Hot Rods V belt tensioner
Discussion in 'The Hokey Ass Message Board' started by lcfman, Sep 10, 2021.
  1. lcfman
    lcfman
    from tn
    I am in the need for a v belt tensioner that I can adapt off an a/c bracket. I have spent about an hour on line looking for something I can fab up but almost all the tensioners are for flat serpentine belts and the few v belt tensioner I saw look like machinery applications not automotive. Any suggestions welcome.
  2. 19Fordy
    19Fordy
    Pictures would help along with vehicle/engine info.
  3. dalesnyder
    dalesnyder
    Look at V8 mustangs from the early to mid 70’s, they had them. Maybe look at rock auto.
    Bob Lowry likes this.
  4. DDDenny
    Something I whittled out.
    Cosmo49 and jnaki like this.
  5. larry k
    larry k
    Think riding mower decks with v belts !
  6. Mr48chev
    Many late 60's though the end of V belt Ford V8 engines had them.
    Start with a search for 72 Ford AC idler pulley and go from there.
    gimpyshotrods, egads and Bob Lowry like this.
  7. Last edited: Sep 10, 2021
  8. Bob Lowry likes this.
  9. 1930ModelA
    1930ModelA
    Mid 60s Corvette Idler arm pulley repop?
  10. bill gruendeman
    bill gruendeman
    I think most moved the a/c compressor to tension the belt, no idler like a serpentine belt.
  11. iamdiffrnt
    iamdiffrnt
    Top center in the photo Jnkyarddog_1 posted, should be the same as 69 mustang 5.8 a/c idler. Rock auto has them for around $15.
  12. goldmountain
    goldmountain
    All the old add on air conditioners with the York compressors seemed to have belt tensioners. If you find an old one, it takes the same bearing as most old alternators.
  13. Jack E/NJ
    Jack E/NJ
    from NJ
    Think skateboards. Wheels for tensioning & wrap. 8^)
    Scott, caseywheels and fiftyv8 like this.
  14. onetrickpony
    onetrickpony
    from Texas
    Use a V-groove for pulling the belt out but a flat tensioner can be used on the back of the belt for tension, too. Using a flat one on the back can be better because it increases the belt contact with the pulleys on both sides where a v pulley decreases the contact.
  15. fiftyv8
    fiftyv8
    from CO & WA
    Some farm machinery also had these items...
  16. indyjps
    indyjps
    Consider a mid 90's GM tensioner, here's the back. Easy to mount and uses a pin to locate, clock it anyway you need. Easily replacement, and many lengths and offsets, GM used them on everything
    Can use it in the back of the pulley, as onetrickpony suggested.
    If you want to swap the pulley, get one with a sealed bearing. Bearing will have a number in the seal and can be replaced if needed, pulley shouldn't wear.
    I searched for 3" diameter steel v pulley, need to ensure the bearing bore aligns with the bolt for the tensioner.
