  8. Deuces
    Deuces
    from Michigan
    I always went with full time vacuum.... Never a problem...
    OLSKOOL57, Montana1 and i.rant like this.
  9. Truck64
    Truck64
    from Ioway
    Scares the womenfolk and horses.
    White_Attack likes this.
